Greetings,
Typically, topgallant yards do not use a pendant with a block to which the braces are attached. The braces attach directly to the yardarms, run aft to single blocks attached to the topmast stay, and then down to a fife rail, pin rail, etc., port and starboard. It seems to me that, instead of the one single block for each brace, one double block attached to the topmast stay could be used. Each brace would have a separate sheave so each brace could still be hauled independently. I look forward to hearing your opinions on this matter.
wq3296
I've never seen a description that uses a double block as opposed to two singles on a span to the stay.
Hi wq;
It may be a bit too late to add my thoughts,  but here goes:
the braces approach the stay from different sides,  with an angle between them.  The sheaves in a double block are parallel,  so the ropes need to approach with no angle between them.  Blocks on a span can swing to match whatever angle the brace approaches at.
All the best,
Mark P
Previously built models (long ago, aged 18-25ish) POB construction. 32 gun frigate, scratch-built sailing model, Underhill plans.
2 masted topsail schooner, Underhill plans.
Started at around that time, but unfinished: 74 gun ship 'Bellona' NMM plans. POB
On the drawing board: POF model of Royal Caroline 1749, part-planked with interior details. My own plans, based on Admiralty draughts and archival research.
Always on the go: Research into Royal Navy sailing warship design, construction and use, from Tudor times to 1790.
Member of NRG, SNR, NRS, SMS
