Everything posted by Coyote_6
Can't believe it's been 5 weeks since my last progress report! The yard has been busy but the results are not overwhelming. First up, the wardroom. The camera shows every flaw! Yikes! Next up, installed the chainrails and pinrails and I think I learned to drill the pinrails before attaching them to the hull going forward... Between the Shopsmith dedicated drill press and the sturdiness of the build board I think they turned out ok. So for now we'll call the mizzenmast pinrails complete. And we'll be drilling the foremast pinrails off of the ship. Stressfully, I am not super-confident in the kit instructions as far as pin locations and gunports. We'll see how it works out. The model plans are close to Chapelle's rigging plans but not exactly the same. It would be sad to be finishing rigging only to find the pinrails not correctly drilled.
So the latest work seemed like such a challenge to make happen, but it doesn't look like much when you see it implemented on the ship. The rails are installed atop the bulkheads! First attempt at incorporating a simple scarf joint. The bow has been opened up for the bowsprit. Lots of slow and careful filing here. The addition of the anchor rake reinforements, port and starboard. (These actually weren't much work but could use some more sanding.) Next steps will include finishing hull details and thinking about applying the finish to the hull portion and deck (tung oil and wipe-on poly). Then on to deck furniture. Thanks for looking!
And of course the starboard crew has caught up with the port team - hull is faired and guardrails (wales) stained and installed. Hopefully that repair will disappear further when the hull gets its finish and darkens. Everyone is now turning to on the rails, and as we all know I can't edge bend walnut to save my life. So we cut out the forward rails from walnut sheet. Decent fit below. Will have to develop some fancy joinery to connect all the rails professionally. Thanks for looking, and as always all comments and ideas welcome!
So we saw the new "build board" in the previous post, which I probably should have been using since the beginning of the build. 11 3/4" x 36" melamine shelf L-shaped brackets from an on-line retailer Pine trim strip Stainless screws as required. The melamine shelf increased the weight of the hull by like 20x, which should add stability for transport to club meetings and rigging. Adjustable L brackets allow added stability and nest with the guardrails. And a little flair.
It's been a rough month for progress, but not due to a lack of trying. The starboard damage has been replaced and is relatively fair. Color variation due to a lack of spare material options - but when finished I hope it will look fine. I have spent 4 weeks trying to bend walnut and mansonia to curve as the gallant rails atop the bulworks, but to no avail. Steam, soaking, nothing. I have abandoned the idea and will resort to a 3/32" x 3" x 24" piece of walnut for the port and starboard curved portions, and will match and finish the rails with 2mm x 6mm x 500mm walnut strips. Very good color match if I decide to leave them natural. The other option would be black stain like the guardrails on the port side above. Finally, I have been working on a build board to facilitate transport to club meetings and as a stable base to support rigging when it comes to that. So we are still at it.
As much as the starboard crew is having a rough time in the yard, the port crew continues with progress. Here we see supplemental framing for the damaged starboard section. Damage was removed bulkhead to bulkhead. While the starboard crew loses time on repairs, the port crew has stained and installed the guardrails to the faired hull. Progress continues.
Today is a milestone - the one year anniversary of the Prince's build log. I am super pleased with her progress to date and super thankful for all the support over the last year, from both Model Ship World folks and my local club (San Diego Ship Modelers Guild). Thanks all for your inputs and reactions. Status today is the port side of the hull is fair, the starboard is still in work and the stern is being filled out/shaped and coming along nicely. Photo of port stern filled in and shaped, starboard in work. Also have made a decision on mounting - flat board with single wooden cradle at center - gold nautical fish pedestals fore and aft. I've learned a lot in 12 months - progress continues...
Sanding has commenced. Any tips or tricks appreciated. Before: After: I also made a little 2" material sample to check my finish ideas. The first half inch is natural wood - then Watco Danish Oil in Natural. The Elmer's Mahogany Wood Filler seems to darken with the oil, which is good. Hoping to final finish with Watco wipe on poly (satin).
Big night tonight - after 21 years of owning this kit - the Whiskey Plank is in!! Before installation: After installation: After reading about the old custom of celebrating the last plank with a drink of whiskey amongst the builders, I couldn't resist the tradition here. So the last plank, or "Whiskey Plank" has been installed. So the port profile: and the starboard... On to the stern. (And we'll see how she fairs with filler and sanding.)
@Bob Cleek Thank you so much for the links to those articles. You have saved me many troubles. I had intended to get some lead shot for cannon balls. Nope. I was going to paint the inside of my bulwarks with water-based acrylic paint. Nope. PVA seems well regarded and stable. It was kind of Mr. Wegner to share his impressive expertise - what an interesting job!! Great links Bob!!
I guess the better question is, has anyone seen PVA fail on its own over significant periods of time, or is it pretty well time-tested?
