MikeB4
Everything posted by MikeB4
  1. The warm weather is back so I can go down in the basement again and continue my build without freezing to death. I completed the Installation of the frames and friezes. I'm 2/3rds of the way completed after 7 years. One question I have is when I install the resin parts should I use super glue or is there some other type of glue I should be using?
  2. This is certainly turning out to be one of longest projects I've ever done. I guess all that matters is that I'm still making progress little by little. I got the inside planking in place and now I'm in the process of smoothing everything out with filler where needed. I've had many different emotions about this build including giving up all together, but I can say at this time I feel pretty good about where I'm at with this kit.
  3. It's been awhile since I posted anything but I have continued this build. I've completed the thwarts.
  4. I completed the Stretchers. I did notice that a few of the cross members are a different size. I probably used pieces of wood that were meant for something else. Not a big deal.
  5. I may give this another coat of paint but I think this is as good as I'm going to get it. I'm pleased over all with the results at this stage in the build and I can only get better as I progress (Hopefully). The real work here was I didn't want to adhere anything directly to the paint, So I had to carefully remove the paint from any areas that I would be applying glue to. Needless to say this is quite time consuming and a bit challenging for me. I realize there's going to be a lot more paint removal thru out this build so patience is a virtue.
  6. With much tweaking I finally got the back bench installed. I'm pleased that the angle of the bench matches the Drawing. All that's left for this section is to fill in the gaps and paint.
  7. I decided to change the suggested building sequence and put the coxswain seats in first. it just seems easier to remove the paint where they need to be glued to the panel Also it's easier access to paint them before putting the the bench seat back in place. I also added some bracketing in order to have some surface area to glue the back seat in.
  8. I finally installed the actual benches. I put in some filler where needed so when I paint it hopefully it will cover a multitude of sins. There were some challenges for me but over all I'm satisfied so far. the back of the bench is going to have its own challenges with fitting and gluing it in place.
  9. I'm working out the dimensions of the benches using bass wood pieces first. once I get it to where I'm satisfied (Certainly not perfect) I'll use the bass wood cut outs as templates to shape the cherry cut outs that are provided in the kit. I'm going to take my time tweaking in each angle until it's close enough to what I feel will work. There's nothing a little filler can't take care of anyhow.
  10. I finally got my Serv-o-matic apparatus built after buying it about 2 years ago. I realize I have a lot of models sitting in my closet that need building. While working on the Royal Barge I'm prepping for my next project when this one is completed. I'm leaning towards building the "Private Armed Schooner (Lively of Baltimore 1813)" from The Lumber Yard for model shipwrights. This seems like it will be a good kit to progress to the next level in my journey of model ship building. Although lively isn't technically a ship it will be the first time I'm tackling a fully rigged vessel with a canon. But I'm only half done with the barge and I'm in no hurry to get it done. I made that mistake two years ago by giving my self a deadline because I wanted to enter it into a show. So the lesson here is, slow down and take your time. At least I got the Serv-o-matic built in preparation for my next project what ever it might be.
  11. I'm almost back to the point I originally started from. There's still issues but by fairing a little more the benches look like they will finally fit much better.
  12. After putting this model away for a couple of years I'm ready to try and correct the mistake I made. When I got to the point of putting the rear benches in place I found that I didn't fair the inside frames enough and would have to tear down some of the build I had already done. Needless to say I was completely discouraged and just put the model away. I'm now ready to look at it again. As you can see in the picture I removed what was needed in order to start sanding down the frames to where they need to be.
  13. I'm going to pick up were I left off. I got discouraged because the rear benches are off as far as the measurements go. I think I might be able to alter things a little, but I should be able to complete this model.
  14. I got some more work done on the rear bench. It was a little tricky getting this to square up but so far I think I'll be alright. I'm also using chuck's method of painting which is to apply many light coats rather than applying one or two heavy coats. when you slowly build it up it looks much better.
  15. It's summertime and it's hard to stay in the house to build models. Since it's extremely hot out I found some time to stay in the cool house and continue my build. It's slowly coming along.
  16. I've made my first attempt at carving one of the blanks for the Royal Barge. It broke on me.
  17. I'm going to follow your progress. I have a servomatic machine also that I need to put together.
  18. Thank you. My next build is going to be the Mayflower. On Saturday I want to buy all the rigging and blocks from you to replace the supplies given in the kit. What did you use for pedestals and are both the same height rather that off set?
  19. I completed the task of inserting the nails (fishing line). Unfortunately I'm not going to have this model anywhere near presentable for the model show on Saturday. I regret not starting this model last year maybe around June. That might of given me enough time to complete it. With that said, overall I'm pleased with the build up to this point.
  20. I've got the cap rail installed and sanded down. Not a perfect job by any means. I took a little to much off on the forward starboard side. I don't think it's a deal breaker but I wish I could do it over again. It's a learning experience to say the least. I only have 23 days left before the model show. I will need to work on it everyday until the show.
