rob444b
NRG Member-
About rob444b
Double Capstan Project by shauer - Portland Scale Ship Co Kit
shauer reacted to a post in a topic:
Bomber_County reacted to a post in a topic:
Light duty compact power sander, drill, shaper
bruce d reacted to a post in a topic:
I have been using a "nail drill" I found on Amazon for light duty work and drilling. They are amazing inexpensive (my corded one was $12) and very compact. It has replaced my Dremel for most work It takes a 2/32" shaft so it will NOT work with Dremel accessories. You can buy different grit sanding drums replacements for a few pennies apiece. The advantage is that it is so lightweight and fits well in my hand. It runs at high speed that can be adjusted but does not have too much torque. However for drilling soft wood and sanding it is fine. The Dremel was just too bulky and I was afraid of it crashing into delicate parts. Drill sets made by Arrowmax fit perfectly. I will put down some links below. https://www.amazon.com/COSLUS-Electric-Nail-Drill-Professional/dp/B0DBKQVJHB?pd_rd_w=1M5wm&content-id=amzn1.sym.784113d6-3054-4922-a575-af4720478411&pf_rd_p=784113d6-3054-4922-a575-af4720478411&pf_rd_r=SEF3VZSW9Y2XEN41GG7Y&pd_rd_wg=R2ayK&pd_rd_r=bc4e8325-83aa-44cf-bf42-334b221d64c7&pd_rd_i=B0DBKQVJHB&ref_=pd_bap_d_grid_rp_0_3_t&th=1 https://www.amazon.com/AM-ARROWMAX-0-5mm-2-3mm-Titanium-Drilling/dp/B0D9W89Q4Z?pd_rd_w=cMI2I&content-id=amzn1.sym.784113d6-3054-4922-a575-af4720478411&pf_rd_p=784113d6-3054-4922-a575-af4720478411&pf_rd_r=0WCHT1R72YFC9WGGPJ20&pd_rd_wg=TwQPA&pd_rd_r=4a9917b2-8604-498e-95a4-ad6dc1fef0f2&pd_rd_i=B0D9W89Q4Z&ref_=pd_bap_d_grid_rp_0_1_ec_pd_hp_d_atf_rp_1_t&th=1 Rob
rob444b started following Maine Peapod kit , Ships in Scale Magazine Sails Again! , Norwegian Sailing Pram by MBerg - FINISHED - Model Shipways - 1:12 and 2 others
Norwegian Sailing Pram by Desertanimal - Model Shipways - Scale 1:12
Mark Pearse reacted to a post in a topic:
SiriusVoyager reacted to a post in a topic:
rob444b reacted to a post in a topic:
I rounded the edges of the planks on my pram, but I think either way looks good. It is more personal preference. If you want a brass skeg on the bottom, I would use a thin brass strip and attach it after you paint. I would use CA to attach it in place. Your pram looks amazing so far. I also had the transom knee hanging in space, don't feel alone! Rob
For Beginners -- A Cautionary Tale
Beginner looking for advice on first kit
rob444b replied to O-Nurse's topic in New member Introductions
I am fairly new to this also and started with the Model expo ship shipwright series. A series of 3 boats each a little more complex. They can be bought as a set or individually, They have a plan if you build the first (Grand Banks Dory) and send them a picture of it you will get full credit for your next build. I had a lot of fun with these kits and I think you learn a lot going from one to the other. https://modelexpo-online.com/Model-Shipways-Shipwright-3-Kit-Combo-Series_p_5465.html Rob -
This is a great way to start learning how to build wooden ships. If you need I can scan the manual and send it to you as a PDF Rob
"When it came time to fit the thwarts I needed to deepen the slots for the frames. My #16 blade was really helpful here. I guess my dory was a little thinner than most?" I had the exact same problem. I think when you plank and glue under tension, the planks tend to push the hull inward. Which is the reason they wanted you to keep the hull on the frame after it we separated, I believe. I just kind of forced my thwarts in place, to help keep things from contracting. Your dory looks amazing!
- 30 replies
- Grand Banks Dory
- first build
Grand Banks Dory by Desertanimal - FINISHED - Model Shipways - 1:24 - first build
You are looking great. A suggestion, use several coats of sanding sealer before painting. The acrylic pain tends to raise the grain on the wood. Also the idea is not new to me but you can modify the binder clips you use as clamps by using the handles to make a base using either the loop end or the other end as the picture I added shows. They are really handy!
- 30 replies
- Grand Banks Dory
- first build
