Amalio
Everything posted by Amalio
  1. It's just passion and being very demanding with yourself.
  2. It's a pleasure to see you work again.
  3. Thank you............Guauuuuuu.
  4. Hi Gaetan. The lighter wood that appears in this model is boxwood, which in Spain is known as Amarican boxwood. The darkest wood is cherry. As for the finish, the only thing I give it is what is known here as filler. It is a nitrocellulosic primer that is given to wood before varnishing it. It dries very quickly and sands very well and is colorless.
  5. The lathe has nothing special, it is of Chinese origin and has a distance between points of approximately 40 cm. Not bad, but there are much better ones. Any machine does nothing by itself. It all starts with a mental process depending on the means you have. First you do it inside your head and then it's easy.
