kmurph
  1. Finished up the deck furniture and started to mount the bits and cleats. I Have the mast spreader cut and painted. Working on the masts and booms. It is going to be a few weeks before a can do any more work on the model.
  2. I have gotten the hull painted and the brass rod installed on the hull. I am going to wait on the bow Decorative brasswork, until after the Bowsprit it is installed. The deck houses made a little bit more sanding and then staining. I need to take some time to figure out the rest of the deck connections for the rigging.
  3. Started this build a few weeks ago. Hull all shaped and started the painting process.
  4. I retroactive created this build log. I went off the build plan when it came to the light towers. I used tubing instead of the supplied wooden dowels because i want to install mini LED lights in the towers. For the mounts i used 1/4" bolts that i drilled a hole through the middle for the wires. For the lights i used Lighthouse LED 12V, 5MM flat top prewired and the power supply from lighthouseled.com. The Model is 98% complete. I lost a couple of items during a move. I ordered the parts along with my next project.
