Rick310
NRG Member-
Everything posted by Rick310
I’ve been continuing to work on the extension of the main rail over the forecastle. The edge plank over the aft end of the forecastle fairs into the main rail and is joined with a fitted knee. The edge plank also has 2 pin rails for the head sail sheets. This is a prominent feature and I wanted to get it right. Initially made the main rail out of basswood but found it unsuitable for joinery work so I switched to boxwood for both the main rail and the edge plank. This is very fiddly work. I am constantly amazed at EDT’s joinery work and how difficult it is to do well. Thank God for Bondo. I found it easier to fit the knee to the edge plank and then the combination to the main rail. I will fill in all the gaps when it is cemented in place. Right now I am waiting to get new paint that I ordered from Model Expo. Both the main rail and the edge plank will be painted pearl gray with the deck beam painted white.
- 351 replies
- Flying Fish
- Model Shipways
No doubt, I just went back and re-read the McLean article. A lot of good info there. It’s been awhile since I read it and each time I do, something else jumps out to me ie, the fancy knees.
- 602 replies
- Flying Fish
- Model Shipways
Glad to help. Lord knows I need all the help I can get! Rick
- 602 replies
- Flying Fish
- Model Shipways
George, I’m not sure but I think the sizes given are the circumference and not the diameter. I need to check the plans when I get home. I think on plan 4? There is a conversion table Rick
- 602 replies
- Flying Fish
- Model Shipways
ClipperFAn, Thank you for your very generous praise. When I compare my model to true artists like EdT, KeithAug and Rob, just to mention a few, they are at a whole different level. They have set the bar that the rest of us strive for. The first picture of the forecastle is the clipper Snow Squall at the Maine Maritime Museum in Bath, Me. I have about a hundred pictures of her, most on film, but I don’t know if there are any on their website. What could be of great interest to Rob is that the model has a full set of furled sails. I will post a few, but can do more if interested.
- 351 replies
- Flying Fish
- Model Shipways
I made the anchor windlass pump break(?) from brass round and rectangular tube. The round tube was filed square for the arms and the rectangular tube was cut and drilled for the pivot. The links were made from brass eye bolts supplied with the kit. The 2 handles were made and soldered from brass rod and boxwood. Again, I had much trouble reducing the diameter of the boxwood using a draw plate. I would like to have gotten them thinner but this was the best I could do. The brass was blackened and the boxwood stained with Minwax Ipswich pine.
- 351 replies
- Flying Fish
- Model Shipways
Really well done! I especially like the way the masts and tops came out. Great technique, something I’m looking forward to and somewhat dreading.
- 602 replies
- Flying Fish
- Model Shipways
Absolutely amazing Rob, your furled sails are top notch!!
- 3,560 replies
- clipper
- hull model
Next up was the anchor windlass. I didn’t like the one supplied with the model, so I purchased one from Bluejacket. After cleaning it up, I blackened the pewter and painted the barrels white. I made the whelps from copper wire, blackened them and cemented them on with super glue. What a mess!! I also made the travelers(?) for the windlass, the forecastle deck beams and the beam knees. I made the pawl from copper strips, blackened it and super glued it to the Samson post although it’s hard to see. am copying the windlass color scheme of the beautiful models of the clippers Snow Squall at the Maine Maritime Museum and Challenge, at the Smithsonian Museum of American History.
- 351 replies
- Flying Fish
- Model Shipways
Looking really good. Nice job on the copper and the planking. Really like the contrast between the copper and the he black hull.
- 60 replies
- Flying Fish
- Model Shipways
After what seemed like a long time, appropriate 1 year, it was time to move onto the forecastle. I was glad to be done with the metal work although I found that I really enjoyed soldering. The first thing I did was to cut and shape the carrick bits, Samson post, knees and the mooring bits. I then proceeded to make the pump brake (?) for the anchor windlass. By this time I bit the bullet and purchased a Sherline lathe and milling machine. I have absolutely no experience with either but seeing what EdT and KeithAug and Rob do, I hope to learn how to use them. First up was making the bells and whelping drums. Made these by soldering telescoping brass tube and rod, then mounting them in the lathe and turning them with files which worked pretty good . The bell gallows frame I made according to EdT, out of rectangular brass tube that I drilled on the milling machine, mounted in a vice and filled to shape. This bells mounts on the binnacle at the stern and the Samson post on the forecastle. The frame took 4 try’s to get one right. The cap for the bell I turned with the parting tool. It came out well by accident.
- 351 replies
- Flying Fish
- Model Shipways
Determining the number and size of the deadeyes took some time as I decided to use 4 different sizes. This proved to be nearly impossible as I had to purchase the deadeyes and the sizes were not consistent as advertised. The largest were 16 in. (Real) which equals 4 mm (scale). The actual sizes ranged from 3.8 to 4.2 mm. I purchased them through Model Expo and I was very pleased with the quality of the deadeyes, even if there were variations in the size. I ordered them during the pandemic and bought both boxwood and walnut deadeyes, depending on what was available. The nicest deadeyes where the Falconet deadeyes but only the 3.5 mm ones where available. Model Expo now has the 2.5 mm ones. I ended up using only 4 different sizes for both the fore and main masts, and 3 for the mizzenmast mast. These were stained with a walnut stain from Minwax with variable results as boxwood doesn’t take stain well. This is especially apparent on the 3 smallest deadeyes which are boxwood. Rings were made of 24 ga. copper wire as the 28 ga. was too small. These were wrapped around an appropriate sized drill bit and pinched at the ends to flatten them along with the end of the chain plates. They were then cleaned with acetone and soldered with a butane torch and copper phosphorus solder per EdT. I am pleased with the results although they don’t compare to EdT’s Y A. several had to be redone as they either sat too high or low on the channel. The next challenge was to make all 62 of the backing links. I made mine 6/32 long with holes at both ends. Again, consistency was the challenge. I actually enjoyed making the chain plates and backing links one I got comfortable with the technique. The backing links were by far the hardest to make and so probably made over 100 to get 62 that were fairly consistent. All these were chemically blackened with a solution from Bluejacket. These were pinned to the hull again for a final check, removed and the deadeyes snapped in the rings. I thought the chain plates looked too wide on the last 3 smallest deadeyes so I reducrd the widths of the chains to 1/32 wide, which looks more appropriate. These were pinned to the hull with bolts made of straight pins and the molding strip glued in place. By this time the hull was looking pretty dinged up so I filled in the dings, sanded and repainted it.
- 351 replies
- Flying Fish
- Model Shipways
I was finally faced with the fact that I could no longer avoid working on the channels, chain plates and deadeyes. I have been dreading this moment ever since I first saw the plans for FF. I literally had decades to consider how to make the chain plates and no idea how to go about it with a reasonable expectation that I could do this. The recommended technique described in the plans looked difficult to make and be consistent especially since I had little to no experience with soldering. Fortunately and timely, EdT published the 2nd of his 3 volume series on building the Young America. These books have been an absolute Godsend not only for making the chain plates but all aspects of modeling a clipper ship. His wonderful description of how he tackled this issue and his clear photos and concise method convinced me to try it myself. First, was making, fitting and marking the channels which was fairly straight forward given the hull’s asymmetry. I made the 3 brackets for each of the lower channels out of brass that I cut with a paper cutter. I had previously made bands for the bowsprit and struggled to get consistent widths cutting the brass sheet this way. Making the brackets was a preview of making the chain plates and I was very concerned with consistency given to that there are 62 of them. EdT used copper which I had not used before. So, with some trepidation, I purchased some .02 copper sheets and 24 and 26 ga. copper wire. I cut the copper sheets on the Byrnes table saw with poor results until I remembered reading that some one suggested sandwiching the sheet between 2 layers of 1/16 basswood sheets, This works like a charm. I had the opportunity to purchase 1/16 wide brass strips from Bluejacket but it just looked too wide and out of scale. I made mine 3/64 wide. The next challenge was to drill holes in the end of the chain plate, given that I did not have a drill press and would have to do it by hand. I started by using a center punch and a #75 drill bit held in pin vice. With some practice, this worked fine, later to be enlarged to a #71 drill bit. The chains were bent and pinned to the hull. I had measured the hull were the chains would be bolted and placed painters tape on the hull to locate that position and insure all chains terminated at the same level.
- 351 replies
- Flying Fish
- Model Shipways
Wonderful painting and I really like your sketches of the stern board, stem and figureheads. Your talent is amazing and I believe, very accurate.
- 351 replies
- Flying Fish
- Model Shipways
WOW Rob. Incredible!!! Really like the furled sails!!
- 3,560 replies
- clipper
- hull model
Thanks again ClipperFan for your kind words. I think that if I continued to remake the arch, I might be able to come up with something better but I didn’t want to get bogged down and it probably wouldn’t be that much better.
- 351 replies
- Flying Fish
- Model Shipways
Looks really nice!! Looking forward to starting the POB version when I get the solid hull version done.
- 60 replies
- Flying Fish
- Model Shipways
Rob, the scale of the Flying Cloud model is 1:48, or a 1/4 inches =1 foot
- 351 replies
- Flying Fish
- Model Shipways
Before I moved on to the channels,chain plates and deadeyes, I attempted to come up with a solution to making the stern carving. This, of course was to avoid attempting to making the chain plates and straps for the deadeyes which terrified me. The stern board was described by McLean as a beautiful arch but no other details. The Buttersworth’s painting shows a small portion of the end of the arch but all else is speculation. I originally thought I would attempt to bend very small strips of wood but my utter failure in producing those strips was discouraging to say the least. I had no success with a draw plate reducing the strips to approximately 1/32 diameter, which I thought was the maximum size I could use without it being too bulky. There must be a secret to using a draw plate that I just haven’t found. That, combined with the trouble I had bending wood strips made me think that this was going to be very difficult and not practical. I considered having a decal made, but that would look flat and besides, what design? I would probably try to duplicate what is shown on the plans and I decided to go that route as a last resort. About that time, while reading KeithAug’s amazing blog on the schooner Germania, he described using brass wire to model some ship’s carving at the bow of the model, which was beautifully done (as everything else on the model). I decided to try this using 24 and 28 ga. Brass wire. I made no attempt to duplicate the plans, aiming to produce a stern arch that looked decorative. After several attempts , this is what I came up with. I intend to use decals for the name and port.
- 351 replies
- Flying Fish
- Model Shipways
Rob, ClipperFan. What a beautiful painting of Glory by Samuel Walters. Walters, as you may well know, was considered the pre-eminent Liverpool artist back in the 1800’s. I have additional pictures of the Flying Cloud at the Boston Museum of art which clearly shows the belaying pins for the mizzenmast in the taffrail rail. I just can’t discern accurately the spacing in way of the shrouds. These pictures are available on line plus I took my own photos. I believe that this model was donated to the museum in 1929 and was built by H E Boucher in 1915, who I think was a professional model maker. It was overseen by Capt. Arthur H. Clark, who captained clipper ships and wrote the book The Clipper Ship Era with nice things to say about the FF. One interesting detail of this model is that the inside edge of the plank sheer has a double bead molding, as does the outside edge. This is also seen in photos of the Benjamin. Packard. I choose to model this molding, although it is not supported by the plans or Carothers American Built Clipper Ship. Rob, I certainly don’t disagree with your decision to mount the pin rail to the shrouds. Going by the Walters painting, it looks like the closed bulwark would be to low for the pin rail.
- 351 replies
- Flying Fish
- Model Shipways
ClipperFan, I’ll do my best, probably next week as I have to go out of town. Rob, nobody can criticize your decision as no knows for certain. I have doubts about my own solution although I believe it’s reasonable. To add to my uncertainty is the beautiful model of the Flying Cloud 1:48 scale at the Boston Museum of Art. I took pictures but was unable to discern the mizzen pin rail. It appears that there is one pin between stanchions fore and aft of the shrouds and 2 pins between stanchions in the way of the mizzen shrouds. Can’t tell if the rail is expanded and there are more pins. If not, then there are still not enough pins and this model has full sails.
- 351 replies
- Flying Fish
- Model Shipways
Clipper Fan, Thanks again for your input and suggestions. Really appreciated. When I saw the China painting, I was at the preview of the auction and the room was pretty cramped and dark. That is why I was unable to get a full picture of FF. I believe the colors are fairly accurate given how good the photos for the catalog were.
- 351 replies
- Flying Fish
- Model Shipways
ClipperFan, Once again thank you for your input. The curved end of the taffrail could certainly be brass although it appears to be wood on the Chinese painting, something I have wondered about. What is concerning is that the rail on the aft cabin roof is poorly depicted-wood or brass. I agree with you that it is probably brass although the end of the rail is awkward and doesn’t look right. I prefer the depiction by Buttersworth and intend to model it out of brass as painted by Buttersworth. Interestingly, curved metal rails At the fore end of a wood rail as shown on the Glory photo is frequently seen in photos and paintings of some of the large 4, 5, 6, masted schooners built in the late 1800s and early 1900s. Rob, I completely agree with you about the mizzenmast pin rails. What I modeled on FF, was seen on ships built many years later. Was this a new innovation or one that persisted from earlier times? I think your solution is every bit as plausible as mine. I just don’t know and I still don’t know if there are any other alternative that make sense. It is so frustrating to have photos or paintings that don’t quite show the detail you are looking for. What ever you decide, your model of Glory sets a standard other models will be compare too.
- 351 replies
- Flying Fish
- Model Shipways
