juhu
Everything posted by juhu
  1. Excellent, being an oyster or other creature, would be almost happy to be in there
  2. Hm, if I understand it correctly, the massive block would be an option - to fix the bulkhead and then make a hole for the mast. Although may be not necessary. If you keep the bulkhead in place with some soft wood block or better balsa framing, you ma just need to make a cut for the mast in the bulkhead, just like it is done in the keel... difficult to explain in words
  3. Hi well, photos may be good, as I understand the problem, yes, your solution may work, I quite liked the one proposed also in the kit - cut in the keel to fix the mast. But softwood box may also suit. Hm, do you think it would be possible to share some photos of this plan_ just to get an idea_ I think I do not have this one. At least I see for example scuppers on the side - nice detail omitted in the klit and also all plans. I do have three Doughty§s plan of +á+ť, but the cover art of our plans looks great and much better than for example the one on the Alert§s box - I believe these plans are very fine. How much pages is there in them? What is the content? Edited: sorry, I was blind, I see this is somewhat different plan that the original "triple" we were talking about. Ok, anyway, any info of the content is welcome
  4. Greetings and congratulation! Sent you a p.m., those plans are of my greatest interest!
  5. Hi Chris, well, your supply of Chapelle's books is much larger than mine . Yes, I do have a copy of American sailings ships plus some other newer sources regarding these particular vessels. Just one correction: I am not saying there was no SMALLEST 31ton cutter built. Fact is, we have no full list of vessels built on those plans. Fact is also, that those vessels we know are based on Doughty's plan are all of the two larger designs. One interesting point: only the smallest of the Chapelles plans calls for a carronade as armament. Both larger plans had drawn long guns. I am just thinking why, lets speculate a bit, since we have no clues: Carronade is in general lighter in weight than long cannon, more suitable for a very small boat. However it has also lower shooting range, is less accurate. It is more devastating in close combats. But look at this plans. No bulkwards, just rope railing. Doughty's design can hardly be called a fighting vessel. It is built for a speed and agility. I also guess, for this purpose the long range gun is more appropriate equipment, if the ship size allows it. If you are going to rebuild this kit to a larger design, I would definitely not use a carronade but a long gun on the deck. Actually, this was also my plan, to "enlarge" the design.... but. Now I see the main problem. If you search here on a forum, you will find beautifully built Alert. But the hull lines comparing to the plans looks very "strange" . I am just hasitating to construct the whole new hull to make it look somehow more realistic... Also not sure what to do with the kit. Will send also PM...
  6. This is a gem. I love to see that modeller's "surgery" when the cabin , doorway etc. is open - it makes the ship more lifelike. Will follow the thread closely.
  7. Hi Christian, thanks for a nice welcome. Actually, I have been present on modelshipworld for some time. But was inactive for a period and after the web was redesigned some time ago, my account with posts was deleted? Shame, there were some interesting discussion and threads regarding other kits'historical accuracy. And before that I was active on now dead drydockmodels, where I have posted my research regarding these revenue cutters... also lost. Nevertheless, I am here and now more watching than writing Regarding the Krick's Alert, this is really old model kit and yes, if one seeks the historical accuracy, better to go elsewhere. But this is pretty same with ALL available commercial kits of this vessel type (they all seem to be based on those same old plans). So yes, making a firewood out of it is an option. On the other hand, if you take proper literature (mentioned Peterssons book for rigging etc.), you can improve many errors at least as far as the sails and threads are concerned. Some of the other things are easier to correct (wrong masts height), some can be more of trouble (problematic hull lines as seen on your shots comparing to the plans). But then again, from the sources it is clear that even if the particular vessel was built on Doughty's plans, it can vary in dimensions, tonnage etc. In turbulent post war times I think this is nothing special. So you can use this kit as a base and build the model of the smallest Doughty's schooner and your representation can be quite faithful due to the above mentioned deviations of the real vessels. To say the truth, there is no evidence (I am not aware of at least) that there was a ship built upon this SMALLEST 31t Doughty's plan. I have my theory that it is possible that only those two larger designs came into the life, but this would be another discussion. Anyway, decision is up to us, personally I also think of putting this kit away and to buy some better kit of another nice schooner (what a shame Model Shipways is not easily obtainable here in Europe!) or may be at the end I will try to make something out of this one. If possible, I would be very interested to see the Doughty's plans from Chapelles book to be compared with bulkheads from the kit. As I see from the photos, keel seems to be pretty off? I am afraid if the bulkheads are too, correcting the kit may be like a total scratch build I am also keen on seeing how you rebuild the hull - if you make a new bulkeads and bash the keel to match the plans, then also the deck piece from the kit will not probably fit etc etc.... quite a lot of work... Juraj
  8. Hi, found this topic and as I am also the "happy" owner of this kit, I would like to share some thoughts. First of all,I am really keen on history of the real vessels. I spent literally months comunicating with various people and institutions including historical department of US coast guard (former US revenue service). Once upon a time I published my research on already dead drydockmodel forum, may be some of you remember it. So, just a very very short summary, if interested, I may provide more details on request: - let's distinguish once for all between the BRITISH cutter Alert on 18ct (described in ship's Anatomy book in the first post of this thread- this was one mast vessel of french-origin cutter design) and here discussed US revenue cutter based on Doughty's plans- this is an example of two masted topsail schooner, extreme type of so called Baltimore clipper. - Italian plans used by Krick (and alas, more other kit manufacturers) are very old, innacurate and contains many errors in (not only!) rigging, hull lines etc - W. Doughty created three designs of plans upon request as correctly mentioned here. The plans are preserved. But beware of the two facts:1. The list of vessels built on these plans is not known. Although we do have some evidence that particular ship was built on the plan, the list is not fully complete and because of fact two: in turbulent years after the War of Independance, the plans, although given and ordered to follow, were not followed strictly. This can give us "advantage" : nobody shall blame you when your model does not represent the exact Doughty's design, although it should have been built upon it. - Nevertheless, the italian plan of Alert contains many factografical errors in rigging and other stuff, that you can hardly excuse it just by this explanation. - Italian plan of your "Alert" (and also mine ) is based on the smallest 31 ton Doughty's design. I will skip now my research regarding the fact if ANY real ship was built on this smallest design and will focus on Alert: - Although you may find some POSSIBLE references to USRS cutter Alert in older resources (e.g. Chapelle's American sailing ships), this is wrong and corrected by later literature (Caney) - As you correctly observed, Alert of 1818 does not match your plans (75 tons, 4 ports per side...), nor Alert of 1829 matches (sorry, but that is the fact, can provide you with resources, if tyou wish) Summary: 1. Krick's Alert is based on very old and full of errors italian resemblance of W. Doughty's plan 2. Due to the fact we have no exact vessel naming list, if you study carefully the literature and various guides (again, may offer some good resources), you can build up a good representation of 31 ton Doughty's revenue cutter out of this kit. It is marvellous! 3. If you care about historical accuracy, do not try to connect your kit and built with any particular vessel (and by no way with any "Alert" ) of USRS 4. By no means do I want to discourage you, I own the same kit, unassembled, and spent too much time searching informations from various sources, I am just sharing my knowledge, nothing more. Will be interested in your build log and will gladly help with any info I can provide.
  9. Hi, well, just some summary. Please, mind, I am just keen on history of tall ships and so I always try to find out as much historical background as possible. I was thinking of this kit for a long time, then decided otherway (with a pity!) for various reasons: Lynx had rather short career, no chance she fought on any "Great Lake battle", as stated on many sellers web page. She was a trader, not a warrior taking prizes, unless the circumstances were extremely favourable. Presumably she made just one journey to France and back prior her capture. But thanks to this short career, she was taken and most importantly her lines were taken off by British and to these days it is then one of the best documented Baltimore clippers. And truly beautiful one. Mind, there was also another schooner Lynx built during Revolutionary war, but this is another story... So, some points: 1. there is a sailing replica named Lynx (search web, sure will find it), but other than the name, there is little resemblance, the hull is totally differnet, althought the famous name is probably a good selling point Just to be aware, it hardly can be used as a reference for built of the historical Lynx http://www.privateerlynx.com/. Search also for "Mosquidobit" - under this name she was used by Britain and you may find some references. 2. There is a lot of details missing on the model, the most eye-catching are no ship boats I guess. As a reference, I would recommend old but still very helpful book by H.I Chapelle "The Baltimore Clipper - its origin and development" where one can find detailed drawings and description of this very ship. Also, for a good looking model you can ask Smithsonian's, I guess they do have a plans for this boat and can provide you weith a copy? One vay or another, here is a a nice representation: http://amhistory.si.edu/onthewater/collection/TR_323263.html As you can see, boats are there, missing in the kit, the deck cabinets, ladders etc does not match the kit, gunport lids are missing, capstan was fitted by British and should not be visible on the deck when building american Lynx etc etc.... 3. What I see as the most problematic part, it is the aft section, just hull around the rudder. It is hard to explain, I do have some copies of the original Lynx plan, just comparing them to the kit reveals the angle of the rudder is off and am afraid, the hull shape is than somewhat weird compared to the plans. May be you could compare it with your plans from the kit box? Please note, this is the original plan as taken in England, so already fitted for RN service with capstan etc. Please, do not take this as a criticism, I am aware no kit is perfect, I am just too focused on accuracy of the kit, where it is possible to compare it with the real ship or its verified plans, prints etc. If any questions, feel free to ask. Good luck
  10. Okay, will check my resources when back at home and post my thoughts soon ...
  11. Will be watching this thread. I was considering this kit for such a long time. It is a shame that Baltimore clippers, probably the most beautiful tall ships, are so rarely represented by wooden ship kits. Unfortunatelly, comparing this particular kit with the blueprints reveals some problematic parts that differs from the original. Particularly aft section. Anyway, I am interested in deck fit, particularly the carvature, from what I have seen earlier. Good luck, if interested, can provide some materials on this ship, although probably you have got them already...
