Chuck:  I've used Trans-Tint in the past.  It generally works well.  The only drawbacks are :  1)  It is water or alcohol soluble, so application on wood can raise the grain, especially with soft woods like pine or basswood.  2)  It's a concentrate, so you add a drop at a time until you get the shade you wand.  That makes it impossible to exactly duplicate a batch after you use it up (varying size of each drop, etc.) so mix up enough beforehand to finish the job!
