FifeModels
Everything posted by FifeModels
  1. I tend to agree, and am highly put off with it being plastic. I've a month or so before I need to worry about them yet anyway, so plenty of time for CMB to restock. Thanks
  2. Thanks hadn't seen those. They seem to be out of stock at the moment...but the plastic one below caught my eye as well...but, well, they're plastic
  3. Hiya David. I think it is a UK/Europe series...You can have a look here . (I assume it's ok to link to it here). Re the Launch...I am not quite sure I follow you? I also have a bit of a conundrum and I am not sure how to solve it. Again, from my previous experience with this series, the gratings supplied was quite poor in cut/quality, as can be seen below: Also, the hole size was 2mm, the scale is approx 1:84, the holes seem a little big for this scale. (I would imagine Sailors getting their feet caught if they were this size). The problem I am faced with, the width of most of the gratings is just over 50mm, and I can't find smaller sized gratings that would be wide enough. Caldercraft's gratings for example are only 33mm for a 1mm hole and 45mm for a 1.5mm hole. They do make 2mm holes up to 60mm and the quality would be much better, but I still question the size of the holes at this scale. Any suggestions?
  4. Final post from me today. With the deck, I prepped them and marked the lines of the ribs first, and pre-drilled holes for the pins. I did drill 2 holes per half per rib, but in the end I only used 1 for each as they were a superb fit. Much better than the first version of this. There was only actually two slots I needed to file, and it was the bare minimum needed. They all lined up almost perfectly, except for the Port side middle section; it seems as though that was cut just a little too far right, as the photo below shows. It made no difference to the fit in the end though, and only needed a minor alteration. Before fitting, again I painted off ship the sections for the dummy guns, and once dry, proceeded to fit to ship. I'd also fitted the bow frame and bow formers. Not shown here. Thanks for looking in...again.
  5. Hello again. Finally made a start on the main build. I was trying to leave this as long as possible to reduce the amount of time between waiting for parts, but an eagerness to make a start got the better of me. As I've already posted, I'd already secured the mounting bolts and given plenty of time for everything to dry, so time to join the 4-part keel together and mount it on my crude but effective slip. Whilst that was drying, I took a note from previous experience and decided to pre-paint the frames where the dummy gun decks will be. It just made things easier doing this off ship, and the advantage of knowing where everything is going to be helps too. None of the ribs protrude above the external decks (and those that do get removed later anyway), so I simply painted the entire outer sections of the ribs black using a rattle can. When fitting to keel, I made the decision to use some 2cm x 2cm Pine as braces, to help add strength and make sure they are at perfect right angles. Next step is the first false deck, which I will post about separately.
  6. Good afternoon. Before starting on the main build, I wanted to get another of the smaller tasks out of the way. The first of four Anchors. I won't write much on this, the photographs tell the story quite well. Thanks for looking in.
  7. Good Morning from a non-EU Scotland. More work on the launch.Had another coat of white after the stabilizers were added. Then masked off for the upper colour. I lightly brushed this on and then used an airbrush for the rest. I did end up with a slight bleed so had to mask the top off once it was dry and redo the white. That's it for the launch for now as I have gone as far as I can with the parts available.
  8. Good afternoon. More progress on the launch. After removing the launch from the jig and sanding down the ribs, I began work on the outer hull. I started by giving a light coat of grey primer to help me see the areas that needed work first, then began the process of filling and sanding and filling and sanding. I didn't want to go for a perfectly smooth finish, these boats were made of wood not fibreglass. The final coat of filler was diluted and brushed on. After I was happy with the hull I began with the colour coats. Started with a mist base coat and gradually added very very light coats to build up the paint. Took about 4 very light coats in the end, lightly sanding between them. I've not put the final topcoat on yet as I needed to fit the stabilizers. Thanks for looking in.
  9. Good afternoon. Continuing with the Launch. I finished assembling the frames onto the jig, and after some rather delicate fairing, (and only breaking one rib), I started on the planking. Pretty straight forward job. I did give the inside of each plank a light sand first just to make things easier further on in the build. Once finished, I brushed on 1:1 diluted PVA to help seal the planks, and then a light coat of Admiralty matt white so make seeing the area's need filling easier to see. Today, I applied white wood filler over the entire hull, and begun the process of sanding/filling/sanding...and repeat. Still have some work to do around the Bow, but will know more once I've been able to apply a light undercoat. Thanks for looking in.
  10. Ahh ok. Yes that was the original partwork I had got part way through previously. If you need any pointers let me know, as there are a few things they didn't point out in the build instructions, particularly with the frame for the launch.
  11. Hello again folks. I've been away for a while, life and work gets in the way sometimes. However, Fathers day has just been (UK) and I got a pleasant surprise. A new subscription to Deagostini's Sovereign of the Seas and a new Dremmel to go with it Some of you might recall me mentioning I was building this particular one before. I was, as a 3 year part work. Things didn't go according to plan and...well we won't go there. The advantage of that though, is for a good portion of the series I know what is to come, what to avoid, where to correct my first attempt...not to mention a lot of spare parts The first thing I wanted to do before actually commencing the build was to correct the way I made supports in the keel for attaching to the base further down the line. (Remember me saying we won't go there...). So a quick visit to the hardware store I picked up some steel threaded bolts with square nuts. There are easier to fit into the keel. Before starting on the main build, I wanted to build up the two cannons that came with the first months pack. Previously, I collected the cannons to make them in batch. However I found, personally, that I ended up focussing on the overall project of making 10 or 20 cannons at once, instead of looking at each individual cannon as a project. I am hoping the results this way will be better. Not really a lot to say about this, sanded/smothed/painted the sides whilst still in the fret. I used Ensign red instead of Red Ochre as I found it a brighter colour. As there is no hard and fast historical data on the ship, I used artistic licence and will continue to do so throughout the build. I also primed and painted the cannon itself and the wheels. Strictly speaking the cannon should be bronze, as per cannons of the era, but I stuck with a satin black. Then it was simply a case of removing the truck from the fret, sanding the edges and then assembling it before giving it a final coat. Another advantage of having previously built this/having a 12 month sub is again, being able to skip ahead and see what is to come. I knew I would be having to drill holes for the eyelets, and would rather do this before the truck was assembled. Finally, I put everything together and made the first parts of the tackle to go with them. With pack one came the first parts for building the ships launch. I always like these from Deagostini as they are almost like mini kits. The first time I did this didn't turn out too bad, but I knew I could improve on it by tweaking the order in which I did things. The first change was sanding/smothing/painting the ribs before fitting to the assembly jig. I've started on assembling the frames...and that's where I am upto so far Thanks for looking in.
  12. Hiya Kevin. I took a break from this to build a car. (Don't ask lol) I have just dug her back out though so will be resuming work on her shortly.
  13. Afternoon all. Sorry such a delay between posts, I've not been able to achieve very much due to illness and inconsiderate children getting in the way haha. I've made a start on the long process of coppering the hull, not much to show just yet though...
  14. Evening. I've finished all the lower gunports and this afternoon I masked off and sprayed the lower hull, first with a primer then black upto the first yellow band. Few areas need touching up as the last pic shows, but nothing major.
  15. Keith, forgive if preaching to the choir on this, but frog tape to mask, then paint again with the colour you are masking to help "seal" the masking tape, then once dry apply your second colour.
  16. That was my original plan as well but I am tempted to brush on the black...
  17. Thanks Kevin. I've decided where it comes to painting/linging the gunports and painting the ships sides, I am going to work deck by deck. It just breaks up the work a little for me. I've applied two coats of Admiralty Yellow Ochre to the lowest gun deck, allowing more than is needed so the black bands can go over after masking. Is she yellow with black stripes though, or black with yellow stripes...? I've also used filler to extend the whales into the q-galleries.
  18. Hello. I've corrected the upper whale on one side, again as with the lower ones was quite a simple fix, I was even able to trim the lower edge off cleanly enough to be able to make use of it along the upper edge. I know pics below are from opposite sides, but they were both the same with the same fault, so show the difference before and after so far:
  19. Kevin yes I think that was my mistake as well. I did try to take into account the plans were flat etc but clearly not enough. I was pretty much taking a reference point and holding a straight ruler and using line of sight to mark...how I ever thought that would end well is beyond me lol Gary it does, thanks. Confirmation is key. *sigh* Means I have yet more trimming/filling to do
  20. Thanks Kevin, looking at that mine are about 2mm too low amidships. The lower edge of mine touches the upper edge of the middle row of gunports, where as yours are above them by about 2mm(ish). Gives me a better frame of reference to go by, thanks.
  21. Thanks Jerry. I did think afterwards that the curious way the yellow bands are painted might have the effect of lessening out that curve, and maybe it is because it is unpainted that I am thinking it looks wrong. Now someone else has basically said the same thing, makes me feel better. Cheers.
  22. Afternoon. I've finished adding the whales on either side, and on one side so far tidied them up, partly filled any cracks although not completely. (The real thing isn't made of fibreglass after all). Obviously I still have a lot of work to do on the ports...but I would like opinions on the upper whale. To me it looks too low in the centre. It measures up correctly going by the planks but still to me it looks too curved? Could just be optical illusion based on the direction one looks at it, I don't know.
  23. Thanks for the vote of confidence. It actually wasn't as much of a chore as I thought it was going to be. Trimming the lower edge was easy, for the most part the strip came off with little damage to the underlying planking. I think filling the resulting gap on the upper portion was the most fiddly, and will no doubt need redoing before work on the hull is finished. Pics below. Needless to say everything is looking rather rough at the moment.
