Posts posted by shipmodel
Hi all -
Here is my first build log. I'll try to make it complete and comprehensive, but please let me know if I don't explain things too well.
This is a commission from a group of owners and racers of this cutting edge design. A one-design yacht is where an agreed upon design is built by all of the boat owners and then raced against each other. This reduces the effect of technology and puts a premium on sailing tactics and boat handling. The latest design that was chosen was a 42 foot version of the Swan line of boats built by Nautor of Finland and designed by Frers Design Office. The first hull came off the ways in 2005, with about 45 more in the water today.
I was provided with some proprietary plans and drawings which are accurate down to the millimeter. I cannot reproduce them, but here are some drawings that are available on the internet, and some photos of boats on the water.
Swan 42 by Dan Pariser (shipmodel) - one-design racing yacht - Finished
Hi Bob -
Thanks. I'll try to keep up the level of my work.
Here is the second installment:
The model was specified to be in 1:32 (3/8"=1') scale, so I first sized up the plans provided to the exact size of the model, just under 16 inches LOA. Looking at the plans I determined that the best way to shape the hull was by a series of horizontal lifts. I took the waterline lift half-plan, mirrored it in Photoshop and combined them to make a full plan that could be cut out to the exact shape of the lifts. This was printed out and mounted on a stiff file folder. The profile view provided the thickness of the lifts. Below the waterline they are almost exactly 1/8", while above it they are double that thickness.
As with most of my model hulls, I like to find a convenient horizontal level to use as a reference plane. The hull below the line and above the line are shaped and treated as separate components until quite late in the build. This allows me to lay each piece flat on a work board for ease in shaping it, or on the platen of a drill press to make precise holes or to do any milling that can be done.
The stiffened plan was cut out in sequentially larger lifts. Each was transferred to basswood of the appropriate thickness, and a centerline drawn on. A perpendicular was drawn at station number 6 so each lift could be registered against its neighbors in both dimensions. These were glued, one at a time, to make a stack up from the bottom of the hull to the separation plane, and down from the deck. When everything was secure the shaping began with a small block plane.
