HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 66 donations so far out of 49,000 members - Can we at least get100? C'mon guys!) ×
Organ tech
Everything posted by Organ tech
  1. It isn’t shone in the plans or provided for in the parts. It would be easy to add and I may.
  2. I have glued the deck structure- pilot house in place. The chains, supplied, for staying the funnel are too large to scale so I used the supplied thread, which is too large to scale for any of the rigging. I failed to get the curve on the bottom to conform to the deck. I also added the port side pin rail, not in the plans, as I am adding one or more sails to the formast to hide the out of scale rigging there. I wish I had bought finer thread. The running rigging thread looks better.
  3. Rope loops on belaying pins. I formed them around a 16 penny mail, add glue to the side of the fife rail, then drape them over the pin with pointed tongs.
  4. I did get the direction right, just didn’t secure it to the eye right☹️
  5. My main mast is glued in. The gaff lift is belayed and the boom sheet secured. I am disappointed that the deck block is askew, but will leave it and press on.
  6. The stern area is ready for the main mast. I have the boom sheet block secured to the deck, with an eye, ready for the line that I will thread 1st, before glueing the mast.
  7. Belaying all of the lifts-halyards. I hang a clothes pin on the line to make it just taught, but not bending the mast, then add a drop of clear glue. I will simulate the rope wrap- arounds on the pins, later, with extra thread.
  8. If I made a lot of ship models I would get a watch makers lathe and turn them from wire. I bought extra blocks from a firm in Australia. I think they have pins too🙂
  9. Thanks for the compliment! It is a stock item that came wit the kit.
  10. I work with very small parts on top of a piece of 600 grit black sandpaper. This reduces bouncing and rolling and makes small things easier to see.
  11. I also added my figure head. Here, I made the mistake of gluing in the bowsprit first, not leaving enough room to fit the correctly fashioned figurehead assembly. I went ahead and installed it wrong. I might correct, as I see a way to re-do it.
  12. I assembled and installed the foremast fife rail. One piece is missing so I used wood. Too bad I spilt the deck under the rail when installing! In this small model, I only noticed it in the photo. I tensioned and belayed the port topgallant halyard to it, after gluing in the foremast at a little too much rake :-(.
  13. I am drilling the holes in the fife rails for the belaying pins - a modified sewing pin works well as a drill for the Britannia metal. The plan shows the foremast fife rail 180 degrees oriented to how I would expect it ( see my photo of the top plan view). I want the haulyards to belay behind the yards so I will place them accordingly. I am not sure why the main mast has a fife rail, but will ask that in the right forum.
  14. The masts are still not glued. I increased the rake. The plans show more rake for the main mast, when it seems the square rigged formast would need as much or more(?)
  15. Good point They are a little. The main mast needs to be a little more. The masts are not glued in yet.
  16. I am redoing my forward companionway and a couple of other deck structures. I can do better. My ship with the deck house in place, not affixed yet, just a photo op.the windows on the pilot house don’t cut it either. I will re-do them.
  17. Ship posing with its main mast and both paddle wheel assemblies in place. Before I glue in the masts, I will add the fife rails, debating whether to use the Britannia metal parts supplied, or to fabricate from wood. I am not sure why the aft rigged main mast has one. Maybe included in the original builders plans in case an owner wanted to square rig this mast(?).
  18. One paddle wheel assembly glued in. I simplified this by making “dummy” helper sponsons that hide behind the paddle wheels, giving extra support.
  19. Sponson supports are steel wire. I am carefully shaping them so the wheel assemblies sit plumb in their openings, trimming and bending with pliers.
