Rick Abramson
Everything posted by Rick Abramson
  1. When I was building my 1:400 QM2, I noticed immediately you could see athwartships through the superstructure. I made a template of the inside of the balconies and cut clear acetate. I then painted one side of the acetate flat black which would be inboard. That did the trick!
  2. I airbrushed the entire model using TruColor paints' US Navy colors and also drilled out all of the portholes. The model came with nicely done photo etched parts. The girders supporting the flight deck are solid plastic castings with raised girder details. To create the "illusion" of open girders, I painted the girders gray, then painted them flat black. After the black had dried, I then took a pencil eraser and removed the black paint from the raised girder detail leaving what would be the open areas black.
  3. Assembly process for the Trumpeter 1/350 USS Langley, CV-1. The US Navy's first aircraft carrier. The Langley was converted to an aircraft carrier from the US Navy's collier USS Jupiter.
  4. Thank you for your response. I definitely followed your suggestion. . . .much appreciated!! Rick
  5. The Revell USS Olympia has been rated as the finest plastic model of this famous ship. I improved the model with laser cut wood decks and many photo etched parts. The model was airbrushed using Trucolor paints.
  6. Just out of curiosity, is it a requirement that models presented here are to be wood only? My builds are mostly plastic. If plastic doesn't "qualify", I don't want to take up space here. If that's the case, no offence taken.
  7. Thank you Norm on behalf of John and myself. To say the least, building this model is not a "pleasure cruise."
  8. This is the original Revell model of the FDNY fireboat the "Fire Fighter." She was in service for 50 years and will eventually be on display at Mystic Seaport. Model 1/87 scale. All airbrushed with Trucolor paints.
  9. As info, that "I" beam like structure from the bridge to the bow was a removable support for a canvas cover to provide shade.
  10. This is the original ITC model of the USS Oregon from 1959. Original price was $2.98!! I built this in 1977. I made all of the railings. The model was re-released by Glencoe Models. It does appear frequently on ebay. . .a bit more $$$ than $2.98.
  11. Chris, Eric and Don, thank you for your kind comments, much appreciated!! This "kit" is certainly not for the "feint of heart." It is basically a "scratch-building kit." Except for the Portland, I build usually in plastic. I attached some shots of my plastic builds., Top to bottom: QE2, QM2, USS Olympia, details on USS Arizona. The bridge and fighting tops on the Arizona are all photo etched parts.
  12. An additional note; the paper flags proved to be too heavy resulting in the flags flying in different directions. . .not good! I had decals made from the paper decals, they worked perfectly! Not only are they lighter than the paper ones, after installing the flag halyards with black thread, I then gave the thread a thin coating of ACC which stiffened the thread preventing it from twisting.
  13. After a joint effort between John Elwood who began the Portland in 2016 and myself, who took over where John left off, the Portland is finally complete. I would never want to tackle anything like this again! Now awaiting the plexiglass cover. The second photo is before I stained the base.
  14. I have to agree with norm1116. This model is a horror show! The book of instructions is basically useless. A great model builder friend of mine began building it in 2016 and recently threw in the towel. A thick London fog is easier than the instructions. My friend completed about 80% of the model and gave it to me if I wanted to take it from where he left off. I did accept it and will try my best to complete it. I think it was easier for our code breakers in 1940 to decipher JN25, the Japanese naval code. MODERATOR'S NOTE: To see Rick's finished Portland, click here.
  15. This is the Revell USS Olympia. The hull and waterline are Trucolor; the superstructure is Floquil Depot Buff. Decks are laser cut.
  16. For primer, I use the Tamiya Surface Primer, item no. 87042. It is fabulous. For masking I use the 3M blue, medium adhesive. Except for the primer, the model is entirely airbrushed. Normally, Trucolor does not need to be thinned. If it does, I cut it with lacquer thinner. Glad you like the model. She took 3rd place at a model ship conference. I recently finished the Trumpeter 1:350 USS Saratoga and used the Trucolor USN paints. The gray for the hull and mahogany for the flight deck is 100% on!
  17. I have been using Trucolor paints for quite awhile. They were formally Accupaint. I use this paint on my ships, planes and model rr equipment. It is fabulous! I cannot recommend it enough! I attached a shot of my Revell 1:400 Queen Mary 2 that I painted with Trucolor Paint.
  18. This the Revell PT-109 that I painted as PT-117.
  19. Here's a shot of the 12"=1 'scale QM2 that I took from the tender in Barbados
  20. Here is another shot of her under construction; positioning the superstructure and how I have the model displayed.
  21. John: Guess I was waiting for my ship to come in
  22. Don: Here are some shots of her under construction. The kit had 550 parts and took a month to build. I used 13' of masking and 3oz of paint.
