Everything posted by MisterMeester
Progress report on the stern plating kit application.... Port side, adjacent plate #12, a portion of a molded plate seam remained exposed. I suppose I didn't quite lay each subsequent plate far enough along. So I made and applied an extra plate (#12a) to cover it. This also covered the next raised molded plate seam. The only downside is that I've created an inaccuracy. There were only three such plates forward of that hawser lead hole. Same thing, starboard side. Plate #13 (yes, I know it looks like a 12, but it is a 13...pencil lead rubbed off) did not extend far enough. It's hard to say if this is the result of my application of the previous plates sequence or some other explanation. I added an extra plate here as well (#13a). This plate would not completely cover the next raised molded plate seam, so I sanded that off (green circle). A photo in the instructions suggests that Ben did the same regarding sanding down the raised seams. Now on to the lower section. The placement of plate #14 is critical, so I decided to tape plates #14 - #18 together and do a dry fit. I also cut out plate #21, which is the plate that extends from plate #18, to ensure that plate would lay right up to the rub rail. Satisfied with my positioning, I glued these 5 plates in place. I'm using Tamiya Extra Thin cement for this. Tiny gap where plate #14 meets plate #18. I haven't decided yet if I'll fill this with putty. I suspect once painted black it will barely be noticeable. Slight alignment issue. Plate #18 is off to Port by 1mm. This should work out okay, however, as plate #21 will cover that point and I should be able to lay that plate in a manner that this misalignment will not be apparent. And just a mention of cutting the plates from the template...I have gotten better at that and find cutting the plates out from this perspective.... ....is easier than this perspective.... Until next time, thanks for looking. Cheers, Mark
Hello Winnie! Happy to see another CFL fan here! Re: the FB group.... agreed, the owner definitely comes across that way, and I'm not sure why. Having communicated with him behind the scenes regarding my portholes/windows kit I found him to be actually a bit of a softy. I truly think he means well, but just has a unique way of communicating. I'm curious to know what you didn't like about the Mini Brass stern kit. Looking forward to seeing your build and thanks for looking in to my build log. Cheers, Mark
Ahoy Evan! Yes, very much content with the porthole drilling and repairs complete. Regarding the stern counter plating options, if I had scratch build skills such as yourself, I likely would have gone that route as well, but alas, as essentially a beginner, I need help in some areas. Yes, I'm pleased with my decision to go with Ben's kit. A little more economically friendly than the Mini Brass kit and not as heavy as well. As well, I'm hoping my build log will help others. Just to avoid my beginner mistakes, if nothing else. Cheers, Mark
After several (about seven or eight) attempts to replicate the orange peel texture, I finally have a result that I'm satisfied with. Not necessarily orange peel, but more like kiwi fruit peel. But it's generally uniform and I'll take it. The product and tools used. The first seven attempts were made using a black foam paint brush. The final two attempts were made with a white "Cosmetics Wedge". I also discovered, through trial and error, that it was beneficial to dab the foam, once wet with the product, on sheet styrene first, to get it worked into the foam, rather than a wet blob. A couple of examples of failed attempts... First pic, what a mess. Sanded all this off and tried again. This attempt wasn't as bad, but just not uniform. Orange peel on the left lapel, kiwi fruit peel on the right lapel. The trick is knowing when to stop dabbing as the product dries. Sanded all this off and tried again. The final result. Not perfection, but I'm okay with it. This closeup shows a tad inequality, but as the previous photo shows, it is not as noticeable from further back. Next step will be to learn how to airbrush and then primer all parts. Not sure when that will happen as golf season is in full swing (haha) and my Titanic project takes up most of the rest of my spare time. Thanks for looking. Cheers, Mark
Stern plating has commenced. Plate #1, on the stern counter, in place. Curious to see how this plays out with the subsequent plates of this area of the stern. I'm envisioning the overlap of the subsequent plates to rise above the rub rails. Should this be the case, I suppose there are two options. Remove Plate #1 and disregard plating this area, thus going with it as molded....or....go ahead and plate it and build up the rub rails. Removal from the template is delicate. The template numbered, as per instructions. Thanks for looking. Cheers, Mark
Update time, and update on the Hawser Leads. At some point I determined I got the locations of the aftermost Hawser Leads wrong, so I filled and re-drilled them a tad further forward. Upon doing research on another matter, and while looking at photographs, I had another look at these locations and concluded that I had them right the first time. Ugh. So, filled and re-drilled them again. I also decided to drill all eight of the Hawser Leads to 1.8mm. I had tried this earlier using a power drill, after having drilled them out to 1.4mm, but the bit just stuck. Drilling them out manually proved successful. 1.8mm for these leads is closer to scale. Continued with the frame kit and did a dry fit with Part Q1, which is B Deck. Upon doing so, I determined that there was a fit issue. The forward Grand Staircase of Part Q1 conflicted with not only the frame kit, but also Part W1 as well. The issue with the frame kit was not surprising, but how could Trumpeter have allowed a fit issue with Q1 and W1? Anyhoo, modify I did. Turns out I was missing a few parts in the dry fit. Oops. Honestly, I had a hard time understanding the instructions. Trumpeter has the modeler building the Superstructure primarily separate, before attaching the whole block to the hull. A few YouTube vids finally made it clear. The short of it is, I didn't have to modify Part W1, or the frame kit, for Part Q1 at all, as Parts N & P and A9 and A12 all raise Q1 higher than I had it during my first dry fit. Oh well. No harm done. As mentioned, I'm not lighting my model, so I expect the Grand Staircase interior area will not be visible much. Further, the frame kit should still function accordingly. Despite the cutouts, the horizontal frame is still solid with vertical frame. Part A9, above. Hard to make out in this pic, but the staircase is now above Part W1 and the frame kit. Port porthole fix, complete. Drilled out to 3.2mm and filled with 3.2mm styrene rod. Any cavities filled with Milliput. Sanded down and re-drilled again with 3/32" bit. I'm now happy with the results. I figure it will look better once paint is applied. As above, for the final Stbd porthole I was not happy with. Again, should look better with paint on it. More mods required for the frame kit. This time to accommodate Parts N1 & N2 and P1 & P2. This should complete modifying the aftermarket frame kit. And yet another mistake admission. I inadvertently cut a stanchion off Part N1. My excuse is that I'd cut Part N2 off it's sprue a few days before I did the same to N1. Bottom line is carelessness. Red circle shows the corresponding stanchion of N2 intact. Green circle indicates the mistake. Blue circle indicates a sprue piece I used to fix. Sprue piece filed and sanded square. New stanchion in place. I'm happy with this result. I may have to sand down the height of it a smidge as I suspect it's too tall. Time will tell. That's it for now. Applying the stern plating aftermarket kit, purchased from The Midwest Model Shop, will be next. Thanks for looking. Cheers, Mark
Update time..... Part P2 "continue ridge" sanded down and complete. Corrections to Part N2. Relocate two portholes; add porthole; remove door; add window; continue ridge. Windows of the 1st Class Gangway Doors hollowed out. Two doors on each side. I purchased an aftermarket kit for the Utley sidelights from ScaleWarships. Instructions say to drill these portholes 3.0mm for the acrylic insert, but I found that to be too small. 1/8" is more like it. Here's a dry fit of said sidelight. I wasn't happy with 13 of the 2.4mm (3/32") portholes drilled so I filled them with 2.4mm styrene rod and re-drilled. I'm still not happy with this one on the port side and one on the starboard side. So, I've drilled them out at 1/8" and awaiting the arrival of some 1/8" styrene rod to fill and re-drill at 3/32". Note the damage to the rivets. I've ordered some HO scale 3D rivet decal sheets from Micro Mark that will, hopefully, address that. A tip picked up from Ben of The Midwest Model Shop. Once all the portholes were drilled out, I figured I could go ahead and work on making the frame kit I purchased fit. Not a good picture here. It's showing the third vertical modified to accommodate the porthole resin "glass" inserts. All the frames modified for the resin porthole inserts. I haven't figured out, yet, how parts N1 and 2, and P1 and 2 fit, but I expect I might have to modify the horizontals to accommodate the tabs on those parts. Wash ports. The forward Well Deck has 10 wash ports. Five each side. These come hollowed out already. The aft Well Deck has eight wash ports. Four each side. These wash ports are NOT hollowed out. I forgot to take a pic of them before adding the shutters. Wash port shutters. The wash ports had outward swinging hinged shutters. I used 0.25mm x 2.0mm styrene strip, cut to a length of 5.5mm each. Corners rounded using a sanding stick. That's it for now. Thanks for looking. Cheers, Mark
Stern portholes drilled. 1.2mm. Trumpeter did not include the aft hawser leads in the mold. Port Aft hawser leads plotted and drilled here. 1.4mm. Graham's document does not have distances off any references, I assume because his resource materials did not provide any. I'm satisfied that he likely spent many hours researching it, to no avail. I wasn't about to spend many hours myself on it. I plotted my holes by simply eyeballing them based on his document and the Titanic references I have. There's a good picture of these, albeit Olympic, in "Titanic: Icon of an Age", pg 119. Looks like I messed up a bit. I plotted the forwardmost lead a little too far aft. For the starboard aft hawser leads I measured the location of the port aft leads from adjacent plate seams, in millimeters, and transposed. Trumpeter DID include the forward hawser leads in the mold. However, the port forward mold depressions were 1.4mm, while the starboard forward depressions were molded at 2.0mm. I did not discover this until after I'd already drilled the other six leads. Regardless, I drilled these leads 2.0mm. Instead of drilling the other six leads again, at 2.0mm (which would be too large), I decided to plug these with 2.0mm styrene rod and will re-drill at 1.4mm. Still a work in progress, as I need to fill the cavities with putty. Minor hiccup here. The largest bit for the Wowstick is 2.2mm. The next portholes in line to drill were the .094" holes, which require either a 2.4mm bit (which I don't have) or a 3/32" bit. The Wowstick chuck is not big enough to take a 3/32" so I used my Deko drill. Drilling these holes on the starboard side went pretty much hiccup free. However, on the port side, after only two holes drilled, the bit decided to start skating on me resulting in the next two holes to drill out of alignment. Time to stop and regroup. Green arrow shows the first two holes working out fine. Red arrows show the misaligned holes. If the styrene rod in the hawser leads above works out, I have a mind to do the same here, to correct these two holes. New plan required pilot holes for the remaining. I chose to use a pin first, eyeballing as close to center as possible to mark the spot, and then use a push pin to enlarge the mark. Then I used a 0.8mm bit in the Wowstick for the pilot hole before finishing off with the 3/32" with the Deko. Everything went well from here. So, all portholes are now drilled except for the .109" holes. I have an "Utley" portholes aftermarket kit on order from Scale Warships that require a 3.0mm hole. Upon arrival of that kit, I will then drill one 3.0mm hole and do a dry fit with an "Utley" porthole before proceeding with the rest. Another little task required was this...... There are 12 of these deck supports on the inside of the hull that require cleanup for the porthole "glass" inserts. Somewhat surprised that Trumpeter did not position all the supports so as to not conflict with any portholes, but alas, I suppose that's part of model building. Door removals. As per Graham's research as shown, and cross referencing appears to confirm, a number of doors have been incorrectly molded in and, for accuracy sake, need to be removed. Still some cavity filling required for the above. And the door removal I worked on today, on part P2, which also requires "continue ridge". For "continuing the ridge", I used 0.25 x 0.50mm styrene strip, attached with Tamiya Extra Thin cement. A work in progress. Letting it set overnight before sanding it down. And to complete this post, it is a common opinion online among other builders of this model that, for a more accurate model, both the KA as well as the Pontos detail kits are beneficial, as each have their advantages. I recently came into a modest amount of unexpected retro pay from my previous work years so I decided to splurge on the Pontos kit. Quite excited to now have this kit as well as the KA kit. And an additional bonus is that I managed to find it in my home country so, no customs duty. More to come. Thanks for looking. Suggestions are welcome. Cheers, Mark
As expected, my local hobby store did not have Mr. Surfacer 500 in stock. Order placed with my go-to online supplier. It will arrive next week. In the meantime, I've masked the lapel off expecting that the procedure will not match the existing texture and will probably have to do the whole lapel. Thanks for looking. Cheers, Mark
I’ve received permission from Graham Boyd, member participant of the Facebook group “Trumpeter TITANIC 1/200th model ONLY building tips and tricks”, to reference his documents regarding kit inaccuracies to the hull and portholes and the associated corrections. Graham referenced the book “Titanic: The Ship Magnificent” for his detailed work. He created 37 images, for closer detail. Eighteen for the hull corrections and 19 for the porthole corrections. I intend to post only a few in this build log. This will, hopefully, explain what some of my decisions regarding the hull are based on. Porthole Corrections - Port Side, Section 1 Regarding the portholes to “remove”….these portholes never existed. By my count, there are 30 total. Twenty-nine on the Port side and one on the Starboard side. As of this point, I have these all filled (hence, removed) and sanded. Regarding the portholes to “add”….there are a few of these that Trumpeter just missed altogether, but the majority are portholes that are there…just in the wrong place, and need to be moved, so to speak. Considering the scale, I have no idea how Graham determined the precise distance to which a porthole needs to be moved, but I can’t help but think a bit of educated guesswork was involved with that. Regardless, I do not intend to do any of these. By my count there are 55 (+/-) of them. I figure the odds of me getting 55 new scratch portholes drilled perfectly in place are slim. There is bound to be at least one that would stick out like a red dot on a white cashmere sweater. Upon researching this build I’ve learned that building an accurate Titanic model is next to impossible. Apparently even the original builder’s models aren’t accurate. For that reason, I have decided to give myself some leeway in the accuracy department and moving/adding portholes is one of those sacrifices. Further, my skill level is limited. I’m just not willing to risk scarring an expensive kit with a procedure I don’t feel comfortable doing. I intend to make my 1/200 Titanic as accurate as I possibly can, within my skill set. This build is by no means intended to be a show model, or museum piece. It is very much solely for my own satisfaction. But I digress. Back to the reference material… Regarding the “hawseholes” (aka Hawser Port, Mooring Pipe or, as I know them, Fairlead) …. I will not be moving the foremost lead on either side of the bow. I’m fine with where they are. There are four more on the quarters (two either side) that Trumpeter missed. Those four need to be plotted. I do intend to do those. Regarding the single and double “safety bars”…..I will be attempting to apply these using styrene strips. Five single and five double, each side, for a total of 20. Prior to that attempt, however, I’m researching if there is any photo etch available for these portholes. That would be much easier, as the styrene pieces to cut will be quite tiny. Regarding the porthole sizes indicated…..these dimensions are the original sizes, in inches, reduced to 1/200 in millimeters. The mm sizes are not drill bit sizes. In fact, Trumpeter did not mold the portholes to 1/200 scale. They are all slightly smaller. Therefore, determining what size drill bits to use is ongoing. The distorted portholes….. Of the five distorted portholes (each side) to fill and re-drill, I’ve chosen an additional four (each side) that I think are distorted enough to warrant this fix as well. I believe the two aftermost portholes on the top row (bottom row in this pic, both sides) will be covered by the stern plating kit. I’ll hold off drilling those ones until after the plating has been applied. I’ve measured where they should go…. The four missing stern portholes….. I suppose Trumpeter didn’t even bother with these as they likely would not have shown on the mold at all, given their location. Plotted and ready for the drill. I have not decided which drill bit to go with on these yet. The first porthole drilled and first porthole “glass” dry fit. Starting with the lowest row, and consequently, the smallest. With the porthole “glass” aftermarket kit, and using my handy-dandy home made drill bit gauge I can take most of the guesswork out of which size to go with. For these portholes (0.031” aftermarket “glass”) I’ve decided on the 0.8mm Wowstick bit. Note to self: Styrene doesn't drill so well with the larger bits. That's it for now. Got me some drilling to do. Until next time, thanks for looking, and suggestions are welcome. Cheers, Mark
Guaranteed when I built this model 50+ years ago I did not fill gaps, and sand mold lines and join seams. I would have thrown it together, painted it and that's it. 100% certain, as well, that I used the novelty glow-in-the-dark parts. Not this time. I think I'm beyond that. Going with the conventional head, etc. Who knew a model such as this would have complications? As I am still very early in my scale modeling resurgence, I do not have an extensive repertoire of models worked on to compare this one to, but it would appear that, as models go, it's relatively cheap. And with that, comes lots of fit issues, gaps to fill, and mold lines and join seams to sand. A few pics of some work done so far.... Tamiya White Putty used here. Mr. Surfacer 1000 used here after sanding down the white. Done. Three big gaps were here, right shoe meeting with the right leg. My close up pic has revealed I'm not quite done sanding this down. The right hand comes in two parts. The left hand is all one. As with the torso, Tamiya White and Mr. Surfacer 1000. The Phantom's teeth were less than perfect. Unfortunately, I forgot to take a pic of them before I began chiseling bigger gaps between them. This pic is more or less mid-way through my work. Not a good pic. Out of focus and hard to get a sense of how they started out. Teeth done. I did just the top row. Looking forward to how they'll look when painted. This was inevitable. Sanding the join seam of the head also removed some hair striations. Hair striations chiseled back in. I hope I sanded the seam enough and primer/paint will hide it. My next dilemma is this..... The Phantom's cape covers most of the join seams on the shoulders, but not all. Some of the lapel is exposed toward the collar. The challenge here is, the lapel has an orange peel texture. Sanding the join seams will inevitably smooth a portion of that. Researching what I can do to restore that, I've learned that Mr. Surfacer 500 is a potential solution. Just brush it on and then dab it with the bristles of a brush (or, I'm thinking perhaps foam would work well). I figure if the resultant texture doesn't match, then I would mask the lapel off and do the whole lapel. I'll be checking my local hobby store for Mr. Surfacer 500 tomorrow, but I'm not holding my breath that they'll have it. I expect to have to order it online. Note to self: Do a test of this on a piece of styrene first. In the meantime, I guess I'll get back to sanding. Thanks for looking. Suggestions are welcome. Cheers, Mark
Time for an Update. Things are ramping up. Most items ordered have arrived. Just waiting for four more upgrade kits from two different suppliers, none of which have shipped yet. Not in a rush for those, however. Just a bit never-racking as they were all ordered quite sometime ago. Anyway, a summary on what I have received, thus far.... Bulkhead/Framing kit already mentioned above. I've not gotten any further with that yet than the dry fit. A few more items for reference... Went with the KA detail kit, (vs Pontos). Most reviews favor this kit. "More bang for your buck", I heard a few times. Some suggest both kits, as Pontos has items this kit does not (and vice versa). This kit actually cost me more than the Trumpeter model kit itself, so I think I'll leave the Pontos on the shelf. Interestingly, one review said the KA kit is for advanced modelers and the Pontos is better suited to the newbie. Another reviewer said the exact opposite. I guess I'll never know for sure without the Pontos kit. Purchased the Stern Plating kit from The Midwest Model Shop. A portholes/windows detail kit purchased through "Trumpeter Titanic 1/200th model ONLY building tips and tricks" Facebook group. The distorted portholes at the stern (both sides) identified for filling. Distortion is the result of the mold process. To be drilled out again, later, to make them correct round. Longitudinal view of the port side, with more portholes to be filled. These portholes don't exist. Source of this information is from the aforementioned FB group. I messaged the "author" of that info, for permission to post some of those images here, but never heard back. Anyway, including the distorted portholes, there are 47 to fill and sand. There are another 55 +/- portholes that are out of place and, for accuracy sake, should be filled and moved. I'm not brave enough to go that far. I figure the chances of me drilling 55 new portholes and get all 55 exactly aligned correctly are pretty slim. Unfortunately, the vast majority of the porthole and hull errors and corrections are on the port side. The side of the model I want to display. The starboard side has only a few errors. Fingers crossed that any mistakes I make are few and minor. Just a closer example image of some of the portholes filled. I used Milliput Superfine White. Image showing the distorted portholes, both sides, filled. And so begins the sanding. 240 grit stick. A finished porthole. Followed the 240 stick with a 400 grit stick. It went better than expected. I was concerned with botching up that rivet line. Anyway, 20 more portholes still to sand. Thanks for looking, Suggestions are welcome. Cheers, Mark
Haha! Yes! Hague, (The). I called it that too, for the first few years that we lived here. Just 22 minutes to the North (I'm actually in Warman also). Thanks for the offer of help. Two newbies heads are likely better than one! Cheers, Mark
I did a dry fit, last night, of an aftermarket frame kit I bought off eBay. It's about 2mm too long, longitudinally. Me thinks it will fit better once I clean it up. If not, will have to modify it a bit. Once that is done, I'll get a better idea of how the fit will be with the midship section of C Deck.
Well, with reluctance, I’ve decided to post a build log on this basic kit. For me, the operative word being basic. I purchased this model on impulse two years ago on an opportunistic basis for one reason. Nostalgia. I had it, and a few of the other Aurora Monster Models, 50+ years ago. But since purchasing it, and recently building my Academy 1/400 RMS Titanic, it has taken on a new purpose. That being to help learn entry level scale modeling skills, which will, no doubt, be necessary to improve on for my Trumpeter 1/200 RMS Titanic build. I looked at starting a build log for this kit on another community board, but that board was somewhat frustrating in that the engine that drove it seemed slow and clunky, annoying pop-up ads, 3rd party photo hosting, and it was unclear on exactly what a build thread on that site is. For me, posting a build log is not showing off. I’m fully aware, in the short time I’ve been here, that the talent on this board is immense. How could I possibly be showing off to that talent with such a basic kit? Contrary, this log is about receiving feedback on how I could, and can, do things better. Critique and suggestions are welcome. My wife and I watched the original Lon Chaney silent film a few nights ago, for reference and inspiration. Loved it. I’d seen “The Phantom of the Opera” many many years ago, but that must have been the Claude Rains version, as I know for sure it was not the Chaney film. First time I’ve watched that one. A couple of inaccuracies to point out: The Phantom (Erik) did not have long silver hair, as depicted in the box art. And, if there was any “prisoner”, it was not a guy behind bars. It was Christine, an opera understudy whom the Phantom was obsessed with. And so it begins….. This is as far as I've gotten. I have a bar clamp on order for the right leg. In my, thus far, short scale modeling career, I've become somewhat disappointed in THE hobby store in my locale. It's lacking a fair bit and I've had to resort to ordering online for quite a few items. I don't want to use rubber bands as I don't trust that I will be able to prevent those from coming into contact with the liquid cement. I think I did a pretty good job on sanding the left leg inseam, but..... ....sloppy work on the outer seam of the left leg. Particularly up near the belt line where those trouser folds are. The other pieces are on hold, for now. Awaiting the bar clamp, as mentioned, and also needle sand sticks for the arms on order too. My hobby shop didn't have those either. Me thinks the sleeve folds in the arms are going to make for some tricky sanding. Thanks for looking. Suggestions are welcome. Cheers, Mark
Thanks all. Hamilton...haha....yes...born and raised in BC! Moved to Sask in 2016. Wife has family here. To answer your question...seems Rider fans are generally neutral toward Lions fans here. It's more Winnipeg, Calgary and Edmonton they have an aversion to. But mostly Winnipeg. That's been my observation. Side note: the step son-in-law was born and raised here, but he's a Stamps fan. Says he could never cheer for the Riders. I've met a few like that. I think it has to do with them growing up with a team that was generally very bad when they were kids. Anyhoo....build update.....not much to say. I've still be doing a fair bit of research and planning. I can finally say, however, that I have physically actually started as of tonight. Did some scraping of the mold nubs on the bottom of the hull. Very minimal, so far, but it's a start. I've ordered a underhull plating kit from Maritime Models, so I'm going to leave the seam line on the bottom to help assist with getting that aligned right. I also have the stern counter plating kit from Midwest Model Shop. That arrived a few days ago. Still not sure about the seam line for where that gets laid down. I'll probably sand it down. For sure the seam line on the upper aft stern will get sanded, but not until after I plot the four missing portholes that go there. Next up will be marking the hull for the many corrections identified on the Port side, as well as plotting which portholes get filled, which get drilled and which don't. I'm still not planning on using the LED set, but I have decided to drill the portholes anyway and go with a resin portholes/windows aftermarket kit. My original plan was to use a pencil on the portholes. That plan was based on a tip I came across on the "Trumpeter Titanic 1/200th Model Only Building Tips and Tricks" FB group (sheesh, that title is so long I still don't have it memorized). It's a cool way of simulating glass. Anyhoo, what changed my mind is the distorted portholes on the Port and Stbd Quarters. To fix those requires filling, then drilling. If I'd gone the pencil route, I would then need to back those portholes from the inside with styrene to "colour" them in. Problem with that is they would then be more recessed than all the other penciled in portholes that wouldn't have been drilled out. Hence, the decision to just drill them all and fit clear resin in each one, thus making it all uniform. The actual drilling won't happen until the aftermarket kit gets to me. I want to drill some test holes in styrene and then fit each of the different size resins so as to know the correct size drill bit to use for each of the various sizes. So, that's were it's at. More to come soon. Thanks for looking, Mark
I thought it's time to get my build log started, even though I haven't actually started the build yet. Soon. I've been quite busy with research, planning and start up. Essentially 50 years since I built scale models, so lots to do in preparing for this build. Start up is still in progress. Before anything else, I first off just want to put out a big thanks to Evan, aka Force9, for his very detailed and resources rich Titanic 1/200 build log. I’ve learned so much from his thread, before I even begin my Titanic, and I would have missed so much without this information. Thanks Evan. Okay. Some preliminary stuff.... This was my work station for my Academy 1/400 Titanic. All building, and the limited painting I did, was here. Not exactly conducive to the Trumpeter 1/200 version. My new workstation for the Trumpeter 1/200 Titanic. The pool table is being sequestered for a few years. That's fine. We didn't play much anyway. The son-in-law helped me carry the 4x8 plywood in yesterday. Originally purchased for the electrician to install the pool table light fixture. Stowed in the garage since. Spidey senses must have known there'd be a use for it again. The task lamp is the same one as with the small table. I just drilled a 1/2" hole in the plywood for it. Now it's interchangeable, as I will still be using the small work station. On the left, I put the binder together just yesterday and today. Some inspiration from Evan, again, on that, but I give myself credit as well for recognizing this need. Throughout my entire working career, I have always been about organization. It's half of it. Even as a Deckhand, organization was key. An organized and clean deck is a good working deck. Same goes for building models, I figure. The book on the right was recently purchased online and just arrived today. I'm optimistic this will be a valuable resource toward my build. A closer view of the "build binder". Not sure what else to call it. I'm an older salt, and thus somewhat old school. Digital pictures and screenshots are fine to a point. But, for the most part, I like the physical copy in my hand. Much (probably most) of what is in this binder are digital screenshots. Anyhow, lots going on with startup. My new Airbrush Station. The new airbrush kit just arrived today! And one more pic for now. One problem with the Spray Booth venting is insulating the gaps at the window. Been pondering this for days now (the Spray Booth arrived last week). Stuffing bubble wrap in the gaps proved to be a Mickey Mouse solution. Got the idea of foam in my head as a solution. Placed an order for some poly foam yesterday. It's coming from the US, however, so a solid resolution here might be awhile. Suggestions are welcome. Anyhoo, that's it for now. Lots more to come. I've ordered five after market kits for the model, none of which have arrived as yet. My first approach to the model itself will be addressing the hull. No brainer there, I suppose, but in particular, how to approach the hull inaccuracies and porthole inaccuracies. Regarding the portholes, I came across a tip on Gene Davis' FB page (the title of which is too lengthy to repeat) that I most likely will go with. I like it. I don't plan on using the LED lighting kit for my model and this tip appears to me to be a great option for the portholes for those modelers not doing the LEDs. Stay tuned. In the meantime....suggestions are welcome. Thanks for looking and cheers, Mark
Thanks Peter. Cheers, Mark
Dutch. My Grandfather was from The Hague. Not many of us here on this side of the pond. Cheers, Mark
Yes, Trumpeter.
And how 'bout those Canucks, eh?!
Hello everyone, Thank you very much for allowing me to join this group. Good to be here. I joined MSW a week ago at the suggestion of another member here, but haven’t gotten around to an intro until now. I’m a 62 year old retired Deckhand/Deck Officer formerly with the Canadian Coast Guard of the Federal Government of Canada. I was at that career for 35 years and 4 months. Born and raised on the coast of British Columbia, I currently live in Warman, Saskatchewan (just North of Saskatoon). I moved here in 2016 for family reasons. I am essentially a beginner scale modeler. Here is my modeling story, hopefully in brief……. I just recently finished my first completed scale model build in 50+ years. I had finally gotten around to checking out THE hobby store here in Saskatoon 5 years after moving here. It was an unplanned opportunistic visit. Walked out with an Academy 1/400 Titanic and another much simpler non ship model. That was in June 2022. Both models sat untouched all of last winter. The non ship model was purchased mainly for a nostalgic reason and is yet to be built. I’ll be starting that one soon and I intend to post a build log for that in the Non-Ship forum. There is more than just the nostalgic reason for that build now. It will be a great model to develop skills. Detail painting and airbrushing in particular. As for the recently “completed” kit….that would be the 1/400 Titanic. I started it in early November and “completed” it mid January. I will post some pictures and text about it in the Completed Gallery soon. In the meantime, I just want to say that I started that model without any prior research or a plan. Just dove in, having no idea what to expect after a 50+ year hiatus from plastic scale modeling. It is also the most complex plastic scale model I have ever attempted, by far. I was somewhat disappointed with it, in the end. I attribute this to two aspects. My skill level (essentially a green as grass beginner) and the model itself as manufactured (historical inaccuracies; fit issues; and fine detail painting required where I would have preferred parts to attach). Having said that, I thoroughly enjoyed the process and want another crack at it. Therefore, I’m going bigger. I’ve purchased the Trumpeter 1/200 Titanic. It arrived yesterday 😊. I have read the pinned article “For Beginners – A Cautionary Tale”. I intend to not give up. Many lessons already learned from the 1/400 build, and many many more lessons to come, and learn, and skills to develop. I’ve been researching the 1/200 quite a bit, the last two weeks. I am already aware that it too has inaccuracies. Some of which I will deal with, whereas others I will accept as is. But I digress. This build will not start for quite some time. I will begin a build log on that project when the time comes, but in the meantime I intend to focus on much smaller and simpler builds to develop my lacking skills. One final note….a brother of mine gave me a Corel 1/25 “Sloup”, Modello SM 43, wooden kit as a Christmas gift some 25+ years ago. It is a model of a small French F/V. I still have it. I actually started it, way back, but then after three rows of the planking done, I got to the difficult task of needing to bend the next rows for the hull’s buttock lines where they meet the transom. I tried, but eventually gave up. I learned years later that there’s more to it than simply holding and bending said planks in the steam of a boiling kettle of water, as the instructions indicated. I also learned on this site that difficulty with planking is the single most deterrent to a wooden ship modeler from continuing. That is actually comforting to now know. But I digress. Point being I intend to continue and complete this kit as well, but that’s a few years down the road. Again, thank you very much for the privilege. I look forward to learning many aspects and techniques of scale modeling from the wealth of expertise here. Cheers, Mark Meester
