ASAT
Posts posted by ASAT
I then started on the deck house / companionway - made a drawing and shamelessly stole the one from Blackies build, not sure if that style is in the older kits or not but I liked it so I went with it. It took me the better part of a day to do it, made a shell from some 1/16" ply and then planked over it with bubinga and redheart framing accents. Was a pretty fun little piece to do...
Been working on the the deck layout some more, I made some more gratings with smaller grate holes .... and made a pump setup from some various parts I had laying around. I used some brass eyelets and straightened the flange for the lower section and glued a little brass fitting on top of that then drilled it for the output pipe and the actuator rods. I decided the stove location would be under the fwd hatch/grate so I stuck the kit chimney pipe in that one and made the large middle hatch a combo grate and solid removable boards....
Shawn, you can try wetting it and weights, it will need to be pretty wet depending on how twisted it is. You could also try blocking the keel/bulkheads aif the twist is not too severe. If all else fails, make a new one from some plywood available at hobby stores. maybe post a pic of the keel twist to give a better idea how to best proceed....
bevel the edges of the plank during the fitting process, soak em, use CA and force them as close as you can when gluing, and then sand the sh1te out of them...
I use my Byrnes table saw the most.... I also use the thickness sander alot. The disc sander is a jewel.... I also have the proxxon wood mill and I have only used it a handful of times... If you ever progress beyond kits, or want to use upgraded wood to enhance a build you will be glad that Jim Byrnes is around. I have abused his equipment for 10 plus years and they are still precision pieces of machinery - cant say enough good things about them. To see what is possible to achieve with those tools, see this thread,..... http://modelshipworld.com/index.php?/topic/3345-harvey-by-asat-al-scale-150-kitbash/ all that wood was made using Jim Byrnes tools....
Well it took me two days (nights) to build a windlass - this is the first one I have ever scratch built - I used some gears out of my rc servos and found a handle/lever in another kit I have for parts - I can't decide if the overall size is too big, I didn't have any plan to go by, so I used the pictures from Kruginmi and Blackies Harvey build logs....I reduced the size 3 times and I think I am just gonna go with it -maybe I could reduce the height of the side posts? Also do the spindle ends need some kind of "cap" or are they OK sticking out like that? Comments appreciated.......
Jim, those strakes are looking great, the nails look awesome and the symmetry of their spacing really enhances the look. Nice work!
Jim, I saw your post yesterday and I have been thinking about you - hope I don't offend you but I have been praying that you will find peace and be comforted in this time of trial.... that your doctors ease your suffering and that you will have more days of joy than not. Also that you have loved and have been loved, and that you will still be able to celebrate life with those that are nearest to your heart and for all of you to have strength and courage as you persevere through this formidiable time.
Lou
Floyd, I will post a few pics when I get home tonight, the false keel was cut that way from AL
Mark, I thought that the stove was actually "offset" to starboard under the deck and there is a 45 degree flue that connects it to the exaust stack on deck which needs to be out of the walkways - those designers are most creative!
Thanks Guys, appreciate the kind words. The rudder box was just a way to cover my mistake when I drilled the rudder stem hole incorrectly I could have used a large diameter ring but I thought the box looked better.
I saw something similar to that done on Fly or Pegasus and thought it was a good solution for my ham fistedness - I will probably put a "lid" on it after I replace the kit tiller with a carved one and rig it. And yes, I have been putting off drilling that bowsprit hole, although the planking is boxwood with pear bulwarks so it will carve fairly clean if I go slow!
Not sure about your planking curiosity Floyd, it's pear which is a treat to work with and finishes beautifully - bends fairly easy too. The "depth" was just the way the center keel was cut in the kit - probably because the kit supplied gratings are more like window panes than grate holes - I plan on replacing the gratings as well - those fittings forward in the pics were just placed there, not glued yet... but I like the stairway shaft idea Mark used - I may borrow that as well!
Lou
Mark, I know you are having fun with your Lady Anne, but your results sure are appealing so I hope you don't mind a little "flattering imitation?"
Wow, those pens are cool! I love wood and the neat stuff you can do with it. I made my kids some memory boxes using exotic inlays for Christmas one year - was a great project. Hopefully I will be able to give them all a shipmodel to remember me by as well....
That bow area is sharp! I love that decking reinforcement and that windlass just looks good from any angle. I think I will do a combination of chamfering and using the stub bits as well..... hopefully I will have some more to post on my build soon. Thanks again!
Lou
Mark, I thought I would work on the bowsprit before doing the windlass, to see how much room is available for it. I am wondering how you have the bowsprit located? I cant really tell in any of the pics if the end of the bowsprit penetrates into the deck or is it just trapped by the stub bit? Also is the deck end of the bowsprit chamfered to match the deck if it does not penetrate into it?
Lou
Mark, that is what I like about MSW as well, lots of info shared by all.
I was hoping to do a windlass similar to yours but Ithink I may have to go with something a bit simpler, something like Blackies(another harvey builder) I don't have a lathe so I will start with a dowel and see what emerges. Keep posting your great pics, that's one area I need to work on,my pics don't come out near as well as yours. Any tips for that?
Lou
Glenn, glad you are back at the workbench. I agree with your sentiment on the loss of your FA and Pegasus logs - they were an unparalleled definitive work with beautiful results. Shame to lose that resource. BTW - are you going to post any FA pics in the gallery?
I prefer the use of wood over paint on my models, influenced greatly by your FA work. I am looking forward to your rendition of Vanguard, I think the stub masts will enhance the beauty of the wood choices and allow the eye to be drawn to the details you are so good at producing but sometimes get lost in the midst of the rigging.
At the end of the day, we do this to enjoy the process as well as the result, and in my mind there is nothing wrong with "pretty".
Well I asked KruginMi to re post his Harvey kitbash as it inspired me to do one, and he did, he also asked if I was going to post a log so here it is. I bought the kit in a kind of online garage sale - it must be a new version as about the only thing I wanted to use is the bulkheads and metal work/fittings. The kit came with alot of stuff pre made which looks pretty shabby so I am taking free licence to do it the way I want..... besides I am not a real stickler for historical accuracy - I like the way the woods look together and I give most of my models away to people that wouldn't know or care about the accuracy but they seem to enjoy the models..... I have substituted the kit wood with Boxwood, Pear, Holly, Bloodwood, Redheart and Bubinga so far. I'm still trying to work out the deck layout - this is where I was awed by Krug's version and I am deciding how much of his ideas I want to borrow? currently the model is at this stage....
Thanks for posting this Mark, I just may have to get that Crothers book, awesome to see what can be done with the application of talent. I don't know if I want to show mine now
Harvey by ASAT - Artesania Latina - Scale 1:50 - Kitbash
Also added some "fashion" pieces to the stern area to kinda tie that all together - and a few shots of the current full deck layout..... Still need to build a capstan for it - will be placed between the two grates....
