French 1/1 mainmast stay rope 1680-1700, La Belle 1680
Go to solution Solved by popeye2sea,
Hi.
Anyone know what was the thickness of the rope "mainmast lower part stay(100%)"
on the French vessels from 1680th to 1700th in 1/1 scale?
I can't find this information anywhere, it's possible the rope was about 3.5 inches ?
In 1/36 scale its a 2,44mm, im making La Belle 1680. What thickness of rope should I make ?
What do you think about it ?
Edited by Kuba91nt
  • Solution
The Main Stay circumference should be half of the greatest diameter of the Main mast.
In order to get the diameter of the main:
Thickest part of main mast is at deck level.
Diameter equals one inch for every 3 feet of mast length.
Main mast length is approx. 2.5 times the beam of the vessel
So, for example, vessel has 30 foot beam
Main mast length 30 x 2.5= 75 feet
Main mast diameter 75 / 3 = 25 inches
Main stay circumference 25 / 2 = 12.5 inches
Main stay diameter 12.5 / 3.14 = 3.98 inches
At 1:36 scale a 4 inch diameter rope will be 0.11 inches or 2.8 mm
Hope that helps.
Regards,
Henry
Laissez le bon temps rouler !
Thank you, I'm still learning, some things I don't understand, that's why I'm asking.
La Belle has only 14 ft 9 in (4.50 m) ~ 15ft
Main mast length 15 x 2.5= 37.50
Main mast diameter 37,50 / 3 = 12,50
Main stay circumference 12,50 / 2 = 6,25
Main stay diameter 6,25 / 3.14 = 1,99
At 1:36 scale is 1,41mm, but this is a barque
Isn't that too thin for a ship of this type ?
Kuba,
What I gave you was a general rule of thumb for ship rigged vessels of that era.  Personally, I think that a 1.4 or 1.5mm rope will probably look just fine. But if you wish to go a bit larger, have at it.  Whatever you feel looks good to your eye is what is important.
BTW, I'm guessing that Kuba is not your real name. We are a fairly friendly bunch here on MSW. We like real names (no pressure).
Regards,
Henry
Henry
Going off topic here and you may be right but the symbol looks like a Rasta lion and I THINK Kuba is not an uncommon Rastafarian name.
Allan
Edited by allanyed
Allan
15 hours ago, popeye2sea said:
Kuba,
Regards,
Henry
My real name is Jakub, in Polish Kuba is a diminutive of Jakub. Jakub and Kuba is a variation of the name Jacob.
And the Rasta lion is because my name is Jakub - Jacob, and im Rastafarian 😀
Thank you very much for your answers.
Regards,
Jakub, Kuba 😄
