You’re most welcome, Patrick. If you want, I will send you the fuselage that I didn’t use, just send me a pm with your contact and I’ll get it on the way. It’s partially painted but can be cleaned up.
Don
Thanks so much Don. I checked it out and really like the helicopter model's detail and went ahead and ordered one. In addition to using the pontoons which I have, I guess I could change out the area behind the fuselage to look more like the original.
I appreciate your response. Patrick
Hi Don,
I am starting to build the crane and other deck hardware.  I have a big question and favor to ask. The plans show part numbers for the various crane parts. Some are obvious like the plastic molded parts. Others, I have no idea. In the kit you had, was there a complete parts list matching numbers from the instructions with various parts? All I have is the back of the instruction booklet with a very partial  list with no numbers to match the numbers in the plans.  Thank you. Patrick
Patrick,
sorry for the late response, just saw this. I’ll check and see if I still have the docs, I normally keep them but it’s been several years- will let you know.
Don
