jack stay on 1850s clippers
Go to solution Solved by gak1965,
12 minutes ago, paul ron said:
im working at 1/8" = 1' flying fish. 1" = 0.0104"
what is the diameter of a jack stay on clippers; and what would the scale equivalent wire gage be on my model?
Well that depends on the diameter of each yard.  I tend to use my eye...since wire guage can be tricky..dependant upon country and manufacture origin.
Here is a pic of a jackstay on a yard from a  downeaster...windjammer.   A grandson of its predecessor the clipper.
Rob
Current build:
Finished build:
Current build(On hold):
4 hours ago, paul ron said:
so would you think about 1" - 1.5" is a fair estimate?
Are you asking about the stay eye bold spread?  The distance from one eye bolt to the next……in your scale?
Rob
Current build:
Finished build:
  • Solution
FWIW, I used 24 gauge annealed steel wire for the jackstays on my 1:96 Flying Fish, except on the skysails where I dropped to 34 gauge. Doesn't mean it's right or to scale, but it seemed to look okay and worked tolerably well with the 0.75 x 6mm eyebolts I used for the jackstay eyebolts.
Regards,
George
yes the 24 is optically pleasing. i was tinkering with different gages but then the ocd kicked in to find what would real ones measure.
thanks.
gak1965... i cruised your build log for the ff... nice job!
Edited by paul ron
I just checked the data given by
MIDDENDORF, F.L. (1903): Bemastung und Takelung der Schiffe.- 401 p., Kassel (reprint 1977 by Horst Hamecher).
which, albeit in German, is probably the most detailed textbook with relevance to the late 19th century. He designed and rigged inter alia the five-masted ship PREUSSEN.
On page 313 there is table for jack-stays and their fittings. The diameter of the jack-stay is proportional to the length of the yard. For a 10 m yard the diameter should be 15 mm and its centre above the yard 25 mm. For a 30 m yard the diameter should be 25 mm and the centre above the yard 36 mm.
