Hi
I want to know how does Constructo quality compares to AL?
Now why the heck would I want to know this? Reason is, is that here in my country hobby shops only seem to have an local importer for AL products. So other companies like Euromodel, you are going to have to either buy and ship from their website, or nicely ask your hobby store to do it for you, which means it becomes a lot more expensive than normally buying it from a brick an mortar store.
However, I see one shop here sells Al and Constructo, with the Constructo being a bit cheaper than AL.
Thanks
What do you mean by "quality" ? Material, instructions, historical accuracy and research behind the model?
Nevertheless I would say both are equally low - may be it is better to speak of a particular kit from their range than just general talk, otherwise there is not much to recommend .
"A smooth sea never made a skilled sailor."
Completed: Smuggler
they are all poor quality
you must rebuild a lot of pieces because they are wrong or non - historical
the wood is low quality etc.....
but if u  just want to build a ship for plesure it's good and all brand are good
Of the bank I look at an ocean of pleasure, or the tumult attracts you, this global movement will be your tipcart!
current build:   royal caroline
buid finished:  la recouvrancehttp://modelshipworld.com/index.php/topic/3025-la-recouvrance-by-ofencer29350/page-2?hl=recouvrance
For quality, I would like to know about material and instructions.
Both are equally low compared to what?
Compared to what?
Thanks!
Equally low together. Compared to kits from e.g Jotika, Victory Models, Model Shipways
As said, if you just want to build something, does not matter which one of AL/Cons you choose. You will get what you pay for. Whether it is enough for you is up to you.
Completed: Smuggler
Thanks!
