Daniel Filipe
Everything posted by Daniel Filipe
  1. Thanks 🙏🏻 Today was trying to fit this in a possible way.
  2. I was thinking, in that time, while doing the final planking of the model, I can control the size of the hatches with the wood strips. 🧐
  3. Good evening, I need your advise about this. So i’m planning to leave some hatches closed, the small F32 pieces are meant to be the hatches. They have a very small gap inside the square. Is that ok?
  4. Sim 😄 Ainda não tapei os espaços que se vêm nas fotos. Estou quase lá.. vai devagarinho 👍🏻👍🏻
  5. Good evening, today just sanded the B7 strips and placed the B13 in position. Not fully glued because i wanted to match the piece with the skeleton of the ship. Doing this, I have now some holes on the inside. I made everything according with the instructions.. But it’s fine, I will use my leftovers to close the holes.
  6. Well, did very little this week. I will start to plank these areas. Some weeks ago, i ordered some cannons just for curiosity. They are beautiful. I’m not sure if I’m going to use the small ones as the model suggests. (on the upper decks) In real life, it would be impossible to reload them, etc. The Model Shipyard golden hind doesn’t have the upper deck cannons. Anyway, some pictures below
  7. Good evening. Placed the pieces together to check any anomalies. Will have to sand on the stern to fit smoothly. Nothing to worry about.
  8. Obrigado @Jorge_Goncalves Felizmente já me sinto mais à vontade para enfrentar cada passo. O que interessa é fazer e aprender 👍🏻 Newest update:
  9. Doing some work before gluing anything. Reduced the strips from 5 to 4mm. Now I like it. Having space for a 10th wood strip instead of 9. 🥳
  10. The width of the strips. Photo from another build. For me, the width of the strips should be smaller. They have 5mm i think.
  11. Good evening, Before starting planking the deck, i need some advices about the size of the wood strips. I think they are too big comparing with the scale. What would you do in this type of situation? Just a photo from the replica of the Golden Hind
  12. @Backer Only those two at the front. More reinforcements today.
  13. I must leave 4mm for the keel. On the Polaris i sanded to much and now I want to prevent that 😅
  14. Thanks @BobG Glued the frames and started sanding the two small supports at the bow. It will be more easy when planking the strips.
  15. Good evening everyone, started today. very happy because the false keel is not warped. It’s a good start for me 😅 (not glued yet)
