Let's number your circles 1-8, left to right. It looks like circles 3,4,6,7 those lines all go to a belaying pin at those racks. Circles 1,2,5,8 all refer to jib/staysail sheets. Are you going to put sails on your model? If not, then don't worry about the sheets, 'cause you won't have anything to attach them to. If you are, those are probably blocks attached to the deck to give the sheet a fair run.
