Working on thinning down the bulwarks on the Harriet Lane and wonder how thin it should be brought down to.The plans call for 3/32nd but I wonder if it should be thinner.
Edited by Lucius Molchany
Depends entirely on how thick the originals were.  If the plans say 3/32, then that is probably the correct scale thickness.  Since the kit is also in 3/32" scale, that indicates bulwarks 1 foot thick, which may be about right.on the original.
I can't answer that directly, and don't know what scale you are working at, but if you have no reliable reference material, here's a suggestion:
Convert the 3/32" to full size inches, hold your hands that far apart, and ask yourself "does that look reasonable?"
Richard
     Richard
