gdollow
Everything posted by gdollow
  1. Here is a new build, the Bismarck. All I can say is that this is one kit that needs photo etch as there is very little detail. I would expect more from Tamiya. Anyway here are shots of the sprues
  2. I have rigged the fore mast. The pictures make the rigging thread look thick, but I am using the fine E-Z thread.
  3. Thanks I will see what my local fishing tackle shop has
  4. Slog, This model is 56 cm long, beam of 10cm and overall height 23cm
  5. Here is an update. The bridge is now complete, just need to paint, fit and rig the fore mast. There is 20-30 pieces of PE in the fore mast.
  6. I agree, it wasn't until I started building this model that I discovered its history. Should have been a floating museun like the HMS Belfast
  7. More progress. I bought an oerlikon PE kit, but the gun body was so delicate, that I could not bend it without breaking it, so I used the bases of the pe kit and use the plastic gun body. BTW to show the size of the oerlikon guns, I have put it on a 5p piece. The last picture shows the first bit of superstructure and the rigging of the booms. I am using E-Z thread for all the rigging.
  8. This is my progress so far on Academy's HMS Warspite special edition. It comes with extra PE and gun barrels. I also bought extra PE oelikons and pomp pomp guns. he oelikon body proved too delicate for me, so I used the shields and bases and the plastic gun from the kit.
  9. Here is the deck, the hull should be completed tomorrow, so I'll post a picture when done. The catapult is only placed on the deck, it needs a top coat.
  10. Al Thanks for the link, it's an impressive diorama. I've ordered the profile morskie book and plans for the Warspite. I might be a bit sad, but I like looking at ship plans Graham
  11. Thanks I'll have a look Graham
  12. Thanks CaptainRoger, very much appreciated. I have been looking every where for this. Graham
  13. Thanks Jim, I'll try fine EZ-Line or fine copper wire
  14. Thanks, Do you know the diameter of the cables or the diameter of the rigging material I will need to use on the model Thanks
  15. Hi I will be starting the Acadamy 1/350 Warspite soon and I cannot find any rigging plans for this ship. Does any one who has built this model know where I can get information on the rigging. Also what is the best material to use for the rigging and what thickness of material do I need? Thanks Graham
  16. Thanks, I'll pro ably use the IJN railing. I have found some USN railing at 1:500, which will be slightly under sized.
  17. Hi I have just bought the hasegawa USS Missouri, and I want to add photo - etch stanchions. At this scale all I have found is Eduard's IJN and Kreigsmarine railings. Could some one tell me if these would be suitable. There seems to be plenty photo etched stanchions at 1:400 scale. Would these look OK or would they be oversized? I did manage to find a wooden deck overlay, which I will be using. When this and my paints arrive I will be starting a build log. Thanks Graham
