DPTrainer
  1. Hi Aydin, I'm currently building this model and your build blog is very helpful as this is my first model using planking! I am just about to start the planking but I have had great difficulty fitting the rudders and motor assemblies even with no sides and decking on the boat! I noticed from the photos that you have fitted the propeller shafts at the start of planking but you don't appear to have fitted the rudder assemblies, rudder servo and linkages. I'm concerned that I will not be able to fit the rudder mechanisms if the boat is planked. I found my hands were accessing these components through the side of the boat. Also the control horns fit freely on the rudder shaft so I presume you will need an extra nut in order to secure the control horn onto the rudder. At what point did you fit the rudders and r/c linkages please. Also I had to remove the motors from the gear box to get them into the hull. Was this your experience as well? Any tips will be greatly received. Thanking you for your anticipated help. Cheers Duncan Platt (DPTrainer)
