CapnJack43
Everything posted by CapnJack43
  1. Been a while since I posted made some progress but lots of other things happening as usual. Used drill press and dremel to shape the yards.
  2. Had some leftover rail posts from my Danmark Build - used them with some leftover brass rod to make the side rails.
  3. Made a needle out of a piece of brass rod by hammering the end to flatten in and then drill a small hold to insert the anchor line.
  4. Bow rails are completed thanks to Kenneth Powell for the great photos in his build log. Made the grating out of 1/32x1/32nd strip wood. Using my home made jig for attaching the rails to the bow makes up for my shaky hands.
  5. Fore and aft deck rails are done getting ready to work on the bow rails and dreading it.
  6. Bow rail did not line up after gluing it together. Used a piece of strip wood and alligator clips to get the proper spread.
  7. Chainplates with deadeyes are done - made another jig with an alligator clip to hold them level while gluing them to the hull. Chain did not come with the kit - bought some chain in Walmart and secured to the hull with pins.
  8. Didn't like the bread and butter longboat that came with the kit so I decided to order a longboat from model expo. Kit came in a plastic bag with no photo and a single sheet of printed instructions and the photos on the sheet were so dark that I could not figure out what they were trying to show. Found some links on this site from other builders that helped clear things up.
  9. Making a stairway for the forecastle put together a jig with the dremel drill press
  10. Had to cut the Britannia fitting because it was too small, cut out the snake and mounted it on a piece of wood added the gold by dipping a q tip in gold and rolling most of it off on a paper towel before rolling it across the surface Window frames in white seem to make it stand out better
  11. Made a base out of 5/8 inch stock contoured it to the hull and fastened it with wood glue and screws
  12. Tinted clear water based acrylic with some brown acrylic paint to darken the deck a bit
  13. First coat of primer is on the hull next step is to fill and sand the many imperfections
