g8rfan
Everything posted by g8rfan
  1. I also installed the sheaves at the aft end of the deck. At first I tried to fabricate these using the sandwich method, but at this scale, I had a hard time getting all the pieces lined up well. i was able to manage the ones at the top of the bulwark. For the ones further forward that are embedded in the wall, I chose to just use a solid piece of wood. I drilled holes where the lines would feed through and then used a very fine engraving bit on the Dremel to carve out between the holes. This at least made the pieces look more like a sheave and not just two holes.
  2. Well, I spent about an hour last night putting up a post of my recent work, only to find it wasn't here today. I'm guessing I must have forgotten to hit the submit button. Oh well, here goes again. After spending a while making a bunch of eyebolts for the gun deck, I realized I had forgotten a couple things on the outside hull, namely the boltheads around the gun ports (actually the backings for all the eyebolts i was getting ready to install). At first, I assumed these would be the same size as the bolt heads on the inner bulwarks, but after making a few comparative measurements on a few photos, it appears these are actually about 3.5" in diameter. At first I considered using pinheads, but these were a bit too large. Then I remembered the TichyTrain rivets and ordered some of the 0.035" size. The first time I tried to use these, I had a terrible time. If you try to cut them off one at a time, they tend to fly off like tidly-winks never to be found again, and even handling them with tweezers was not easy, if squeezed too tight or too close to the end of the tweezers, they again would fly off into the room somewhere. I found though that if I taped the entire piece to a piece of masking tape and cut them all at once with a sharp blade, the tape would hold them in place and allow me to pick them up one at a time fairly easily. I then simply inserted them into pre-drilled holes. I first tried using CA glue, but found that the glue did not want to adhere to the plastic, probably due to some mold release agent. Instead, I used slow curing two-part epoxy (J-B Weld) which worked really well. I just made a nice puddle of mixed epoxy and dipped the end of the rivet into this. Here's how things went, I left the rivets brown for the photo so they would be easier to see, but of course all this will be painted black
  3. Thanks again Paul. Looking at that link, those are some tiny hooks, and the eyes might be just what I'm looking for. Best thing we have here is probably BassPro. I'll definitely check it out. Much appreciated!!
  4. Hey Jon, You definitely hit that eyebolt on the head (or in the eye). It is amazing how many eyebolts are actually on this ship. To save my sanity, I will definitely take your advice. I plan to make enough to take care of the gun deck rigging and wait to do the spar deck when the time comes. For the rest, I can just make them as needed. I got you on blacking them. I did try painting the 1/32 ones at first, but as you pointed out, that does tend to clog up the eyes, even using an airbrush. Also, any that were touching would stick together and once separated, the brass would show. I got some Brass Black and thankfully it works well on the wire I'm using.
  5. I spent a while searching some more for smaller eyebolts without much luck, so I set about making some. Using a small jig I crafted, I could make about 50 in an hour and a half. Not bad, but still a good bit of time. Then I simply posted the question here on MSW and got a great suggestion from @petervisser . Instead of trying to make an eyebolt with the typical shape, he simply twists wire around an appropriately sized needle. this gives an eye that is perfectly shaped and the right size. Of course, the shank is twisted and larger, but it doesn't matter as this will be buried in the wood and not visible, and actually gives a little more grip. This method is really fast and easy. I could make about 1/minute using 36 ga wire and a 24ga needle
  6. Thanks Paul. Not sure even very small fish hooks would be the size I'm looking for, but for even the 1/32" I bet your right and probably cheaper than buying scale eyebolts
  7. Hi Jim, Glad to see you got a log going. Just wanted to concur with Kurt on the transom issue, I had the same issue and thanks to him was able to catch it in the beginning. Easier to fix while you are shaping the hull than later. My hull didn't have a significant twist in it. Good luck on the build Frank
  8. Thanks David, Thats a great site. I would love to buy one pack just to see how they are, but the shipping from the UK is more than the eyelets. Will have to think about whether to go ahead and spend $30 for three or just make my own. Thanks again for the link. I gave Peter's method a try last night and it actually works really well. After getting the hang of it, I could make about 1 per minute. I wrapped the wire around a 24 ga. needle and grabbed the ends with a hemostat. With one finger through the grip on the hemostat, I could just hold the needle end tight and twirl the hemostat. The toughest part is judging when the eye is tight against the needle. Still, a very nice approach. Of course, at a minute each, it will still take about 7-8 hours to make all that I need for the whole ship. 😆 Thanks again Peter. I'll be sure to give you credit in my build log. By the way, where did you get the black wire? Frank
  9. Hi David Thanks for the link. These are a little bit larger than what I was able to make, but smaller than the 1/32" and I like that they come in packs of 250. It's unfortunate that they are out of stock. Might have had to give this some thought. Appreciate the input.
  10. Thanks GP, I know what you mean there. I typically will work for about an hour and then give myself a break. I figure to do everything I need is going to take close to 12 hours total. Peter, thanks for sharing your method. I like the twist idea, because it keeps the stem centered and since it is going to be buried in the wood, it doesn't really matter what the final diameter is. I am also using 28 ga. wire and wrapping it around a 24 ga needle to get a final eyebolt that has1mm od. Your approach will definitely save some time. Henry - already thought about that AND they have to be small enough to fit through these tiny eyebolts......ugh. And we do this for fun, right?
  11. Thanks GP, I'll take a look. I've given a go at making my own from wire as you described. I can gt it done and can actually make about 100 in an hour and a half. Problem is, the ship is going to need probably close to 800 total. It seems a pretty arduous task. Plastic might not be too bad. BTW, would you mind sharing how you make the eyebolts. The way I have been doing it is to wrap the wire around a post that I made by mounting a 24 ga needle into a wood board. After trimming this, I get what looks like a "P" shape. Then I insert this into a hole and use fine tip tweezers to bend the eye outward so that it is perpendicular to the stem. Bit of a process Here's the final outcome compared to the 1/32" eyebolts that came with the kit
  12. Hey Jon, Thanks for the feedback. I have definitely considered whether it is worth it to even bother. You are correct, at any distance at all, you can hardly recognize the eyebolts, but to me, the 1/32 just look "clunky" at this scale. The wire is surprisingly strong and fairly easy to work with. You can get away with 2-3 bends in the same place, but any more than that and yes, it will break. My last concern was the thread. As you pointed out, it may be a bit of a hassle trying to get it through these tiny holes, and the hooks are going to also need to be fabricated from wire thin enough to fit in the eyebolts. I'm going to make a few and see how hard this is before thinking about spending the time to make all these. As for the count, thanks for the drawings. I didn't include the double eyebolts that go on the hanging knees. I made those up separately and am quite happy with how they turned out. I do like the look of the haul in/out tackle and so I wanted to include it. As you may have noticed form what little I've done so far, I am also a bit focused on the little details
  13. I am currently working on the BlueJaket USS Constitution and ready to move inside and get started on the gundeck. Before laying the deck, I wanted to get all the eyebolts taken care of for the guns. The eye bolts supplied by BJ have 1/32" i.d. which equates to 3" at full scale - 2to 3 times what they should be. I made eyebolts from 28 gauge (.014") wire that were more suitably sized, and although not terribly difficult to do, I will need 14 per gun or 448 total (plus all the ones for the carronades). Definitely not thrilled about tackling that. My question - does anyone out there know of a source for eyebolts smaller than 1/32"? I've looked everywhere and that is the smallest size I have been able to locate.
  14. All the airports, scuppers, sea steps and mooring staples are installed. I am ready to move inside and get started on the gundeck. Before laying the deck, I wanted to get all the eyebolts taken care of for the guns. The eye bolts supplied by BJ have 1/32" i.d. which equates to 3" at full scale - 2-3 times what they should be. I made eyebolts from 28 gauge (.014") wire that were more suitably sized, and although not terribly difficult to do, I will need 14 per gun or 448 total (plus all the ones for the carronades). Definitely not thrilled about tackling that. My question - does anyone out there know of a source for eyebolts smaller than 1/32"? I've looked everywhere and that is the smallest size I have been able to locate.
  15. Aye...I am the cap'n of me own ship. I can do with her as I please. Thanks Jon, appreciate you taking the time to look. Personally, I kinda like the contrast of the white steps against the black hull. Think I'll stick with all white
  16. Started work on the sea steps. I had hoped to replicate the 3 tier steps made by @JSGerson but at 1/98 scale, that proved to be a fruitless endeavor. I settled on making two tier steps, which still gives the impression that they are not just one layer. The top of the step is 28x6" and the bottom tier is 24x4", with an overall thickness of 4"(thanks Jon for the plans) . Dividing the overall thickness by two means each piece needed to be .02" thick. The top piece needed to be 1/16" wide. Of course I don't have any lumber to fit those dimensions, but as it turns out, the left over scribed decking I had from the gun deck worked out perfect. The scribing is 1/6" wide and if I sanded the back side down until the scribing just showed through, I got the perfect thickness. I sanded down a piece that was four planks wide and about 4" long, then cut this down to the appropriate length of .29" and .25" for the two different layers. The individual planks were then very easy to separate. Prior to separating the lower pieces, I shaved off about 1/3 to give me pieces that were equivalent to 4" deep. These were glued together using thinned (50:50) wood glue Now I just need to paint them and attach to the hull. Question for all: the instructions from BJ say they are painted black (from Navy plan#35810), however, most models I have seen they are all painted white, and then finally I have teh following photo from 1931 where they are painted to match the hull color depending on location. My model is based on 1812 configuration. Does anyone know what they should be for that time?
  17. Hi Brian Been folowing your log for a while. I love the idea of opening up the side of the ship to show all the interior. When (if) I finish my Connie, I plan to build a cross section to display next to her to show all these details. Your log will help considerably with alot of those details. Keep up the great work Frank
  18. Thanks Jon, I was pretty happy with them. getting the oval shaped holes in the hull to fit them into was a bit of a challenge. I'll post some pics once I get them painted.
  19. Next were the scuppers. BJ doesn't supply these with the kit, so they had to be fabricated. From Navy plan 25001.A, the overall length of the scuppers is 17" and the ends of the "oval" are 8 3/4". With a little math, that equates to an overall circumference of 44", which if stretched out to a circle, would have a diameter of 14". On scale that would be equal to 9/64th. I could not locate that diameter tubing locally and didn't really want to wait to order it, so I settled for 5/32, which after squashing and shaping wouldn't really make that much difference. The plan was to cut small rings from the tubing and squash them flat to give the desired shape. The ends of the oval are 8 3/4", which is close enough to 9", or 3/32 on scale. All I need to do was squash the tubing down to 3/32" width. After that, the edges were filed down leaving just the lower lip for the door, then cut the doors from brass sheet and attach with CA glue. Here's the sequence: Here's a better pic showing the lower lip After doing a couple of these, I realized the door was too large and should be the same diameter as the hole so that it fits into the lower lip. I removed the ones I had done and cut new ones. here's the final outcome: One last mistake When filing down the outside edges, I forgot to take into account that the port and starboard sides are mirror images. I made them all the same. A tiny detail that will probably never be noticed by anyone other than myself, and since I really didn't want to make half of them all over again, the doors on one side will be facing the wrong way. Oh well.
  20. Thanks Jon, I'm glad you liked the copper, and with the detail work that you do, saying that anything I did was amazing is a welcome compliment. I did remember to get the airports flush when installing them, here is how they look Still need a little touch up paint and a couple need some filler around the edges where the hole wasn't very clean. Overall, happy with how they turned out. BTW, thanks for the details on the sea steps.
  21. Thanks Tim, I appreciate the support. No doubt, a wooden model is nothing like plastic. Even though there are a bunch of cast metal parts, most everything has to be fabricated. To add to it, BJ's "instructions" are more of a guide than step by step instructions. For me, that means alot of research as i go along. Still, it's fun learning new things and I do love a challenge. I just read through your Alfred log. Very impressive work and a beautiful ship. A bunch of things in the beginning I wish I had read several months ago, and alot of good ideas and tricks that I will certainly use moving forward. I'm now moving on to the outside hull details, starting with the airports. the brass fitting supplied by BJ are nice, but they do not have the shield (eyebrow) over the top half as they are on the ship. I felt that this would be a nice detail and would also make the ports more visible once installed, When perfectly flat, they all but disappear. The supplied airports are 1/16" thick and 1/8" in diameter. To make the eyebrows, I cut some 36 gauge brass sheet into 5/64" strips and then cut pieces that would be long enough to fit around half of the airport. I used 1/8: brass tubing to bend these pieces to the proper curve and then glued them to the edge of the airports with CA glue. I'll have some photos shortly
  22. So, I was going to get started on all the outer hull fittings, but decided to frame in the transom first. I made up a mock transom from bristol board to help make sure everything lined up well. The first thing I found was that the window sill was too low. This actually ended up helping me. In addition to being too low, I had forgotten to leave a curve in the back and had sanded it flat across. To fix these two things, I just added a 1/16th" thick piece to the window sill. To get the proper curve, I used the gun deck plan as a template. Also, before gluing it down, I cut out notches for the transom timbers. That was much easier to do on a flat piece of wood than trying to chisel out notches from the solid hull.
  23. Yes, by far. 5 rolls of copper tape from Temu - $3.00 and I gave my freind $25 for printing the stamps even though he didn't want me to. 10 sets of plates from BJ - $290. Just a little bit of a savings.
