Ikcdab
Everything posted by Ikcdab
  1. Thanks to @KeithAug @druxey and @wmherbert for your helpful advice. I'm not sure how I avoid bending "in the wide direction" as it seems essential to me that the first plank should follow the line of the deck. With regards to my previous question about appropriate planking width, I realise that they don't all have to be the same width....I will get the table saw going tomorrow and cut planks in 6, 7 and 8mm widths and see how it goes .. Thanks again
  2. Bulkheads all now fixed to building board, keel made up and we are ready to start planking. I have, of course, watched endless youtube clips about planking, so I am soaked in how to do it....but confused by the variations - everybody has their own methods. So, what are the top tips for planking? The designer says to start at deck level and lay in a few planks either side of that. The lay in planks from the garboard and fill in the gap. Is that the best way?
  3. I have come across a snag. I have cut out the bulkheads exactly as per the drawings. When I assemble them, I have a mismatch between the hole for the propellor tube on the final bulkhead and where the cutout (slot) is on the keel section. See picture below When I measure it on the drawings, I see the mismatch. There is a 8mm discrepancy, the diameter of the hole. I don't see how I can change the slot because of I move it down the propeller will no longer fit. All I can think of doing is to fill the holes in the bulkheads and refill them too match the slot. Then I'll need to shim the motor so that the shaft matches the redrilled holes. Any thoughts?
  4. Hi Keith, thanks. We shall see. Luckily I can back out and change things if it doesn't work out. As you say, I said I was using balsa right up front and all the advice on here was not to, despite that being what the original designer used. I do have plenty of clamps, we shall just have to see how it goes. I guess narrower planking will be easier than wider in that case. Ian
  5. Hi Keith, as per the plans I am building it from, the bulkheads are spaced 95mm apart. I am planking it with 3mm thick planks, again as per the drawings.
  6. So I have now cut out all of the bulkheads. Just temporarily stood up....
  7. Hi Roger, thanks. Is "spiing" the correct term? Google doesn't help me with that! The strip approach seems promising, I guess narrower strips are easier to form around the shape of the hull. Ian
  8. Excellent. Very useful. I found that gentle heat from a hairdryer was sufficient to soften the prittstick such that it just peeled off.
  9. So the reprint was successful. I now have a straight, unwarped rudder. Ill upload a picture tomorrow. Meantime i am still cutting out bulkheads. So a question, how do i decide the width of the planking? The drawings are silent on this, so its a bit of guess work. The longest length from the gunwale to the keel is about 270mm. here is a drawing showing 8mm and 9mm planking. I guess that where the sides are flat then its immaterial, but more important arouind the turns, and also where the planks bend around the stem and stern. My temptation is to go for 8mm planking, Any advice gratefully received.
  10. So tonight I am going to reprint the rudder. The screenshot below shows that I have added a sacrificial "sprue" along the bottom edge in order to try and keep the rudder from warping on the build plate. You can also see that I am going to print the remaining hatches and, hidden behind the rudder, is the motormount. Its a 9 hour print, so Ill run it overnight. Lets hope this one is more successful....
  11. And I have also started cutting out the bulkheads.... This is the first one. The top edge is sacrificial and once the planking is complete, gets get off along the curved dashed line. The instructions say to "score this line" which I have done, probably cutting half way through. I am apprehensive as to how easy it's going to be to release the hull from the building board in this way. Anyone got any experience of this?
  12. And so to actual construction. The keel is 25mm x 3mm basswood, but I could only buy 12.5mm x 3mm, so I have just to laminate two bits together. I was concerned to get these true, they are 950mm long. You can see the setup I used to get these glued true. I fastened down a 1m straight edge to my building board and held the wood tight with weights. I held the wood flat with some 123 blocks. Glue now drying.
  13. So some progress. I think I can 3d print many of the fittings for the boat. I very much enjoy using fusion360 and I have used this to design a number of features. I have now printed some. Below are the double bollards: And here are engine room hatches with portholes built in. And a failure. This is the rudder, but it has warped while printing. So I now need to reprint it, bit with additional supports to keep it true. The bend you see is not an optical illusion... I have also designed funnel, portholes, skylight, vents etc. But not printed them yet. More to came later. Ian
  14. Hi Roger thanks, I am not familiar with any of those sort of calculations and i know nothing about the motor's torque curve, the prop geometry or the hull resistance. Do people really make all of those sort of calculations for a model boat? if so, where do i find the info? Bearing in mind its a 12v motor, if i link it up to 7.2v NiMH 5ampere batteries, then that should give slower revs and a reasonable duration?
  15. Hi there thanks for the reply. My motor is 43mm diameter, so only half the diameter of the prop. I fear that a motor 90mm in diameter would be rather large!
  16. So I already have a motor in stock. It claims you be high torque, with the following specs: Rated Voltage: 12-24V Rated Current: 0.32 A Rated Speed: 3500-10000 RPM (15000 RPM MAX) Rated Power: 60W I tested it this morning. Several wallwarts that were rated at 12v failed to shift it. Even though they claim to output 1amp or more. All I got was a couple of rotations, then a stall, then a few rotations etc. I then connected up my beefy 12v old rheostat railway controller, rated at 1.5 amps. Motor ran perfectly, controllable and smooth. I guess that the wall warts, even though claiming 1 amp current aren't up to the job...my electrical theory is letting me down. But the real question is, how on earth do I choose a battery pack? I am told lipos are difficult to manage and I should steer clear of lead-acid. So that leads me back to NiMH. what sort of rating do I need to get a decent run time? YOu may think I am getting ahead of myself, but I need to know now what size of equipment the hull is going to have to accommodate so that I can make space as I cut the bulkheads.
  17. Nice price too!
  18. Hi George thanks. How easy was it to remove the templates from the wood after cutting out?
  19. Hi George, what did you decide on to stick the templates to the wood? I am at a similar stage to you on my build and am thinking prittstick. Ian
  20. Hi Jim yes it's a LH prop. I bought that as it was recommended by the designer. Apart from prototypical accuracy, does it make a difference?
  21. Well, my first purchase. Whilst I plan to make most of the parts myself, I thought that the prop would be beyond me. So now I am the proud owner of this A bronze 90mm M5 prop. I know I haven't even started on the hull yet, but thought I needed these things to get me started. Ian
  22. Hi there John, it's the one currently based in Melbourne. https://baysteamersmaritimemuseum.org.au/5present.php
  23. Hi Keith, i can cut any type of wood on the table saw. It's only that my local model shop (whom i like to support) doesn't list basswood on its website and I've not seen it in the store. Maybe i should go in and ask. I also read that basswood is "furry" - several quotes of this!
