Looking good Udo.
I am also building the Endeavour.
I am onto the 2nd layer planks, above the wales.
My first layer - had several planks that split when bending at the bow.
I'll keep on eye on your log.
Cheers Dave
Dave R
Measure twice, cut once.
Current Build: HMB Sirius 1786 - Flagship of the First Fleet to Australia (Scratch Build in the Shipyard)
Finished Build: HMB Endeavour 1768
Thank you Dave for stopping by.
Wale on the starbord side has been completed.
As mentioned earlier I'am not using the kit supplied planks, the wale consists of a 4mm x 1,5mm walnut Strip for the blackstrake and four strips 3mm x 2mm for the wale.
Before constructing the wales I have compared the kit drawings to the AotS, it matches very well.
Cheers,
Udo
Current builds:
Le Coureur 1776 - CAFmodel 1/48
VOC Retourship Batavia
Boston Typhoon steam trawler 1/32
Research/Side Projects/On Hold:
H.M. Bark Endeavour
HMS Bounty 1787
Nice sweep to the wales Udo.
I'm still planking the 2nd layer, be glad when they are all on.
Dave
Dave R
  • 1 year later...
Hi, I've had this kit in storage for a while and just starting it now. I read your post regarding the deck cannons being too big and after checking mine against the plans discovered that I had the same problem. According to the plan they should be 30mm not 45mm long. So thanks for the heads up and to the advise to contact JoTiKa which I've just done.
Cheers and hope the build is coming along ok.
Current Build:HM Bark Endeavour, scale 1:64, Caldercraft static kit (Build Log)
