Introduction
I started this build early in 2007, after having some moderate success with plastic models (airplanes and a few ships).
Didn't know anything about wooden ship model building so I started based on the kit instruction booklet. I soon abandoned the build, because I was frustrated but mostly because I didn't have a workbench area to set things up and work in steps. When using the kitchen table and expecting 2-3 meals a day, the build gets in the way. You can imagine.
Current state of affairs
Well, 10 years is a long time and the partial built kit was stored safely in a box filled with Styrofoam popcorn in the basement. I have since then moved to a new house with the luxury of a workshop in the basement. Plenty of things to do when you get in a new house so the kit was safely forgotten on a shelf. Until last summer when something made me bring it out and see if I could continue with it and hopefully finish it. In the meanwhile I browsed for information on how to properly build model ships and found plenty. Eventually discovered ModelshipWorld as well.
So here is what I was expecting when I started. The picture is from the Artesania Latina website.
new-spanish-galleon-san-francisco-ii-mod
The first picture I have here is of the stern deck fully planked. Didn't know about staggering the deck planks or even cutting them to shorter pieces. There was a reference in the instructions but I chose to ignore it. After all, it was much simpler with long planks, right?DSC_13302.thumb.jpg.592b12d8cf467a87c2c06f75e1060925.jpg
The next picture is from the stern, showing the hull planks covering the sides. Port side is not fully planked to the top of the bulwark and planks are not trimmed yet (in 2007). You can also see at the top of the starboard side that the false bulwark is not making contact with the bow piece. When done and trimmed, the hull planks left a gap there. I should have been more careful when gluing the pieces, as thinks like that take a lot of effort to fix (or hide).
By the way, the next few pictures are actually 10 years old, so when I start showing my mistakes, please don't get too excited. It's all done 10 years ago. In the next few days I will start catching up with the build, showing the progress I made since summer with the help I got from reading other fellow member's builds for this and other similar hulled ships.
Edited by SaSi
Here is another detail showing the trimming in progress for the deck planking. Unfortunately I didn't take any overall pictures of the ship nor did I think of taking pictures of the fitting of the bulkheads on the false keel.
I am not sure what I was trying to picture here. Probably me having a hard time sanding the edges without lifting the veneer thick planks.
And here starts the interesting part. Please be gentle but be truthful. What do you think I was thinking when I did this? I was looking at this picture and I was trying to figure out myself. And failed.
The picture shows several mistakes and omissions. Both turning the plank all the way to the port side - which was hard and took some effort only to cause several problems, as well as the second plank showing a step out from the top plank covering the stem. Something was wrong in the bulkheads and caused that step to the starboard side only. Can't remember what.
And, of course, since it was not mentioned in the instructions, I didn't fill the first two bulkhead sections with wood. Only learned about why this should be done 10 years later. Well better late than never.
And, of course, here we have the third plank with a rubber band trying to keep it in place but bending it in a way it should not have been bent.
Needless to say, the second and third planks you see here were carefully removed to be able to continue with the hull.
In the next few pictures some details are shown, but it's mostly me trying out my new (back then) 100mm macro lens.DSC_13309.thumb.jpg.1b65dcfa54b30611745221c5d4a7e559.jpg
DSC_13303.thumb.jpg.c382ea783257f52ccf26363705cf8974.jpgDSC_13311.thumb.jpg.776acd3bbb643fa351f6d87c11894d76.jpgDSC_13321.thumb.jpg.f34c1fd8bd22e71a8dfcf6bedc2b1483.jpgDSC_13325.thumb.jpg.e1415eae8b8ee2a5fa993f3ba1db6ba9.jpg
Here we are in the stern, showing a rather decent job of planking. I mainly want to point out here that the sticks provided in the kit for hull planking, although documented as mahogany, are actually several different color variations. I remember I considered using the dark ones for the above waterline part of the hull and the rest for the keel but later decided to interleave them and show the curvature of the hull - from stem to stern.
Here is another picture of the stem, showing the big mess I did to it.
Planking at the bow isn't bad - for a first timer. Or so I think. That was the part of the build I was proud of when done. But what I want to show is the part of the false bulwark (thin plywood supplied in the kit) that is showing to not make a good fit. It is half showing in the top of the picture. Along with some badly trimmed planks that will cause issues when the captain's terrace will be mounted there.
Hi SaSi
i am new to this hobby, and planking can be a  difficult task but  there are plenty of tricks out there to help with the task I  learned a bunch from the link below
https://modelshipworld.com/index.php?/forum/14-building-framing-planking-and-plating-a-ships-hull-and-deck/
check it out , and be patient, follow the plans and most importantly have fun
Derek
Derek C
Quote
A man without a goal is like a ship without a rudder --Thomas Carlyle
Current Build
18th Century Whaling Vessel "Lagoda"
Finished Builds
Triton Cross Section by Derek C 1/48
18th century longboat by Slideways - FINISHED - Model Shipways
18th century longboat by sideways from MS plans
Hi Derek,
thanks for the link. I have been reading these threads since last summer. I have been progressing and fixing things and documenting them along the way. I will be posting the progress done so far in the next few days and keep updating as things progress.
Just a spoiler: Hull planking is complete and it does look decent. A few things I learned along the way will help on the second build.
Fast Forward ten and a half years to August 2017 and here is the build as it came out of the closet - more or less. What you see in the front most bulkhead to the left of the picture is another big mess I made by following the wrong suggestions.
You see here the hull structure sitting on a holder contraption. Didn't help much as it had to have some play for the keel to fit through while the backbone frame was a mm or so thinner.
Another detail that had me stumped was the edge of the stern. The bulwarks seem to grow higher than the back part. Something that took me some effort to fix. I don't think this is my mistake though. I've seen other builds in progress in the meantime and they show the same problem back there.
And here's the royal mess I made to the bow. I read somewhere back in summer that this part should be filled with filler to aid in planking. Now, I may have misread but it wasn't clear if it meant filler putty or filler pieces of wood. I used wood putty. Made a mess around, took ages to set - never set fully - and was soft as clay. Spent a couple of hours a few days later to clean that up.
So, lesson learnt: Fill up the bow bulkheads with good quality plywood or even hardwood. Balsa is totally useless and birch plywood is soft and pins / nails don't stick during planking. I mainly used the scrap plywood from the bulkheads in the kit. It was difficult to cut and sand but made for a great substrate for planking. More of this in next pictures.
BTW you can see in this picture that the original mess of the overcurved planks is sorted out. These were cut and new planks were put to the port side. Unfortunatelly the topmost plank had to be sacrificed. Something to fix.
Edited by SaSi
BTW, if you noticed a change in hue in the color of the wood of the model, I noticed that too. The color shows correctly on my monitors when I view the pictures through different picture viewing software. It's only when I upload the pictures to the site that the color changes.
I changed my camera between 2007 and today so it may have to do with camera color profiles messing up with the site's settings. Any insight from anyone on that?
Here are some two of the canon ports being enlarged from the original size I cut them 10 years ago.IMG-001510.thumb.JPG.85b1156bdf326246407f8bf67d983a04.JPG
And here is the same canon port when completed with the frame mounted. Looks great but it's wrong. These are the topmost canon ports and these are supposed to take the empty frames - the ones without covers. Well, these are a mm smaller than the hinged frames so these ports were cut larger than they should. Something more to think about along the way.
Lesson learnt: Check the kit contents and identify the various parts before assuming anything.
Edited by SaSi
The last picture in the post above is there by mistake. Uploaded it again and couldn't find a way to remove it.
Edit: Found the way to remove the extra picture. Pressing the semi-transparent bin over the picture. Nice!
Edited by SaSi
Here is a picture from the stern planked with thin (0.6mm) planks. Put in place to set. Trimming and planking done only when glue is fully set. Best to do it on the next day.
Here is the bow with the bulkheads cleaned up from the putty mess ready to be filled with wood fillets. IMG-001551.thumb.JPG.d4c31ae3795e26bd40fb4bd42c143866.JPG
And a picture of the stern, after trimming the planks and fitting a curved and sanded piece of plank over the top to fix the look of it.
Here is a close up shot of the bow with the planks trimmed correctly. I used a dremmel with a sanding disk to gently clean the edges. The nails holding the planks can be seen also. These are the nails supplied with the kit. They have a huge head - totally out of proportion to the scale. I nailed one on a piece of scrap and tried to sand the head down with a file. It was very hard to do so eventually decided to use them to hold the planks until the glue set and then remove them. Removal wasn't hard - I just used a sharp blade to lift them.IMG-001580.thumb.JPG.a134a9d5a55ebd4c111abd607783e81d.JPG
Insert the nail into your dremel and use a good file and you can resize those nail heads with ease
Derek C
Quote
Current Build
Finished Builds
Here we are on September 29th. I'm keeping track of dates thanks to the information in the pictures.
Planking has progressed a bit. Notice the second plank from the bottom to the left of the picture. This is a mistake. That plank should have been tapered, like the corresponding plank to the port side. Same for the plank it touches from below. These are mistakes that I have to live with. I was also a bit worried about the looks of the planks. Even though I beveled the planks I mounted - from the top going down to the keel - you can see gaps between them. You can also see some cracks caused by the nails. I should have used a mini drill to pre-drill before putting in nails.
Hi! thanks, interesting point. I will keep that in mind.
Here is some more progress in planking from October 10th. By the time I reached this point I had read up planking techniques and started tapering the planks as they reached the bow.
One think I wanted to show in this picture is the fact that the planks are being laterally bent as they reach the stern. Probably not the right thing to do but as I mounted the first first planks in the wale and followed the instructions, that plank had to be bent in that way. From there on I just followed the flow.
What do you think about this pattern?
Here we have that missing - broken - plank replaced.
And here we are at the stern bulkhead. Below the waterline - wherever that is - it was becoming difficult to nail and glue the planks to the stern bulkhead. The planks came at an angle and would only touch the edge of the stern. Not a promising joint, even if I kept the nails, which I had decided not to. So I glued 3 pieces of 0.6mm planks there, let them dry and then sanded them at an angle to create a full face surface for the planks to sit. Worked out well.
Going down to the keel - I had already glued the gardboard in place - here we have a bended plank that was dry (actually wet) fitted in place and kept there with pins. That's a good idea I picked up but it was rendered difficult by the fact that the bulkheads gave in and split at times. One thing I would do (next time) would be to glue extra "ribs" to the bulkheads to thicken them and make them stronger. That would also allow to plank the hull with staggered "scale correct" planks. As it is in the original kit, the bulkheads are so thin you cannot mate two planks on a bulkhead. One of the reasons I chose to plank the hull with fullsized sticks.
I should also point out that after the first few planks I switched from white PVA glue to contact glue. Applying a layer to the new plank, the edge of the last plank and the bulkheads gave a much better fix after waiting for 5 minutes for the glue to cure a bit. The planks would stay in place much easier and it was less of a strain to the bulkheads and the pins.IMG-001630.thumb.JPG.9ff07e912d746641d9ac78e7edb7efd0.JPG
Edited by SaSi
Here we are almost done with the hull. Once I got the hang of it I could do two planks a day, even on working days. The picture shows there will be some space for a stealer in the back. IMG-001639.thumb.JPG.a6193f44436ca218ecb95528d742f578.JPG
Here is a view of how things look at the bow. I should have tapered each plank in the same way and made them look symmetrical. But I accept this as good enough for the first build, hoping that after sanding down things will look better. IMG-001648.thumb.JPG.13d53c94c5ede73b9e18d349c33b22d3.JPG
Here is the last plank before being mounted. It was tapered from bulkhead to bulkhead until it made a good dry fit. Of course I now know I should have planked from the keel up and the wale down to meed at the bend of the hull. It might have been easier to fit the tapered plank there. But, OTOH, down there that plank isn't really visible. What do you think?
BTW, while planking down the hull I started filing and sanding from the deck down. It was a slow and rather tedious process but it was fun. I applied little force to the files so as to avoid scratches and after a while I switched to a small sanding block with 80 grit paper.
Edited by SaSi
You can always go back and use a 11 blade to cut deep grooves in your planks and then use a wood burning pen to define the cuts if the full planking bothers you ;)
Derek
Derek C
Quote
Current Build
Finished Builds
