Everything posted by CapnJack43
Been a while since I posted made some progress but lots of other things happening as usual. Used drill press and dremel to shape the yards.
- 70 replies
- Rattlesnake
- Model Shipways
Had some leftover rail posts from my Danmark Build - used them with some leftover brass rod to make the side rails.
- 70 replies
- Rattlesnake
- Model Shipways
Made a needle out of a piece of brass rod by hammering the end to flatten in and then drill a small hold to insert the anchor line.
- 70 replies
- Rattlesnake
- Model Shipways
Bow rails are completed thanks to Kenneth Powell for the great photos in his build log. Made the grating out of 1/32x1/32nd strip wood. Using my home made jig for attaching the rails to the bow makes up for my shaky hands.
- 70 replies
- Rattlesnake
- Model Shipways
- 70 replies
- Rattlesnake
- Model Shipways
Bow rail did not line up after gluing it together. Used a piece of strip wood and alligator clips to get the proper spread.
- 70 replies
- Rattlesnake
- Model Shipways
Chainplates with deadeyes are done - made another jig with an alligator clip to hold them level while gluing them to the hull. Chain did not come with the kit - bought some chain in Walmart and secured to the hull with pins.
- 70 replies
- Rattlesnake
- Model Shipways
Didn't like the bread and butter longboat that came with the kit so I decided to order a longboat from model expo. Kit came in a plastic bag with no photo and a single sheet of printed instructions and the photos on the sheet were so dark that I could not figure out what they were trying to show. Found some links on this site from other builders that helped clear things up.
- 70 replies
- Rattlesnake
- Model Shipways
- 70 replies
- Rattlesnake
- Model Shipways
- 70 replies
- Rattlesnake
- Model Shipways
- 70 replies
- Rattlesnake
- Model Shipways
- 70 replies
- Rattlesnake
- Model Shipways
- 70 replies
- Rattlesnake
- Model Shipways
- 70 replies
- Rattlesnake
- Model Shipways
- 70 replies
- Rattlesnake
- Model Shipways
- 70 replies
- Rattlesnake
- Model Shipways
- 70 replies
- Rattlesnake
- Model Shipways
- 70 replies
- Rattlesnake
- Model Shipways
Another jig to make the lines straight-need all the help I can get
- 70 replies
- Rattlesnake
- Model Shipways
- 70 replies
- Rattlesnake
- Model Shipways
Had to cut the Britannia fitting because it was too small, cut out the snake and mounted it on a piece of wood added the gold by dipping a q tip in gold and rolling most of it off on a paper towel before rolling it across the surface Window frames in white seem to make it stand out better
- 70 replies
- Rattlesnake
- Model Shipways
- 70 replies
- Rattlesnake
- Model Shipways
Made a base out of 5/8 inch stock contoured it to the hull and fastened it with wood glue and screws
- 70 replies
- Rattlesnake
- Model Shipways
- 70 replies
- Rattlesnake
- Model Shipways
- 70 replies
- Rattlesnake
- Model Shipways
