Hello Les here. I have a question about the posts for bitts and belaying pin racks.The tops of these posts are tapered. Is there a way to set up a production line for tapering the tops ? I have many to do>
Did you mean that they are bevelled ? If that, I would make a sanding jig for this, so that you can hold them at a 45° (or any other appropriate) angle. That jig also should have stop, so that you can offer all sides of the bits etc. at the same distance to the sanding block in order have the bevel equal.
I you have a milling machine, of course, you can also make a jig for use on that one.
