Hi all.
I'm building the San Francisco II and need some planking advice.
This is my first time with single planking.  The planks are mahogany, 2mm by 5mm.
The instructions show the planks as being laid in one length.  This seems wrong to me, both because I don't believe the ship would have been built like that, and also because it will be extremely hard to do with 2mm thick planks.
Here is a section of the plans:
So, my question is which way do you think will be better, sections or full planks?  All opinions and advice welcomed!
Thanks,
Brett
Hi Brett.
These are the best Tutorals that I have seen.
I have a hard copy of this in my folder I refer to every time I need to do planking.
The template I printed onto OHP acetate. Bends nicely and lasts for years and you can see what you are doing.
First one is the Tutoral.
http://modelshipworldforum.com/resources/Framing_and_Planking/Lining%20Off%20your%20hull%20for%20planking.pdf
Second one is the Template.
http://modelshipworldforum.com/resources/Framing_and_Planking/plankingfan.pdf
As fare as the length of the planks.. It makes it harder to use short lengths But the finish will be Soo much nicer.
You could always fill between the bulkheads/frames then you can use random lengths as you build as the ends of the planks will have something to support them.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
