I am building (first build) Lynx, Mantua Panart. The hull is double planked and per the instructions each side will be 2.5mm thick. The keel, into which I am cutting the rabbet is only 5mm thick. Clearly this is not thick enough for all four planks to sit in their rabbets. Do any of you splendid folk have any advice.
I was thinking I would not take the first skin into the rabbet and sand the planks down to the barding line. Then only put the outer skin into the rabbet. This, however would probably mean single thickness only in the dead wood area at the stern. Any thoughts?
Link to comment
Share on other sites
Hey howya goin Rat-Fink-A-Booboo mate, you are right Rat-Fink-A-Booboo just do it that way.  :bird-vi:
I'm probably not going to live long enough to build all these but I'm BLOODY going to try HAHAHA.
Future Builds: The Schooner Bluenose, scale 1:48, POF Scratch Build (Gene Bodnar practicum - Plans from modelshipbuilder.com)
                       HMS Victory, scale 1:64 or 1:48, POF Scratch Build (John McKay's plans)
Current Builds: 42ft Longboat Armed for War 1834, scale 1:36 POF Scratch Build (Plans from A.N.C.R.E.)
                        Galley Washington 1776, scale 1:48, POF Scratch Build (NRG's Plans)
                        Ragusian Carrack, scale 1:59, POB kit (MarisStella)
                        King of the Mississippi, scale 1:80, POB Kit (Artesania Latina)
                        HMS Snake 1797, 18 Gun Sloop of War, scale 1:64, POB Kit (Jotika/CalderCraft)
Current Build: Stage Coach 1848, scale 1:10, Kit (Artesania Latina) Shhh don't tell the Admins I'm building this I'll hide it here ^under this line^ so they don't see it HAHAHA.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
