Hi All,
This is my first big question here im just new to the forum and this hobby. In a couple of days I will start with my first plastic kit from Revell the HMS Bounty. Because im new I did not bought straight away an air brush system.
So I'm wondering how can I paint with brushes on plastic and make it look like wood and a bit warned out wood. I saw some pictures online of the model i bought and some look very very good and the ones that have been painted as the instruction manual says looks like it is all new.
I bought all the colours that I need according the manual but if needed I can buy some other extra colours or materials to make it a bit more authentic. Before I really start I try to investigate a bit. Im hoping there is someone who could give me some tips.
Thanks in advance
Ray
Hi Ray,
Check out the following thread on painting. It should have some good tips.
http://www.modelshipworld.com/index.php/topic/3962-how-to-make-plastic-look-like-wood
(Sorry if it doesn't link direct. I'm on my phone and it won't let me hyperlink)
Carl
Completed builds: AL Bluenose II 1:75  Gallery
                              Amati Hannah SIB 1:300  Gallery
Current Build: Bluenose II - SIB - unknown scale
Hi Ray,
Thank cwboland I went thru this thread before i posted my question but as far I could understand they all speak mostly about air brushing and dry brushing. Well the latter i dont know what it is and a air brush system i dont have.
p.s. your link worked perfect.
Hi again Ray,
I've only been using brushes myself, and acrylics. I've had good luck, making sure to lightly sand and prime the surfaces first. No problem, even with large surfaces, using large brushes and long strokes. My only problem is how to make the darn thing look weathered (still researching that topic). I'll look at that link cwboland has. Maybe something there. Thanks cw!
Good luck,
Pete
I used on my bounty a wash from simple paint on water base.
I painted the deck with a light sanndy brown color and covered that witha gloss finish so it is smooth to let the wash flow. when it is dry you could use a dark brown paint (water paint like they use for children on school). I used random strokes and had all over the place uneven paint. Whe it was dry I took a cloth and made it a bit wet and startedto brush the paint with the wet cloth totake of some paint. When I got what I like i let it dry and appkied a flat finish.
This method is safe because you covered you base color the sand brown with a finish if you dont like your wash you can clean it with a wet clothand do it over again. I dont have pictures here but I thought I posted a video of this somewhere.
Dry brushing would be also a good topic to search on btw.
I hope this helps you a bit
Gryz Ray
Post No. 12 in this thread explains what dry brushing is.
http://modelshipworld.com/index.php/topic/3962-how-to-make-plastic-look-like-wood
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
Indeed Ulises this thread I've read and it really explains very clear what dry brushing is. Just by reading it you should be able to make a decent attempt, at least I could. But good to mention I'm a rookie in scale modeling :)
Hmmm... I think we all were that at one time or another. :)
Saludos from Mexico
