cafmodel
Everything posted by cafmodel
  1. Do you need this? I can make some out of pear wood
  2. Yes, it is the same as the boat in the plan. It should be a general-purpose boat, and many ships will use it
  3. https://www.cafmodel.com/products/la-salamandre-cutter-full-rib-life-boat-scale-1-48-5quot-wooden-ship-model-kit-1 https://cafmodel.com/products/la-salamandre-full-rib-life-boat
  4. Yes, this boat can be used in Le coureur. Of course, we also gave you a regular boat The difference between them is the hull
  5. This kind of model has existed for a long time, but it was made of plaster at that time. Now 3D printing technology can make the mold more accurate
  6. https://cafmodel.com/products/la-salamandre-full-rib-life-boat You can choose this boat. Its hull is also in the shape of tiles Now the price is 23$ He needs to be very careful when making. He can't use liquid quick drying glue, which can easily bond the hull and the resin mold inside We can use latex or jelly like glue。 We have improved the resin mold, now we use a whole, so its accuracy is better than the original use of splitt
  7. Thank you very much, chuck, Jim Thank you very much for your attention to le coureur and everyone here, It has been 11 months since I started to make Le coureur in September last year. In these 11 months, we have transformed these plans into three-dimensional models and three-dimensional models into wooden kit. This is really a very interesting work。Although the process is full of difficulties and challenges, this is the charm of the model. When we made HMS fly before, we found that the machine precision of ordinary CNC was not enough, and the influence on machining accuracy was relatively small when engraving on one side, but the error would be doubled when engraving on both sides. In coureur, there are similar parts processed on both sides, so we have purchased CNC of industrial mold to ensure the accuracy of processing parts Next, we will be working on the new kit, which will be a bigger challenge Tom
  8. Waiting for the foundry to deliver to me,Hope to receive it as soon as possible
  9. I've been working overtime these days. I hope it can be finished as soon as possible
  10. Yes, I learned oil painting and Chinese brush painting in middle school, But I haven't touched my brush for 20 years.
  11. The first draft still needs to be adjusted
  12. Hello, I haven't cut my left rib yet, I'm thinking about whether I need to cut these ribs Because his ribs are quite different from salamandre's Salamandre's ribs are only 2 mm apart, so you can't see the structure clearly without cutting the ribs,But the distance between the ribs of Le coureur is big enough to see the internal structure. Of course, if you want to see the inside more clearly, you need to cut the ribs。 The other thing is how different these jagged ribs are, and I want to keep them more Of course, all of this depends on what kind of effect you need to express
  13. Hello ,I have bought some boxwood, but the wood is still wet and can't be cut。I think it needs to be kept until the end of this year。 I'm also looking for dry boxwood。
  14. Yes, the next Granado, I'll try to separate it up and down so that the structure inside will be fully displayed, And the top and bottom can be closed or separated, This is a little difficult. I hope I can succeed https://modelshipworld.com/topic/25172-caf-granado-by-cafmodel-148/?tab=comments#comment-737258
  15. Yes, there is such a fixture in kit , Only in this way can the designed model be installed accurately
  16. Yes, he contains everything you said
  17. Thank you very much. The kit will include rigging, Or our next kit will meet your requirements, La renommee and HMS fly Of course, renommee is still waiting for authorization from Ancre
  18. www.cafmodel.com Welcome to our company
