Good evening all...  I hope everything is well with you...
Can anyone tell me if they have used a glue called Titebond,,, if so what are their thoughts on it... and what one did you use,, The Original,,  Premium or Ultimate
Many thanks
JT
Jim T
Current build:  HMS Agamemnon - Caldercraft - 1:64
To not be confused, there is plain PVA glue which is white, dries clear and has large opening time. And there is the aliphatic PVA, which is yellow, dries not really clear and has very short opening time. Titebond original is aliphatic, non waterproof and has a really short opening time. The other ones are waterproof and offer slightly longer opening time. Not important for our purposes
I use usually an aliphatic PVA (happens to be Titebond original at the time but others work the same) but when I want long opening time or no marks to show on the wood I use hardware store white PVA.
