Everything posted by Coyote_6
Thank you @Gregory. I will probably be unable to get wider material as I have only been able to find some from Europe. Limited to current width, I may be able to do the two into three. But the graphics are very helpful. But I guess first I better get some measurements. I really appreciate your advice "don't let 'perfect' be your goal". It allows one to accept some compromise where necessary. We'll see what we can do here. Thanks again!
@Pirate adam I will take your advice and measure the remaining planking run for each bulkhead and do some math ! Then I can look at some options as well. Til now I have been able to keep my plank runs pretty perpendicular to the horizon. The stern is rising but I thought it would get better after the deadwood. But measurements would make that much clearer!
In profile I am starting to develop a "smiley face effect", where the planks are riding higher at the bow and stern than in the middle. I have been removing about 1/4 height of each plank at the bow to minimize the effect. I want to avoid a bunch of skinny planks (1/2 width or less) at the bow. Anyone have any thoughts on how to proceed elegantly here? Depending on how she sands I would like to spare myself the second planking - the current planks are 2mm thick.
Curious before I go much farther. Has anyone else done a ship where the aft deadwood era was so far above (proud of) the keel before shaping? The false keel was only like 4 mm thick, so to shave it for the planking would be to effectively remove it. I will be targeting the hull strakes to be 0.5 mm proud of the sternpost/keel after sanding. Will this work? Any thoughts appreciated!
So with the sternpost fitted, the garboard planks went on without a hitch. At only 5 mm wide the addition is almost insignificant, but you have to have someplace to start. Starboard and Port. This model has very nice lines and accessories but is not a stellar model of how a real ship was built. Without a rabbet to install the planks, a lot of careful sanding and filing will be required to make her fair. I think it can be accomplished but I will have to be careful not to eat away the stempost, sternpost or keel. In any respect, a milestone.
So I was working on the port and starboard garboard planks, with a plan to fit the stern portion of the keel and rudder after planking. It quickly became clear the stern keel and rudder needs fitting prior to planking, so stay tuned for that! (Stern keel piece [sternpost?] Not included in image, but it clearly does not "fit" at this time.) Here I've shaped the keel to match the rudder shape, with proper spacing between the two. (More or less, anyway! )
The next natural progression at this point would seem to be hull planking. This brings me to my second issue with the kit - the plywood framing "keel" in no way conforms with the provided stem, forefoot and keel provided. Test fitting convinced me to attach these pieces before planking so I could iron out any issues. I had fitted the best I could and ended up with significant gaps. Now that we're at the point of adding the garboard strakes, it is time to address the issue. Custom shaped a piece of walnut to fill the largest gap between the plywood framing keel and forefoot and then resorted to PVA glue and sanding to fill all the gap lines. It looks passable, but staining will be the true test.
Your PdN is fabulous GrandpaPhil. I looked at your entire build log when I first signed up here and was amazed, both by the beauty of the model and what you can do with card! I can see why she's your favorite. I am leaning towards brass pedestals, but now must consider a cradle as well. The cradle would leave the ship unmolested and removable for inspection, whereas I think the pedestals may require drilling in to the keel and having fasteners or rods protrude. You definitely have given me something to think about! (Not that I generally want people "inspecting" my ship, but I think I like the idea of the ship being the ship, with no protruding add-ons or modifications.)
Well, to paraphrase Captain Barbosa from Pirates of the Caribbean, " then we have an accord." I had not considered waterline in the equation. Since most plans I've seen of the PdN depict the waterline approximately parallel to the weatherdeck (accounting for generally equivalent deck sheer fore and aft), I think everyone is in agreement. See this image from Chapelle in The History of American Sailing Ships: I will select some brass pedestals that will keep the weatherdeck and waterline level with the base, allowing the keel to be lower aft to demonstrate her drag. Thank you all for sparing me from making a mistake here!! I appreciate all the input!!
So a question to the audience - On the Prince, the keel and hull sit lower aft than forward when the weatherdeck is level (drag). Do you prefer to mount the ship for display with the weather deck level or the keel level? Which do you think looks better and why? A wise man at a local club meeting recently told me to figure out how she will be displayed, and incorporate the mounts now before I plank the hull. It will be brass pedestals on a wood base, but will the aft pedestal be lower than the forward one, or will they be the same height?? Looking for some ideas. Thanks, Steve
So the first issue with Constructo's kit arose, and I am glad I caught it early. Kit provides 1300 linear mm's of "Manzonia" wood for framing the gun and sweep ports, but the ship requires at least 1408 linear mm's of material. Imagine if you were installing/glueing as you cut, only to discover you don't have enough "Manzonia" to finish the frames. Crazy. Model Shipways walnut strips to the rescue, and enough to do multiple ships at that!! (Small stained sample of new wood in photo.) First framed gunport! (Severely damaged plywood bulwark within - should be plenty strong now!) "Boom!" Ha! Love it!! Steve
Inner planking with gunports being cut out... And outer planks. I choose to leave a small gap between planks so the individual planks will be delineated after sanding (whereas below the bumper line I intend to tighten the gaps between planks) I am leaving the transom stern til last - you can see I edge-bent the first internal plank, and continuing that process will be a little more time- consuming.
Planking the Bulwarks The planking of the weather deck was the one thing I did in my initial attempts twenty years ago. I have been told by experienced shipbuilders that it turned out ok, so to build on that success (and to attempt to correct various issues with the bulwarks plywood) I decided to plank the bulwarks down to where the guardrail/bumpers will be installed. First plank and stringers between deck and inner bulwarks Stern inner planking first row and second side row begins. 3rd row and on...
Rounding out the plywood sheet parts, the deck house framing and the bulwarks and transom stern. The bulwarks were difficult in two regards - firstly I should have pre-bent them to conform to the ships lines better, and secondly, having broken away the tops of several gunports did not help in getting the shape desired. I believe the planking both inside and out will cover my issues pretty well, but time will tell. Foundations of the deckhouse - not a precision form by any means. The bulwarks installed and checking gun barrels for center in the gunports. I should mention the mast hounds were drilled out in 2002ish timeframe - fairly straightforward as the bit followed slots in the false keel. Damaged gunport framing and an ill-fated first attempt at hull planking, which was later removed. Ugh.
She simply bristled with guns in September of 1945! The kit comes with a plastic replica of the marker embedded in the deck to commemorate the surrender, but I was lucky enough to pick up a coin in Pearl Harbor when we visited the Mighty Mo' replicating the marker. Fair winds and following seas, and thanks for checking her out! Steve
