Alexander Bulimov
Posts posted by Alexander Bulimov
The instructions suggested some ridiculously simplified scheme of attaching rudder, so I had to scratch build some better version with brass strip and nails I had left from previous builds.
I contemplated few options to display the model - with or without the sails, or even scratch building section of a ship’s hull with davits. Ultimately because the model is so simplistic and provided sails being of average quality I settled on displaying the boat with sail furled around the mast.
I consider the build being pretty much finished now. I just need to improvise some sort of a base for the boat, because the kit surprisingly has none.
Overall I’m reasonably happy with the result, although I surely should have chosen a better kit to start with. Probably that one made by Model Shipways. This one by AL is very simplistic, and poor design and material quality doesn’t provide much room for improvements.
Hi everyone, this is my first build log here on MSW, and 5th wooden ship model.
With this kit I wanted to get a break from rigging HMS Terror I've been building for over a year now (build log pending, I'm not very good with keeping logs).
I'm rather disappointed with this kit, and hopefully the build log will show why.
The build process looks straightforward from the first glance at the instructions, but as I was progressing it was more and more obvious that there are lots of very unclear moments that instructions don't show. And what really baffles me - there are no plans of the boat included, you have to kinda guess part placement and some dimensions based on few small photos.
Here you can see bow and stern reinforcement plates being mistakenly glued lower than they should be, because instructions give misleading information on doing this. I had to remove them and glue flush to the top of main keel piece.
Next thing that really surprised me was the amount of material that needs to be sanded off the keel prior to planking (about 1cm). It's a very strange design decision, and instructions don't really explain it, you have to figure it out from pictures.
Planking (arguably the most important step when building a clinker-built boat) is barely explained, luckily this being my fifth model I had no issues with it. Calculated and marked all plank sizes, glued with thick CA glue.
Reasonably happy with the result, didn't bother much with getting it perfect because all of it will be pained white as per instructions.
On next photo you can spot a strange horizontal plank on the bow bulkhead. It's made from 0.6mm scrap piece from HMS Terror build and is covering the ugly end of the plywood keel that would be otherwise visible on a finished model.
Installed the benches, and this step really showed the problems with the kit. You see, with all those elements (bulkheads, benches) being laser-cut, one would expect them to fit reasonably well. But no, not even close. Benches are too long for bulkheads they should pair with, and pre-cut slots that bulkheads should fit in are different sizes on each side of the banks. It's just hilariously bad. Not a big deal for me, but for a kit that is positioned as a beginner-friendly it's unacceptable.
Especially given how easy is to adjust source files for laser cutting (it's not like it's ejection molding and you have to make new forms), there is no excuse for such quality issues.
On a positive side, I loved the use of cherry for the benches and other details, beautiful colour. Although the wood quality for cherry parts is all over the place.
- Keithbrad80 and ccoyle
- 2
Depths markers look great! How did you make them?
New Book on HMS Terror by Matthew Betts
in Book, Monograph and Magazine reviews and Downloads. Questions and Discussions for Books and Pubs
Just so you know this book is available here in Europe since this summer, published by Seaforth publishing. I received it in August, and can confidently say that it is rather good. Plans and technical details are indispensable when building HMS Terror by Occre (which book mentions), and allowed me to re-do side davits correctly on my model.
There are also few remarkable build logs here that used the book to enhance the model, like those ones:
