cdrusn89
Everything posted by cdrusn89
  1. Similarly for the sweep port framing although I did not use any CA on these and tried to keep the glue only where the frame would remain after trimming.
  2. I found the 1/32 X 1/32 material supplied with the kit was "dimensionally challenged" so I decided to use some boxwood I had of the same size. I did the gun ports first, using wood glue along the support or stanchion and a drop of thin CA at the bottom where the gun port frame meets the upper wale. I cut the pieces long and then trimmed to the top of the port using a new Xacto chisel blade. I used the wide blade so I could get both sides of the port at one time. Hopefully this will reduce the chance of cutting them to different lengths. Picture below shows the gun port framing clamped in place while the wood glue sets. As has been said before in this forum "you can never have too many clamps".
  3. Sanded down the starboard side and installed the 3/64 X 3/32 "upper wale". Having previously filled in the gap between the laser cut planksheer and the outer mold line paid off here as there were no additional gaps encountered. Will work on the 1/32 X 1/32 filler pieces around the ports now.
  4. Completed the gun port and sweep port framing. Not a difficult task once I got the hang of it. I tried to keep any excess material on the outside to make it easier to remove before the bulwark planking begins.
  5. Ric - are you going to plank over the sheet wood? I got all the sweeps and gun ports done on the stbd side and hope to get the port side done tomorrow and (hopefully) start planking the outer bulwarks.
  6. Got the gun ports framed, including the canted one for the long guns forward. Started on the sweep ports but trying to cut pieces of 1/8 X 1/8 (or 3/32 X 3/32) to 3/16" in length was "too hard". Try as I might I could not get them consistent enough to keep the port square. So I looked through my pile of wood and found some 3/16 X 1/8 boxwood. So now I cut the horizontal pieces overly long and cut two pieces of the 3/16 X 1/8. I use thin CA to attach one of the 3/16 X 1/8 piece between the two horizontal pieces (on a piece of parchment paper). Then use the template to properly position the other 3/16 X 1/8 piece. I carefully withdraw the template and hit the other side with the CA. Now, I measure and mark the center of the sweep opening and the center of the just created sweep port and using a disk sander incrementally adjust the horizontal pieces until they fit between the verticals. I generally try to keep the material that is in excess of the bulkhead thickness on the outside of the hull to make it easier to remove. I am guessing that getting the inside smoothed out is not going to be as easy as the outside.
  7. Ric - welcome aboard. I have some travel (hate to call it vacation; I am retired so every day is vacation) in August and September that will slow progress. That and the seemingly never ending "orders from Headquarters". Hope to have the hull completed before we leave in mid-August.
  8. Got the 3/32 X 3/32" "sub-rail" installed around the top of the BH stanchions. It takes a decided turn upward at the stern but the build logs I have looked at all seem to have this "feature" so I did not do anything about it - like trying to taper the sub-rail where it connects to the quarter stanchions. I did use some 1/32" material (sometimes sanded down even thinner) to fill in where the BH stanchions did not meet up with the sub-rail. Hopefully I did not introduce problems that will not be evident until it is too late to fix. In the first photo below you can see both the rail fillers and the fillers added to make the planksheer even with the outer hull lines as defined by the BHs. The others show the hull with the sub-rail. It is my intention to sand all the "edge fillers" even with the BHs before adding the gun port and sweep port framing.
  9. Here are the planksheer faring pieces - will be faired along with the rest of the hull after the bulwark planking is completed - need to protect the stanchions before fairing. Also some pictures of the completed hull structure.
  10. Hull structure is complete, waterways and planksheer installed but not yet finish sanded or painted. As suggested in several build logs I have been adding 1/16 X 3/16 or 1/32 X 3/16 pieces outboard of the planksheer to fill in the gap between the planksheer and where the bulwark planking will go. I added diagonal internal supports to the bulkheads after the waterway/planksheer installation to provide additional strength to the center keel/bulkhead structure. I prefer the diagonal reinforcements to longitudinal ones because they are easier to install and do not require precise cutting to "just" fit between the bulkheads. As long as you have the capability to cut precise 45's you only have to get close on the measurement. I used 1/4 X 1/4s that I had laying around from something else. And I only broke one stanchion that I couldn't find the missing piece for - broke substantially more than one that were successfully (more or less) repaired. Next to add the 3/32 X 3/32 piece across the top of the stanchions and frame in the gun ports and sweep ports.
  11. Thought it would be a good idea to drill pilot holes for the eventual mounting screws before mounting the bulkheads on the center keel so I used the drill press to put in two 1/16" holes approximately equidistant from the stern and fwd end of the straight keel section. That will make them centered under the straight part of the keel.
  12. Here is the final version of BH Q before installation on center keel. Added the framing around the gun ports. I used the inner timbers on the drawings as the starting point for measurements. I believe I got the timbers in the correct place. Am not so sure about the quarter stanchions so thought measuring from the center would be more accurate. Will have to wait until the stern is planked to "know for sure" who accurate I was.
  13. Completed the stern structure on BH Q. Have to add the gun port fairing still and will leave the arch board "as is" until planking the stern is completed. Also created filler pieces for BH P and O since I had plenty of spare balsa and it was kind of fun sanding away.
  14. Since there are many sources which indicate that a second filler block between BH A and B is a useful addition I built one and then decided that if two are good, three is better so I made a filler for between BH B and C as well.
  15. Stern filler is considerably more of a challenge than the bow. I had a hard time, even with all the build logs to look at, figuring out what this was all supposed to look like when completed, especially the quarter stanchions. Hopefully I have everything figured out correctly. The first filler block and the stern timers went together "okay". Even with the notches in BH Q and the support beam across the six stern timbers, things did not look very symmetrical. Getting the inner filler pieces "matches" took a lot of sanding and checking. I used a homemade sanding stick made from a tongue depressor with one end squared off and some 80 grit sandpaper contact cemented to it as my primary shaping tool. When I got to the really curvy parts I had to revert to 180 grit wrapped around my index finger.
  16. Bulkhead A and bow filler pieces, knightsheads, timberheads, and support pieces assembled and ready for installation on center keel. Doing this work prior to gluing BH A to the center keel is definitely the way to go IMHO. Much easier to avoid "unintended consequences" elsewhere on model. Here are three views of the completed structure.
  17. The "real ship construction has begun. I fashioned and installed (on the bulkheads only, nothing is permanently attached to the center keel yet) the forward filler block and, taking the advise from several build logs) a second filler block between BHs A and B.I have the knightsheads on each side of the bowsprit (standing in for the bowsprit is the 5/16" X 5/16" piece that will become the bowsprit). Letting this dry (and working on the second cutter). Will add then other timberheads and the laser cut support when this is dry. Filler blocks were cut from balsa wood 2" X 4" X 12" slabs. Balsa is really easy to sand and since I don't have a scroll or band saw that is a good thing. I would not want to try and shape the blocks that came with the kit without a "power assist". Below are pictures of the knightshead and filler blocks installed.
  18. The glue job on the false keel/real keel came out fine, just a few places where the glue needed to be removed. I also marked the reference line on the false keel. Sanded the bevel on each of the bulkheads, removed the bulkhead drawings (mostly), marked the reference line on the bulkheads and the side of the bulkhead that faces forward so the next step is actually putting the bulkheads onto the keel. Am going to reread some of the build logs on this step before proceeding - do NOT want to screw up this part.
  19. John, Thanks - photos are done with iPhone X. I have a Canon EOS 60D SLR but have not gotten clearance from HQ yet for a macro lens so the iPhone will have to do until then. I am going onboard the Niagara for a day sail in September. Have previously sailed on the Pride of Baltimore II as a guest crew. Firmly established that I am no longer (maybe never was) cut out to be a tall ship crew man.
  20. I took the advise from several sources and sanded/chiselled the rabbet joint into the false keel before joining the false keel and the three pieces of the "real" keel. Having done this I clamped the false keel to the workbench added carpenter glue and clamped the real keel pieces to the false keel and will let them set-up overnight. I also utilized 1/16" brass rod for reinforcement for the joint. I will cut them off flush when the glue is dry. FYI, that is parchment paper (with the waxed side up to keep any glue from sticking to the hobby mat. I find parchment paper easier to work with than wax paper, although you do have to be careful to get the right side up.
  21. Here are all the bulkheads with the drawings rubber glued to one side and all the sides marked with which way the face. I tried to use the laser cut-out bevel to advantage putting the longer side toward midships but doubt there would be any great consequence if no attention was paid to the degree or two of bevel that the laser cutting produces. I also rubber cemented to aft portion of the profile to the false keel to show where the bearding line is on the aft portion - the only place it is other than 1/16" up from the keel. I had to make two mirror copies of this too, one for each side of the false keel. Here is what they look like before any sanding is done. The bulkheads without drawings (G, H and I) do not have any bevel so they can go directly onto the false keel.
  22. While waiting for some material to arrive to finish the second cutter I started preparing for construction of the "real" ship. It has been my practice when the bevels for the bulkheads are provided in the drawings to rubber glue the bulkhead drawings to the respective bulkheads and bevel the bulkheads, at least roughly before installing them on the false keel. The less work that is required when the bulkhead extensions (aka stanchions or timberheads) are all exposed on the false keel the better. Unfortunately in this case the plans only show the bevel on one side of the bulkhead drawings. Since I am too cheap to use Adobe Acrobat I had to find another way to "flip" the drawings to create a mirror which would be used for the other side of the bulkhead. My solution was to scan the bulkhead drawings, one by one as pictures (aka .jpg files), import them into PowerPoint (making sure to reset the imported picture to the original size) and then copy the slide and use the "Flip Horizontal" command to create a mirror of the original. Then print out the slides (making sure to uncheck the default, at least on my version of PP, "scale slides to fit paper" selection) and use one picture for each side of the bulkhead. Below are the two pages for bulkhead "A".
  23. So here is the stern yawl finished in a fashion similar to the #1 cutter shown above. The rails are actually white not cream or buff as the look in the picture (at least on my monitor). I added the towing ring and moveable rudder as on #1 cutter. Simulated lap-strake siding created using "O" scale 1 X 4s (approx 0.02 X 0.08). (I just noticed that one of the thole pins on the port side has come adrift - I will fix before putting the yawl in "storage"). Working the #2 cutter and reading ahead for pointers on building the "real" ship.
  24. After several tries I finally gave up trying to build the Niagara boats using formers as shown in Hubert Sicard's site. The major difference in the appearance of boats built using the kit's bread-and-butter material and using formers is the appearance of the planks on the boat's interior (see picture above). However, it turns out once all the internals (thwarts, seats, gratings, etc.) are added there is very little of the boats interior that can be seen. In addition, my attempt at doing the stern yawl and doing the lap-strake planking from the start was pretty much a failure. Using 5/64's wide planks I was unable to keep anything like a consistent (or at least smoothly varying) overlap and it came out pretty ugly (see photo below - the one showing bare wood). Sooo, I decided to use the kits bread-and-butter materials to build the ship's boats and have finished the first of the launches. I made the rudder so it can be detached as I find it hard to believe that the rudder was left attached when the boats were carried in the davits. Wave action (it can get pretty stormy on Lake Eire) could have unseated the rudder or beaten it to death. I also added a towing ring at the bow as I believe these boats were probably towed frequently.
