I hope this is the right forum, my good friend John Garcia had no answer, suggested I come here. I have an estate kit of Heller's Soleil Royale. All the black standing rigging is awol. Trying to find out the sizes needed so I can replace them.
Thanks in advance
Here is what I used, based upon R.C. Anderson The Rigging of Ships in the Days of the Sprtisail Topmast 1600 - 1720:
The rigging sizes all are figured relative to the main stay which has a circumference equal to half the maximum diameter of the main mast, so
42.76 inches mast diameter x 1/100 scale gives 0.43 in.  scale mast diameter
.043 / 2 gives a main stay circumference of 0.215 inches
0.215 / 3.14 gives a main stay diameter of 0.068 inches.
The closest line I had available is 0.08 inches (which may be a bit too large. 0.06 may be a better choice)
The following rules of thumb then apply (in order of size):
Fore stay = 4/5 of the main stay
Main shrouds and Main topmast stay = 1/2
Fore Shrouds, Fore topmast stay, Mizzen stay = 2/5
Main topmast and Mizzen shrouds = 1/4
Fore topmast shrouds, Mizzen Topmast stay and the two Topgallant stays 1/5
Shrouds for the last 3 = 1/6
These following rules apply to the rest of the rigging but they are relative to their respective lines (this should become clear in the table below):
Mast tackle pendants = shrouds (i.e Main mast tackle pendants = the Main mast shroud diameter)
Shroud deadeye laniards = 1/2 the shroud
Stay collars = 3/4 of the stay
Tackle runners = 2/3 of their pendant
Tackle falls = 1/2 of their runner or pendant
Backstays = Shrouds
Tyes = Shrouds
Halyards = 2/3 of the Tye
Lifts = 3/8 of the shroud
Lift pendants = 1/2 shroud
Braces = 3/4 of the Brace pendant
Brace Pendant = 1/2 shroud
Deadeyes = 1/2 the diameter of the mast
Tacks = shroud
Sheet = 3/4 shroud
Clews = 1/2 of the sheet
Bowlines = 1/2 shroud
Leech lines = 1/3 shroud
Bunt lines = 1/3 shroud
Block length should be about 12 times the diameter of the rope and their sheeves should be about 9x the diameter of the rope
Hope that helps some.
Regards,
Henry
Laissez le bon temps rouler !
