Alvb
  • Location
    Germany
  1. Happy New Year to everyone! I've been doing some macramé rigging these past few days. There's still a lot of loose stuff to sort out.
  2. The standing rigging is now complete, and the fitting of the yards and sails has begun. The foresail is proving challenging, as it should appear strongly billowing, and some of the rigging elements are puzzling.
  3. Which ones do you mean? The small wheels of later gun carriages, or the small ones in my photo? The small wheels in the photo are the wheel hubs.
  4. Thank you very much for the feedback. I actually had to shorten the guns a bit; otherwise they would have been 5 meters long. Yes, I'm thinking about incorporating some figures, perhaps like in the painting. Let's see if I can find or create some in 1:250.
  5. It's been a while since I've shown anything here. I'm currently trying to make guns for the ship's deck. It's difficult. The gun shown has a total length of 1.8 cm, or 0.75 inches. The wheels have a diameter of around 5 mm, or 0.2 inches. I'm curious to see how much of it will still be visible under the anti-boarding nets. Alvb Unfortunately, the image is very poor....
  6. many thanks to all I use these subframes made of sturdy cardboard. The shroud ropes are clamped into them, and then the web lines are placed over them. At the intersection points, I use a needle to apply tiny drops of shellac as glue. Finally, the entire shroud system is removed from the frame and any excess length is trimmed off. It's ready for installation on the boat.
  7. Without knowing more about your specific case, I can say that color shows flaws more clearly rather than hiding them. Bela
  8. "Tempus fugit" My last post was on August 15th! However, progress was still made in small steps. The standing rigging of the lower masts is nearing completion.
  9. Don't the jib halyard's cable and the lower block of the mainstay get in each other's way? Bela
  10. This is better. The masts have been lengthened and the fighting tops have been reduced in size. I'd like to depict the sail as billowing as Brueghel did. I've used Bible paper for other models at this scale. However, it's difficult to curve it in two directions. Perhaps someone here has a tip on how I could create such a billowing, curved sail. best regards Alvb
  11. I think the masts are too short and the tops are too big. I think they need to be redone.
  12. After a somewhat longer break, the mast builder has resumed his work and built the two fighting tops. (the masts are not yet completely fixed) I'm wondering where the men left the missing pavises lying around?
