  • Solution
The rabbet is there to keep the garboard plank close to the keel, even if the ship is flexing and twisting in a sea. So most larger seagoing vessels are constructed with rabbets in the keel and the stem.
When the garboard sits more less vertical on the keel, theoretically, you have two options for the rabbet, you can cut a square groove (or square notch, if there is a keelson sitting directly on the keel) or you can cut a triangular groove, as usual, but then have to sharpen the edge of the plank to fit. The square groove/notch arrangement would be difficult to get water-tight, as the slightest variation of thickness of the plank in the groove can cause it work loose and the caulking to fall out. If you have a triangular groove, you will be wedging the garboard plank into that groove and it cannot move in any direction.
However, whether it is worth to replicate this on a model is another question. One cannot see this, once the planking is finished and you can arrange the rabbet in the way that is easiest to make - that is when you only care about appearance and don't want to reproduce actual building techniques.
Thank you. I think I've got it now.
