Zooker
  1. Thanks, John. I'm still looking around for that small drill that BTW is manually operated!
  2. Well, it's been a few years since I've attempted any restoration on this due to unforeseen events, but I want to give this another go. I want to begin by attaching the bow sprit that broke free from the hull; I tried using Testor's fast-drying glue for wooden models, but it's not drying fast enough. I think the best thing to do is insert a pin in the sprit and then insert the other end into the hull. According to the plans, a hole was first drilled in the hull and then the 3/16 dowel was inserted into the hull. Years ago I had a very small drill bit for models, but I apparently have lost it during several moves. Anyway, any suggestions re: attaching this piece would be appreciated. FYI: The kit (#1079) is from Marine Model Co. N.Y. Thanks!
  3. I've done some reading and was lucky enough to get a copy of the original plans for this model; I hope to soon attempt small steps in restoring it to at least a more presentable condition. What I need to do is find a way to reproduce the short railing on the stern.
  4. I live in rural Wisconsin and the clubs tend to be several hours away.
  5. I've been doing a lot of reading given that I am by no means an experienced modeler. I need to make some templates for the Sea Witch (Since my last posting, I was fortunate enough to get the original plans for this model. (Marine Model Kit #1079) So...how do I create templates for the bow sprit cap, dolphin striker, horns, as well as the transom rail, etc? Thank you.
  6. Bill: Sorry I missed this post about a template for this railing. I'd love to have it. Thank you.
  7. Well, I got lucky recently when another modeler visited this site and saw my interest in obtaining the blueprints for this particular Sea Witch model. He had just completed building his after umpteen years of having the kit. It's the Marine Model #1079 that was first drawn in 1937. He had no more use for the blueprints so he gave them to me! Now my question is: Where do I start? I'd say 90 percent of the rigging is still in place; the problem is that parts of the masts and spars have come unglued so it's just a matter of putting them back together. The bow sprit is in pretty bad shape; the top mast stay is missing and I'd like to know how one would go about reproducing it. I can send photos of the bow sprit if folks here think it would be helpful. Again, let me emphasize that I've never built a ship model of this complexity. I just want to get as close as I can to restoring what my uncle did with so much devotion in 1956. Thank you.
  8. It's been a while since I posted this item, and I've done very little except for cleaning up this model where possible because I was hoping to learn which company made this kit in order to find the original blueprints that would help me (a total novice) to attempt restoration. Well, a couple weeks ago someone on the West Coast (who is not a member) decided to browse this site and saw the photos of my uncle's model. He emailed me directly and said it looked very similar to the model he just completed and sent photos of his. Close, I thought, but not quite that of my uncle's. He admitted not following the drawings to the letter, adding that I could have his blueprints; they arrived yesterday. They were from the Marine Model Co. in N.Y and were drawn in 1937 and revised in 1958; my uncle completed his in 1956. What I noticed on the drawings was that the brow sprit comprised two pieces of wood, as is the case with mine. The other fellow's has only the longer piece, and the colors he used do not match those on my uncle's. I felt sure that these drawings were of little use to me, but then I came across a small set of instructions among the blueprints and discovered that the paint colors on my model match exactly those used my uncle. Voila! My search has ended, thanks to somebody who just decided to "drop in" for a visit to this site. My wife said it best: There are a lot of nice people in this world!
  9. Well, I think I'd need more than a few lemon slices. The solution for me, however, is to just spit into a small plastic cup and keep dipping the swabs into it. But you guys are right: It works!
  10. There are some areas on the deck that are pretty cruddy due to years of gathering dust. I have Q-tips on long sticks like those used in medicine and I'm wondering what -if anything - I should use to dampen them that would aid in the cleaning? Water? Alcohol? Thanks.
  11. Is anyone familiar with this book? Also, are there special tools for rigging? Thanks!
  12. OK, so how do I start a build log and move all this stuff that has been written thus far? Also, Jim Lad earlier recommended that I get a copy of Harold Underhill's "Masting and Rigging: The Clipper Ship And Ocean Carrier" This would cover the rigging of the actual ship and not a model, correct?
  13. Louie: Are you suggesting that it might be best to remove all the rigging and then start from scratch after all else is repaired/replaced?
