Solid build Chris, and we are in the same boat (pun intended), since I have not smelled Testor's glue since Clinton administration.
Yesterday I tried using the Minicraft yellow stipe decals, but they are prone to breakage, plus do NOT like going over the rivets. I ended up painting the line, after carefully masking it using Tamiya 10mm tape, Blue painter's tape, and several sheets if paper. I used a rattle can of Tamiya Chrome yellow. I made the line the width of two rows of rivets by masking above the 'ledge' between the portholes and the first line of rivets, and then below the second line of rivets. You do have to cheat your masking a little bit towards the bow and the stern, since some rectangular windows do not quite line up. Cheers
