Johann, Joe, John- thanks for the kind words!
Not a huge update, but an update nonetheless. Waterways have been installed- they ended up being more of a pain in the butt than expected because of the need to drill out the cannonball divots and making them neat. I feel that similar to treenails, it would be easy to make them look incredibly sloppy if not lined up and even. I think I got it where I'm happy with it considering I don't have a mill. In the end I also am not a fan of cutting down the deck beam ends into a tab to fit between the clamp an waterway like I did. The idea is to make things easier but I don't know if it accomplished that and also made some of my beams a bit less sturdy. In the future I would notch the clamp and waterway as was done in the original ship.
I also cut down my frame tops. When I made my frames I didn't leave enough wiggle room on top so a few were a bit under the correct height for the rail. My solution was to cut them all down 5mm below the rail height which is why they look a bit low. I will add a 5mm cap along the top that will just get covered up by planking and I figure make things a little more rigid anyway.DSC_4357.thumb.jpg.248a8a11e37e971fcf35e6434b613f2c.jpgDSC_4356.thumb.jpg.9eb841493f5b284098cbf86d5b14a919.jpgDSC_4352.thumb.jpg.21001af27ce2fd177a33d8b7511c327b.jpg
Thanks for looking in!
Chad
Edited by ChadB
Completed Models:
Triton Cross Section
In Progress:
Brig Eagle
