HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
TIPP
Everything posted by TIPP
  1. Hi Shipman When launched, Cutty Sark had only one deckhouse. John Willis' original specification for the construction includes: 1.Deck House. To be iron framed and plated with Teak and panelled. Galley to be fitted at after end and to be properly lined in wake of cooking range with sheet iron. Floor to be neatly tiled with coloured tiles. Funnel to be of galvanised iron. Fore end of house to be fitted for Carpenter, Sailmaker, Boatswain, Apprentice, etc. and of a size as may be required. When used as accommodation for up to 8 apprentices, this deckhouse was known as the HALFDECK. For the maiden voyage of 1870 all the ABs were housed in the fo'c'sl head, on the level of the 'tween deck, accessed only by a single companionway leading down from the weather deck immediately abaft the anchor windlass. This arrangement was soon deemed impractical because it took the men too long to get up on deck when needed in a hurry. The result was the addition of a second deckhouse for the crew and their former space was given over to storage space. Their 'luxurious' new deckhouse continued to be referred to as 'the fo'c'sl' and the watch off duty were always 'the watch below'.
  2. Sorry to respond so late to your post (#161) but I was just browsing and saw your question about the rails on the bow of Cutty Sark. These rails were removed from Cutty Sark when her new figurehead was fitted recently giving an opportunity to photograph them. The rails are variously known as Middle Rail or Third Rail. They are made of teak and elliptical in cross-section, measuring 2½ inches top to bottom, 2 inches thick and 20 feet long. They are slightly convex to fit the shape of the bow. The leading end is tapered and the after end is rounded. Although they are undoubtedly decorative, they would certainly have had a practical function and here opinions differ. My best guess is that this rail was there to protect the guilded scrollwork and name on the trailboards from being ‘snagged’ and damaged by lines leading over the bow. These could include headline mooring ropes, anchor cables (particularly when the anchor was ‘catted’ with the cable still attached), the fore tack and the sheet from a Jamie Green sail, carried under the bowsprit. I would welcome any more knowledgeable explanation of their purpose. Best wishes for your project.
  3. Cutty Sark’s Spencer sail According to Captain Woodget, who was interviewed by Basil Lubbock during the writing of his book “Log of Cutty Sark”, the Spencer was never much used by him. An exception was when the ship was running dead before a heavy following sea, with the headsails only drawing when she rolled or yawed, the Spencer was sometimes set to ease the ship with the spanker brailed in. It was generally kept bent and furled against its jackstay on the after side of the lower main mast. The sail is set with an outhaul that runs through a block near the end of the spencer gaff, back to the main mast above the gaff, alongside the chain gaff lift, to a block, thence down to belay on its pin on the mast band. The inhaul runs under the gaff and also back to the mast and down to its pin on the mast band. The photograph shows the outhaul and inhaul shackled together beneath the gaff. The gaff is controlled by vangs which belay to the bulwark pin rails on either side, beneath the boat skids. The block and halyard at the peak of the gaff is a signal hoist, not related to the sail.
  4. The clew garnets for all three coarses run from spectacle clew irons shackled to the clews of the sails, directly up to the coarse yard. For most of her time in clipper rig, the coarses were 'clewed to quarters' meaning the clew of the sail was hoisted diagonally inboard towards the mast. There were a few occasions when the coarses were clewed vertically up to the yardarms, but this was not normal practice. The coarse clew lines lead through blocks on the coarse yard and then down the fore side of the lower mast to be belayed on pins (port & starboard) on the foreward fife rail at the foot of the foremast. So, there is no fairlead shown on the diagram for the coarse clew because no fairlead was used.
  5. The original arrangement of the foc'sle was altered after the ship left Falmouth in 1936, most likely when she was refurbished as a visitor attraction in Greenwich in 1954. The single central companionway to the anchor deck was removed and replaced with twin companionways, one either side of the central windlass, thereby making visitor circulation easier. In the process the curved pin rails at the break of the foc'sle, described by Longridge, were removed. Today, the three headsail sheets belay to the three pins on the pin rails abaft the heads on either side (see my pics attached). The fore topmast staysail sheet occupies the foremost pin and the flying jib sheet, the aftermost pin (This follows standard practice that the highest sail - or in this case, the furthest outboard - takes the aftermost pin in a set.)
  6. Here is a picture of Cutty Sark at the time of the Festival of Britain (1951). There is reference to the ship in the Official Guidebook, but I can find no picture of her as an exhibit. The idea was to 'test the water' to see if there was enough interest to justify raising the money for a permanent home for her. (There was !!).
  7. USS Frolick :  Would you please share your understanding of a  "topgallant fo'c'sl" deck
    Is this simply a fo'c'sl that is ABOVE the main pin rail?   Where is it in relation to a clipper with a topgallant rail above the main pin rail?
    1. uss frolick
      uss frolick
      A "top gallant forecastle" deck (as described and spelled in contemporary communications) is simply a short deck before the fore mast, usually seen on flush decked sloops-of war, that are relatively flush with the cap rail. They assist the sailors in working the anchors and foremost rigging, and in some cases it is a platform for mounting a small carronade, normally used in a boat during cutting out expeditions. Think of it as a poop deck for the bow. Here is one on a Cruiser Class brig:
      49839610482_6a103992ee_b.jpg0 by Stephen Duffy, on Flickr
      Hope this helps.
  8. rwiederrich
    Would you be kind enough to let me have your email address please ?
    graemetipp@aol.com
