Chuck, I'm a newbie and hope this message goes through in the correct format.  Working on  Palamos Fishing boat made by OcCre.  cant bend the bulwarks to fit to the deck and hull.  Anyone in your group have experience?  In case I haven't registered correctly my name is Walter my e-mail is xxxxxxxxxxx.  I suspect i'm in the que someplace since my name is at the top of this page.  Thanks Walter
Edited by mtaylor
Edited by Moderator to remove emial addy to keep it out of the hands of the nasties.
Hi, Walter - and welcome aboard!  You may want to post your question under the Framing section - may also want to start a build log under the kits section - folks are quite friendly and willing to help!
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
Hi Walter,
Welcome to this wonderful site :) I've found it very helpful to soak the bulwarks in hot water for a couple of minutes, gently bend them, soak some more if needed then test fit again. Never force bend the bulwarks as this runs the risk of breaking them. As the others suggested, you may want to start a log of your build, you will get a lot of help here. You may also want to remove your email address from your post so as to prevent spam websites from infesting your email. Good luck and don't hesitate to ask if anything is unclear, there are plenty of helpful members here B)
Edited by rdsaplala
Best regards,
Aldo
Currently Building:
HMS Pegasus (Victory Models)-Mothballed to give priority to Triton
HMS Triton (first attempt at scratchbuilding)
Past build:
HM Brig Badger (Caldercraft), HM Brig Cruizer, HM Schooner Ballahoo
