Adrieke
Posts posted by Adrieke
  1. for the doors i have tried a few times to bend the 1x4 sapelly to get the curved top but its to sharp an angle and too small a piece
    i ll give it a go again with the electric plank bender (soldering iron) but i am not sure if i stil lhave enough of the wood left
    i tried with a solid door (2 strips of veneer glued to the metal door part) it needs a doorknob to finish it off
    doesnt look too bad
  2. vrolijk pasen
    just drop by at my place whenever you are in Sydney :P
    well after checking i am happy that i did make the hole at the right place.
    but i have to think about if i am going to cut all the holes (about 20 on that deck ) as it nos easy
    anyway i finalised 2 of the windows and put them in a partialy planked part of the stateroom
    far from perfect but the best i can do at this moment
    making the inside cross the same as the gratings i gave up on as the sapely wood brakes and splinters too easy
    so i ll be making 2 pieces of 5 mm and one piece of 7 mm and line them up in a cross
  3. i ll be going with the 4 panes John . you just won a year trip on the kom washing windows :P
    John when you start on the outside railings be very careful. i made a copy of the plan to cut and use as guides to mark where the vertical 3x3 dowels need to go
    i tought to be clever and make holes thorugh the deck so that the the lower 2 decks is just one dowel. after cutting the hole i notices that there was somethign odd with the spaces between them on the plan.
    yup not all spaces are 35 mm wide. at the front the middle one is way longer and the 2 next to it or slightly longer. since the brass railings are only 35mm we will need to cut two halves and join them up.
    i hope i didnt cut the hole in the wrong place. i will find the round precut top of the railings to make sure
  4. did a bit more finishing work on the 2 nd deck light construction
    the top bit holds to the bottom bit with 3 bits of wood that wedge into it
    the top wil be painted black so as it wone be too visible from the ventilation windows
    when studying the plans i noticed that the outside railing of the first 2 decks will be at an angle
    this because the decks get progressively smaller.
  5. welcome aboard Barth :)
    i saw on Johns topic he has already listed the many errors in this build. nothing is really dificult too overcome certainly  since you already have build some ships
    never read Mark Twain but i am sure its on my ebook somewhere as a free download
    both John and me wil look anxiously out for your build log
  6. thanks John
    have finished them all today :D
    same railings as me then. i think 63 is just enough for all the outside railings and the stair railings
    the 6 for the smoke stacks i ll do with the other ones
    now i made 2 differnt inside frames for the windows. i have already adked the fmaily and all 3 went for the same one
    so its already decided but any comments on which window you like best: the ones wiht 4 or 6 little panes
  7. thanks Sjors
    yes i am gettign in a good routine now :)
    thanks  John.
    yes i ll be using the shutters :
    yes i checked and i need 24 windows in total. but i appreciate mentioning it :)
    i paint manualy too and yes there are probably a few drops to clean up later on but this way its a lot quicker
    Hello Carl
    i ll sure to follow your advice next time
    OK so here is how i am making the outer frames of the windows
    first cutting them too size. i made some marks on the mitrebox so i dont need to keep penciling off the length
    i push the top and bottom in the mold. they fit tight enough to not fall out
    then i push the two vertical ones in after dabbign some glue on the edges wiht a toothpick
    after waiting a bit for the glue to set i use the other part to push the frame gently  out of the mold
    stacking them in a small container to finish drying
    the procedure for the inner part in the next episode ;)
    i am a bit concerned wiht the brass railings. i noticed that they are not all the same.
    there are 63 plain ones. about 5 that have an extra horizontal part and 10 that are the same as the 5 but without an outside vertical part
    calculating i need about 70 railings and if you look on the pictures they are all the same type.
    not sure how difficult it wil be to cut off the vertical bits
  8. hi Carl
    the railing bars or only like 1.5 by 1.5 mm wide so no chance to put a dowel in.
    i am leaving it for now. thtas what i usualy do and then think about it and eventualy get back to it and finish it :)
    the same with the scratch build windows . the procedures i worked out wherent working  so i left them
    now i am back at them.it took me about an hour to make the first window and its not perfect but i feel like its going to work
    i will take some pictures of the little jigs i made to make it easy to make them consistent
    i remembered i stil needed to put a coat of paint on the brass railings. i need a few of them soon
    i bought a test tube of ivory white and its been fine but today th epaint wouldnt come out until i pushed a bit more and all of a sudden half the tube splattered out . not to waste any of it i decided to paint both sides at the same time and hang it out to dry ;)
  9. thanks for all the replies
    i know a lot of tools can be used for more as they are intended.
    most are just a motor that rotates a shaft with something at the end to attach certain tools.
    yes i dont want to waste money on unused tools
    a big part of building is cutting pieces to a certain length so a simple setup to do that would be a big help
