I will soon start with my first ship with plank on bulkhead.
I´ve bought Duseks Pinta as my first model. It is a singel plank hull. I´m asking a little about preparing the planks. I´m thinking about first using a wash on them to stain them a bit darker and then spraying them with satin varnish and then "sand/rub" them with steel wool to make them a bit smoother before I start the planking process.
If I stain after gluing them to the hull even the smallest gluestain with ruin the color staining. The varnish spray and steel wool rubbing is to raise the wood a bit and then smoothen them with the steel wool.
Is this a good process or should I do something different?
I haven't tried finishing planks before attaching for a couple reasons:
1) I worry if the planks are finished, the glue might not grip as well, and I might not get as good a glue joint to the frames
2) a lot of the planks will require soaking and heat to bend them.  Not sure what that would do to your finish.
I haven't had a problem with wood glues (white or tite-bond) affecting finish as long as I sanded first.  Would definitely avoid superglue as it will affect clear finishes (the areas end up whitish).
Someone who has tried this might have a different perspective
Current builds: Model Shipways 1/48 LongboatEduard 1/48 F4F-3 and F4F-4
Completed ships and boats: Kitbashed Model Shipways 1/24 Grand Banks Dory, 1/16 East Coast Oyster Sharpie,1/48 Echo Cross Section, 1/48 Scratchbuilt Hannah from Hahn plans, 1/64 Kitbashed Rattlesnake from Bob Hunt practicum, 1/64 Brig Supply
