Hello,
as I told you I'll do some small short turn projects in between. Here is N°1.
Todays noon I did start a whale boat by GK-Modellbau/Kirchlengern (Germany) in some strange vaneer based PoF style.
Mondfeld critics this buildingtype very hard in his new Encyclopedia of Modelbuildung (3.1/3.2 the Hull part I. & II.) Here my shipcat on the vaneer, gypsum mould kit - and the quite nice stand within.
It is a coaster boat of the XVII.century hunting the whale in a small villages whalemen group. So there is no need for a big whaling ship to be built, too.
The formers lay quite well on the gypsum moulds surface - wetted with water and pressed on by a soldering iron.
The holes for the formers are not aline with the grooves in the keel - so the formers are diagonal...
Hope you like todays progress and the scratching freestyle on the fore and aft lockers topsides.
Here the sideview of todays progress; that ruler shows how small the hole kit is at the very end.
Wishing you a good night.
"Let's add every day 1/2 hour of
modelship building to our
projects' progress..."
Take care!
Christian Heinrich
simple, true and inpretentious motto of ROYAL LOUIS, 1668
Sunking's mediter. flagship most decorated ocean-going ship
Ships on build:
SAINT PHILIPPE, 1693:
1st rang French 90-gun ship - Lavente flagship (based on Heller SR - 1/92 & scratch in 1/64)
TONNANT, 1693:
1st rang French 90-gun ship - sister of SAINT PHILIPPE (mock-up/test-object for S.P. - scratch in 1/64)
Projects in planing:
L'AURORE, 1766:
French Pleasure Corvette (after Ancre plans - scatch in 1/64)
Some Spantaneous Short Term Projects
I have to admit
...I could not stop to build this night...
...only five plankes are placed till noon...
...and the plankes were side by side when I placed them. But by the soldering irons heat they shrink so canyons not gaps appear  - some more than frustrating thing! These "gaps" are as big as a plank is thick!
I am told in the instructions  to paint thehole planked hull with wood glue, wipe it off the planks - sand them and the saw dust would fill the gaps and magically the do disappear...
But due to the size of the gaps I cannot belief in the successfull use of this simple technique. And I do think of the inlaying of squaresized stripes of the planks to fill the gaps before the wood-glue-& sanding trick.
What do you think about this? Can anybody who planked a boat in 1/48 tell to me what to do?
Take care!
Christian Heinrich
Ships on build:
TONNANT, 1693:
L'AURORE, 1766:
The breakfastdaylightpictures (yes in German we can make such long words at Scrabble) show the biggest malus and bonus of this kit:
The formers were swung aft :( due to the mispositionation of the gypsum mould on the predrilled plywood!
But what works is my wood craft artwork, yesternight I was in doubt - but it does it :)
Take care!
Christian Heinrich
Ships on build:
TONNANT, 1693:
L'AURORE, 1766:
  • 11 months later...
Hi.
I built the same ship, maybe due to a later version of the kit I have not seen same issues.
I was able to fill the small gaps between the plankes follow the instruction (white glue and sanding)
Have you finished the kit?
Thanks. Norbert
